Do "chain" autoparts stores carry copper crush washers for brake work?
Old 04-13-2007, 09:56 AM
CVBowers
CVBowers's Avatar
Default Do "chain" autoparts stores carry copper crush washers for brake work?
Will be installing fresh calipers here soon... have Goodrige SS lines w/ AN fittings and will need some fresh crush washers for the fitting that screws into the caliper.
Do the "normal" stores carry them, or is there a good source to get a few?
Old 04-13-2007, 10:33 AM
DOUG @ ECS
Premium Supporting Vendor
DOUG @ ECS's Avatar
Location: Providing the most proven supercharger kits for your C5/6/7 609-752-0321
Received 1,086 Likes on 657 Posts
Everyone I have been to does, but they might have to take it from a caliper box so it might depend on the person behind the counter.
Old 04-13-2007, 10:51 AM
CVBowers
CVBowers's Avatar
^ Thanks.
Old 04-13-2007, 10:57 AM
VetteDrmr
VetteDrmr's Avatar
Received 1,398 Likes on 749 Posts
The AutoZone I use has them in multiple sizes.
HTH, and have a good one,
Mike
Old 04-13-2007, 02:33 PM
rbl
rbl's Avatar
If the are solid all you have to do is get them red hot with your little propane tourch and throw them in cold water ... just like new.
That is how we do the aircraft plug washers.
Old 04-13-2007, 02:37 PM
redvetracr
redvetracr's Avatar
In your neck of the woods you should be able to find a stock car parts outlet that sells Goodridge or Aeroquip stuff.
...redvetracr
Old 04-13-2007, 02:52 PM
CVBowers
CVBowers's Avatar
Don't need anything fancy... just 4 replacement copper washers.
Old 04-13-2007, 04:20 PM
Falcon
Falcon's Avatar
So, you're getting that thing ready for the track season, huh? Good to see you're going to put it to good use. Get it rolling and help me keep these young guys in line!
See you out there,
Jody
Old 04-14-2007, 09:55 AM
DaveL82
DaveL82's Avatar
As others have mentioned might find them at the local parts store. If you can find a real parts store still in business that's the best option or else you have to deal with "what year car, what engine, what color..." instead of them knowing how to determine what you need and where the parts are.
Another option is the local HW store however as with parts stores it's best to find a real HW store not Lowes or HD. I found washers coper washers at the local HW store when I couldn't find them elsewhere.
Old 04-14-2007, 10:15 AM
davidfarmer
Support Corvetteforum!
davidfarmer's Avatar
they all carry them, and you are smart to not try and re-use them. Sometimes you can get away with it, but the concentric circles stamped into the OEM lines make re-use difficult
To Do "chain" autoparts stores carry copper crush washers for brake work?
Quick Reply: Do "chain" autoparts stores carry copper crush washers for brake work?
