VBP C5 polyurethane swaybar bushings
Old 04-09-2007, 11:47 PM
crznZ06
crznZ06's Avatar
Default VBP C5 polyurethane swaybar bushings
I'm almost done with the poly install on my C5 Z06, but I can't seem to get the front swaybar bushings installed properly. If I orient the bushings to fit the grooves in the subframe, the bushing is too tall for the stock brackets (bracket mounting faces don't contact the subframe). If I orient the bushings so that they fit the brackets, the grooves on the bushings don't match the subframe (pushes the brackets too far forward). Any tips? I'm itching to get my car running. Thanks!
Old 04-10-2007, 12:49 AM
John Shiels
John Shiels's Avatar
Location: Buy USA products! Check the label! Employ Americans
check they didn't send the wrong bushings. I have used their T-1 bushings with no problem. Give them a call they have great support.
Quick Reply: VBP C5 polyurethane swaybar bushings
