c6 z51 sway bays upgrade to z06
According to the SCCA 2006 solo rules you can change the front only and still run stock.
In cutting that from the rules book I just noticed that stainless brake lines are only permitted in cars manufactured before 1992... DUHOO!
13.7 ANTI-ROLL (SWAY) BARS
A. For front anti-roll (sway) bars:
1. Substitution, addition or removal of any front anti-roll bars is
permitted.
2. Substitution, addition or removal of anti-roll bars may serve
no other purpose than that of an anti-roll bar.
3. The use of any bushing material is permitted.
4. No modification to the body, frame or other components to
accommodate anti-roll bar addition or substitution is allowed,
except for the drilling of holes for mounting bolts. Nonstandard
lateral members which connect between the brackets
for the bar are not permitted.
B. Rear anti-roll (sway) bars:
1. May not be removed, replaced, or modified in any way.
permitted.
13.6 BRAKES
A. The make and material of brake linings may be changed.
B. Substitution of clutch and brake hydraulic lines with solid metal
or braided metal is allowed on all cars manufactured before
model year 1992.
C. Alternate brake bleeder fittings such as “Speedbleeders” are
permitted. They may serve no other purpose.
model year 1992.
