Which SS brake lines to get?
Old 07-25-2006, 04:31 PM
Adam Boca
Adam Boca's Avatar
Location: www.ncminsurance.com Bowling Green KY Home of the Corvette!
CI 1-2-3-4-5-6-7-8-9-10-11-12 Vet
St. Jude Donor '07-'08
Default Which SS brake lines to get?
I have seen a couple different kinds...
Stoptech and Goodrich
What would you get?
I was told that the stoptech lines are coated so no dirt, dust, etc can get into the lines like the Goodrich lines. I also heard that the coating keeps the car from throwing codes if the lines touch another metal object such as the control arms...
Any opinions are appreciated.
Adam Boca
Old 07-25-2006, 04:33 PM
FasterIsBetter
FasterIsBetter's Avatar
I bought Goodridge for my '03 Z. They fit perfectly, came with replacement crush washers, and have nice quality to them. Ended up with great pedal feel as well. Very pleased with them.
Old 07-25-2006, 05:04 PM
EPiC Vette
EPiC Vette's Avatar
I have Goodridge. No issues, and they have a nice reinforced connection. Had Russells before.
Old 07-25-2006, 05:09 PM
freefall
freefall's Avatar
I got the stoptech's from pfyc.com - no issues at all with them. I went this route instead of the others because I drive on the street a fair bit and didn't want the grit getting inside the braided SS and abrading the lines (maybe not a real concern, but ...)
Old 07-25-2006, 06:15 PM
0Randy@DRM
Former Vendor
Randy@DRM's Avatar
DRM:o Goodridge builds them for us to our spec. We run a straight "AN" adapter into the caliper. Unlike many still use the block setup.
Randy
Old 07-25-2006, 07:06 PM
wtknght1
wtknght1's Avatar
The Goodridge are excellent lines.
I'd stay away from the Earl's lines. Although the Phoenix guys use them on quite a few of their cars, some ABS systems are incompatible with their lines for some reason and you'll get lots of ABS codes. That little problem took me nearly 3 years to figure out!!!!!!!! Grrrrrrr!!!!!
Old 07-25-2006, 07:13 PM
C6400hp
C6400hp's Avatar
Location: DFW This user does not support or recommend the product or service displayed in the ad to the right
Stoptech makes the nicest brake lines I have ever seen.
Old 07-25-2006, 07:24 PM
jlucas
jlucas's Avatar
Goodridge lines with the AN fittings and the coated lines. I believe that's known as Mallet's spec; I don't know if the DRM lines are coated. Randy?
Old 07-25-2006, 09:17 PM
vetteman9368
vetteman9368's Avatar
Location: I have no tolerence for liberals and fools, but sometimes i repeat myself
CI 3-5-7-8-9 Veteran
St. Jude Donor '08
I use the Russell Lines. Fit perfect, came with new washers.
Old 07-25-2006, 10:27 PM
Cobra4B
Cobra4B's Avatar
CI 3-5-6-7-8 Veteran
Goodridge lines from VB&P here w/ AN fittings. I had Goodridge lines w/ banjo fittings and got codes like crazy for the RF wheel speed sensor (bad grounding). Swapped the the AN fittings and all has been well ever since (over 2 years)
Old 07-25-2006, 10:28 PM
vms4evr
vms4evr's Avatar
Me too! For the same reasons. No complaints at all.
Old 07-26-2006, 07:53 AM
ghoffman
ghoffman's Avatar
Cruise-In II Veteran
Randy
I have the DRM lines on my C6Z and I really lke the 90 degree fitting. The 90 degree fitting makes the routing very clean. I have run them now for several months, several track days and they really help the pedal feel. The same lines and fittings were originally used with the stock calipers and fit without any mods to these new PFC zR33 calipers (which re-define the term awesome). I don't see how you would get any better. I used a rubber tube cut like a hot dog bun to prevent abrasion on the shock. These were not DOT approved, these are "track only".
Old 07-26-2006, 08:46 AM
Falcon
Falcon's Avatar
Gary, I can see how to slide the old pads out of those calipers, but how do you press the pistons back into their bores to insert new pads?
Old 07-26-2006, 09:17 AM
Adam Boca
Adam Boca's Avatar
I guess my overall concern is getting junk in the lines like dust and stuff like that. I do not want them ruining the inner lines since this is my daily driver...
The
Old 07-26-2006, 09:37 AM
ghoffman
ghoffman's Avatar
I just use a blunt screwdriver wedged between the old pad and the rotor. It moves very easily if you go slow (like 5-10 seconds). Then pop off the 2 jet nuts and pull the bridge up and the pads come out like toast out of a toaster with the bridge. It is very slick!
Old 07-26-2006, 09:39 AM
ghoffman
ghoffman's Avatar
The
I don't understand...
Old 07-26-2006, 09:52 AM
0Randy@DRM
Former Vendor
Randy@DRM's Avatar
Not coated.
Randy
To Which SS brake lines to get?
Old 07-26-2006, 03:14 PM
wtknght1
wtknght1's Avatar
I don't get that one either Gary. ??????
The SS lines are basically impervious to road debris, rocks, etc and don't expand when they get hot (like when on track). They are easy to install and work like a charm.
Those PFC calipers look even better than the link you sent me Gary. I'm sure they stop as good as they look too!!!! Sweet. I wish we could use those in T1!!!!!
Old 07-26-2006, 03:33 PM
Adam Boca
Adam Boca's Avatar
Good to hear..Thanks for the feedback..
I will look at the DRM lines...
Adam
Old 07-26-2006, 04:09 PM
John Shiels
John Shiels's Avatar
Location: Buy USA products! Check the label! Employ Americans
My DRM lines were 5 years old and 60,000 miles many track miles and were fine.
Quick Reply: Which SS brake lines to get?
