building a track C5?
I'm looking at picking up the left over donor for a GTM build.
Assuming no engine, no front and rear suspension.
What's a WAG on the cost to get it ready for as a track only car.
Thanks,
Carl
Thanks,
Carl
Thanks,
Carl
Thanks,
Carl
I have been in discussion with Tom Wallace about building rollers. Many ppl have an interest. No decissions have been made.
Currently buying an existing slightly used T1 for 30-35 K is the lest expesive. Some T1s go as High as $50,000 for a build but never raced C6.
to take a current C5 or C6 and fully prep to race in SCCA T1 ~ $25,000. That does not include a new engine.
For SpeedWorld GT, I think LG said he would sell one for $185,000.
Or do you just want a vette to take to track days ???
Carl
I'm looking to just take it to track days, run a few of the races ...
Have a good one,
Mike
Carl
If or when the Rollers become avaible, it would still be less money to purchase a used T1 vette for $30-35,000, then buy a roller and finish.
The first FRC rollers that chevy made back in 2000, where just under 20 grand. To finish the car off for race prep those cars sold for $85,000 before they hit the track.
Originally Posted by VetteDrmr
Are you wanting to do DEs or actual wheel to wheel races? Worlds of difference between the two. DEs can be done with your street car; W2W you really can't.
Have a good one,
Mike
Have a good one,
Mike
I'm looking to just take it to track days, run a few of the races like with OTR or other groups at Willowsprings or Buttonwillow. don't want to spend a ton, just would like to be reasonably safe. I was thinking that since most of the stuff coming off would be upgraded anyway....maybe it's an option.
Carl
Carl
Parts Needed to complete GTM Supercar
Complete front and rear suspension (minus leaf springs and shocks)
Front and rear hubs, calipers and rotors (outer CV joints on rear)
Tilt steering column w/stalks
E-brake handle/cables
Fuel tanks with pump(s) and flexible lines uncut
Radiator w/fans and plastic shroud
Engine and computer
Exhaust manifolds
Wiring harness w/engine, throttle control, & ignition sections
Wheels and tires
Oxygen sensors (4)
Ignition switch
Radiator fill tank
Wiper motor
Side and rear view mirrors
Exterior door handles
Vehicle speed sensor
Door window mechanisms
Seat belts
Gas pedal
Flexible brake lines- calipers
Hood latches w/ cable actuator
Porsche Transaxle Parts from 1987-1998 2-wheel drive 911 models
Porsche G50 or G50 variant transmission
Transmission must include the clutch disk, pressure plate and throwout bearing, inner CV joints and starter.
Doesn't sound like you'll have much car left to work with...
Maybe if you find a wrecked donor in which the chassis is toast but everything else is ok. Sounds like a lot of work though
Engine and computer
Exhaust manifolds
Wheels and tires
Oxygen sensors (4)
Ignition switch
Radiator fill tank
Wiper motor
Seat belts
Gas pedal
Originally Posted by AMERICANMUSL
That may or may not be true(TBD 4 me) but it's not nearly as fun...it's all about the journey!
Journey to the bank
