What clutch is best for roadcourses in 500 rwhp C5 Z06
Replacing motor and will likely change clutch while it's out. Which clutch do you recommend? Should I just keep my LS6 clutch with 10,500 miles?
You may need a twin plate clutch and sometimes this is a pain if you street drive the car as it may chatter some. Engine Mods can cause clutch rattle when the clutch pedal is depressed by movement on the intermediate separator plate in some applications. This is normal, however, and comes with the territory of multi disc sytems.
Here's a C5 chart from Exedy:
http://exedyusa.com/products/PDF/Corvette.pdf
haven't had any experience with others bill but the spec3+aluminum flywheel in mine seems to work well on the track. pita on street though, lot of chatter. not sure you'll be able to avoid chatter though.
Location: If you don't weigh in you don't wrestle Road America
I've installed a Exedy single and it is pretty quiet, there is a little chatter when you launch and it's engaugement is quicker, but all in all it's not unbearable. He's done two track events with it (3 days at Gingerman and 3 days at Mid-Ohio) and the only differance is the launch.
St. Jude Donor '06
i installed an exedy twin disc....i have 540 rwhp,have run 5 track event on slicks with no problems and drive it on the street...
427 dry sump..
johnny
427 dry sump..
johnny
Hey Bill,
In our little group of guys I've seen problems with Spec 3, 3+, LS7 and Centerforce. Not to name names but you know who these belonged to, two different guys. None seemed to stand up to drag racing for long, which is much harder than tracking. The LS7 has been getting a beating in the C6 forum, mostly from Ranger and other drag racers who don't like it at all.
Mike Norris recommended a stock LS6 clutch to my H/C car and it was flawless. As a matter of fact, I can't think of anyone in our Challenge that has clutch problems with the stock LS6, except one sticking to the floor, but that was remedied by taking out the over center spring. Can't beat the price either.
When's that bad boy motor going to be done?
