tune-up/mods
tune-up/mods
what all do I need to look at replacing after 4 years/45K miles and a bunch of track days. I've been doing to best I can own my own for the last few years, but when I get back to the states, I'd like to have someone that actually knows what they're doing go over the car and give it a good tune-up/upgrade. Essentially all of the mechanical components are factory origional and I think my driving as reached a point that I can use a little more car.
This is what I've got planned so far
- going to add a full compliment of coolers (Oil/trans/diff.) & accusump
- probably going to coil-overs (at a minimum replacing the shocks/springs/swaybars)
- clutch/flywheel
what about things like the timing chain, valve springs, push-rods, pulleys, seals, hoses, ect? Also, what about the "while that's apart, you might as well do ________" stuff (thinking cam).
My plan is to run SM2 class for AutoX and do as many track days as I can. Looking to spend around 10K, max 15K. Looking for reliability, handling and a little more power.
- clutch/flywheel
