Need a Roll Rar
Is the C5 Z06 on an aluminum frame or only the C6 Z06?
I have a local guy that can weld in a rollbar I'm looking at. But he said he would not touch and aluminum frame car...
Graham,
Your frame is steel....
jeff
Thanks Jeff.
I'm looking at the R-D Racing S/T Frame Support as they call it. It installs with bolts. But you have the option to get it welded. If I do it I thought it might be nice to bolt it in and get it all ligned up. Make sure I like it. Then have it welded. Their bas has the proper cross brace and it doesn't interfere with the rear view mirror from what I'm told. Most of the ones out there make the rear view mirror fairly useless.
Graham
Graham
The R-D Racing S/T Frame Support does interfer with the view out of the rear window. In my opinion it is a very poor design for visibility. I have one and I would not get it again. Dave Cooper led me to believe visibility would not be obscured but that not the case. Wanted to return the bar but Cooper was uncooperative to the point of being shady.
