Just did 3 days of track - need brake advice!
I have an '06 MN6 F55 coupe and I've installed Z51 sways and tires...just ran my first 3 day event at a fast track, went through my stock pads in ~1-1/2 hours, had no choice but to get another set of stockers, they lasted about 2 hours! Looking for options/suggestions....thx!
I have used Hawk pads and Carbotechs as well as a couple of others not worth mentioning. Both of the aforementioned are good, but I prefer the Carbotechs. Currently I use the XP 10s in the back and XP11s in the front. They handle the abuse well for about 4 track days.
You may want a less agressive pad unless you are going to the track often and driving hard.
PS. A note to sponsors, particularly Carbotech:
I learned of these pads from Chris W. Ingle - 2005, 2003 Southeast Division T1 National Champ in car #7. You are getting your moneys worth from Chris. I tried these pad and liked them. I just ordered two more XP11s and one set of XP10s this past Monday.
I had good luck with Performance Friction 01 compound pads on my '06 Z51 ... PFC01 front, PFC Z compound rears. I still managed to melt my piston dust boots even with DRM ducts but didn't have any issues with fade. Ran Motul 600 for brake fluid... six 20 minute sessions in >95F heat.
http://www.petting-zoo.net/photos/Brakes-2006-07-03/
Originally Posted by 63Corvette
A) Cooling
B) PFC-01 pads
C) Did I mention cooling
B) PFC-01 pads
Set the active handling to Competition Mode.
Use Carbotech pads
Cooling is beneficial *all* the time. No cooling leads to pad fade and boiled fluid which leads to no brakes and bad things.
Don't late brake so much
If you're new to this, I bet there are a lot of areas that you were braking but didn't have to. Let the car do the work.
Seat time, seat time, seat time.
Use Carbotech pads
Use Carbotech pads
Use Carbotech pads
But how to you quantify how hard you run at the track with regards to needing cooling or not?
Meaning how fast do you run? and is there a point at which it does make a difference (for example, T1 type lap times)?
DOT 4 brake fluid - Super blue / Gold, Motul 600 or Castrol SRF
Race pads- Most popular ( NO order ) PFC-01s, PFC-03s, Hawk, DTC-70s, Hawk Blue, Hawk Black, Carbotech XP12, XP11, or Wilwood H
There really is not a street and race pad. Two differnt pads and need to be changed.
Cooling, and I found cooling to allow one more weekend out a set of rotors.
Thanks everyone for your input.
So where can I get more info on these and who has the best pricing on the Carbotech pads?
I checked out your link...great pics. One thing I noticed is the tie rod joint wrapped in something...but what is it and are there other solutions? I have roasted both of mine as well as at least 1 lower ball joint boot! They are all history...Does anyone know where you can get just the replacement boots?
It seems cooling is a good thing huh? Where can I get info on the PFC-01 pads?
Did that....and it saved our butts at least one time....big time!
Will look into these
My instuctor also told me the 3 most important things in good braking are, cooling, cooling & cooling!
You're right, being new I'm sure I probably used them way too much, but I'm certainly going to do other events and got to address my brake needs, having serious fade was no fun!
A) Cooling
B) PFC-01 pads
B) PFC-01 pads
Use Carbotech pads
NOT!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
All those CYA modes burn up brake pads. Turn everything off and learn to drive the car. Those modes are teaching you some very bad habits...and burning up your pads.
Carbotechs just can't be beat! They rock!!
Originally Posted by wtknght1
...All those CYA modes burn up brake pads. Turn everything off and learn to drive the car. Those modes are teaching you some very bad habits...and burning up your pads...
How about shields for the rubber boots on the tie rods and ball joints.....anything available?
Originally Posted by Miaugi
You are right I'm sure, but in my moment of "no brakes" I was sure glad to have it on as it got me around a corner that without it I would've eaten a tire wall!
As far as the rubber boots, just grab some 1" or 1 1/4" header wrap from Summit or someone and use that to shield the tie rod ends. I zip-tied some on there and it's worked wonderfully.
[QUOTE=wtknght1]
I agree if the person has experience. However if it's someone that's brand new, has been using AH and is burning thru equipment at an alarming rate I prefer to ween them off the bottle rather than go cold turkey In the original post it was unclear the experience level of the driver
Set the active handling to Competition Mode./QUOTE]
As for brake pads, can anyone give an idea of pricing on some popular options? So far the stock rotors don't look bad, but I'm sure with a more agressive pad that will change.
My last time out I was running the POC Short Track Series. The air temp broke 100 at 10 AM and it was between 105 to 110 degrees in the afternoon at Willow Springs Raceway. Track surface temps were reported at 140-150 degrees. I won the EX class that day and had the 5th fastest overall lap time of about 70 drivers.
I have also run of course in much more moderate temperatures. I am only raising the question that we should question the effectiveness of the cooling duct systems on the Z06, plus the aftermarket add-ons. I am not so certain they do much at all. If someone has validly derived analytical information, I would like to see it.
[QUOTE=96GS#007]
Just so everyone knows, I've been driving for 33 years, safely, no points/tickets/accidents for 8+years @ about 30K miles per year of city & highway and that includes 4 years of Corvette driving where I'm not shy about sometimes adding a little excitement!
However besides going to the drags ~10 - 12 days and doing ~6 autocross events (both slow & fast track layouts) this was my first road track HDPE event, ran green for 2 days, went to yellow on day 3.
Would like to continue for at least a few more HDPE's to improve my skills but need to get better stopping power.
Originally Posted by 02impactblue
Are you running the stock z51 drilled rotors? Any problems with cracking rotors with the pfc's
