C5 or C6 T1 bars?
Looking at the pictures, they would fit either car. It looks like the rear bar does not go straight across from bushing to bushing, but has the neccessary bends to clear the C5 mufflers. It now may even fit the C6 ZO6.
Mark
Mark
St. Jude Donor '05-'08
those are the new style T1 bars because they have the 3 holes on the rear bar. They were made to fit both the C5 and the C6. Most shops are not sure which hole to use so they are using the middle one on most applications.
I do agree that you have a set that looks like the rear bar is bent enough to fit around the C5 exhaust. GM made a mistake with some and made them straight in the back so C5 owners were SOL.
#25534433, according to Fred Beans online catalog, comes up as "Shaft".
Do you know what Chevy part number you actually have? Bonus if we can now clear the C6 exhaust with these bars, last I heard there was interference with the stock mufflers.
Got LAPS?
St. Jude Donor '06
Another forum member sent me this link to the other forum, now I wonder if I have the new version or not.
I also wonder if there is any way I can tell without attempting to mount them?
St. Jude Donor '07
Would take you about 45 seconds to crawl under the car with it to hold it up and see if it will fit.
Got LAPS?
St. Jude Donor '06
Originally Posted by MattW_VA
I've installed a set on my C6 recently and that rear bar sure looks like it would clear, mine was much straighter. Hard to say for sure with your pics though.
let me guess.... CPA60 SOLD you these bars?....
Those are for a C6....
I posted on his tread saying that the bars will not fit a C5.....
the front Bar will fit, but the rear will NOT (you mufflers will be in the way)
I confronted CPA60, but he insisted that bars he was selling are for a C5.. Check the tread.....
You should ask for your $ back.
SORRY MUK, I DID NOT SEE YOUR POST, IVE ALREADY ADVISED & SPOKE WITH JIM REGARDING THIS ISSUE PRIOR TO HIM RECEIVING THE BARS.
JIM, I PM'ED YOU TUES AFTERNOON, BUT DIDN'T GET A RESPONSE BACK, I SEE NOW YOU HAVE OBVIOUSLY RECEIVED THE BARS
IM STILL GETTING MIXED INFO ON THE BARS FITTING OR NOT, SO LET ME KNOW WHAT YOU FIND OUT AND IF THEY ARE FOR A C6 ONLY I'LL CERTAINLY SEND YOUR $ BACK AS WE DISCUSSED AND ILL REVISE THE ORIGINAL THREAD & SELL TO A C6er
LATER!
JIMMY
LATER!
JIMMY
Location: If you don't weigh in you don't wrestle Road America
I got stung on this from my Chevy dealer a few months ago, hell I even got the bar powdercoated before I found out it wouldn't fit. I have a picture of the wrong bar and the stock bar right next to eachother, I'll try to post it.
Anyway Jim I think you will be fine at first I saw the three holes and thought you were screwed, but then I noticed an extra bends to the bar I think you will be fine. Just try holding them next to eachother.
MUKAKsC5
Thanks again for the front bar (It kind of looks smaller in black, I guess that's why they say black is slimming )
MUKAKsC5
Got LAPS?
St. Jude Donor '06
Got LAPS?
St. Jude Donor '06
LATER!
JIMMY
LATER!
JIMMY
Thanks again, you are a stand up guy,
Jim
If you want the T1 anti-roll bars front and rear, bushings and the adjustable metal endlinks it is part#
# PKT1STABKIT
http://www.gmpartsdirect.com/results...er=PKT1STABKIT
FYI all the parts
12480062 T1 Suspension Package 1999/2000
This package inlcudes the following items:
# PKT1STABKIT
FYI all the parts
- 12480063 Spring - Front 1999/2000
- 12480064 Spring - Rear 1999/2000
- 12480065 Bar - Anti-Roll Front 1999/2000
- 12480066 Bar - Anti-Roll Rear 1999/2000
- 12480067 Link - Anti-Roll Bar 1999/2000
- 12480068 Isolator - Front Anti-Roll Bar 1999/2000
- 12480069 Isolator - Rear Anti-Roll Bar 1999/2000
- 12480072 Arm - Front Upper LH 1999/2000
- 12480073 Arm - Front Upper RH 1999/2000
- 12480077 Arm - Front Lower LH 1999/2000
- 12480078 Arm - Front Lower RH 1999/2000
Based on the latest part numbers posted, the swaybars there are also listed as "Shaft" in the catalog... guess shaft == anti-sway bar...
GM PART # 12480065
DESCRIPTION: SHAFT T1 Front Bar
Originally Posted by Wicked Weasel
GM PART # 12480065
If I'm following this thread correctly, that's the old part number... the one in the picture (and that I quoted above) is the new one. I think.
that is possible. I got it from GM direct for the C5. I guess since that bar is not really made anymore they have changed the number although GM is usually pretty good about updating the web page with this part# has been replaced with this part#
