Caliper Replacement
St. Jude Donor '05-'08
Caliper Replacement
We replace pads, rotors, fluid, but what about the caliper?
I figure this abuse will eventually have a toll on the entire package. How can I tell when the caliper is getting to the point that it needs replacement?
Other than piston seals going bad, the typical caliper failure mode is for them to "spread". In other words, the two pads are no longer parallel to each other and to the rotor surface. This is usually evidenced by taper in the pads in a radial direction, the top of the pad (near the edge of the rotor) is thicker than the bottom.
When the caliper spreads it is junk. Nothing to do but replace it. T-1 racers see this at times, but I have never seen a caliper fail in this fashion from just HPDE use.
Hope this helps.
Frank Gonzalez
Is there a difference between the C5 caliper and the C5 Z06 caliper (excluding the pretty red color )
Frank Gonzalez
Yeah, we see the pad taper issue quite a bit. I replace my front calipers twice, sometimes 3 times per year...and always just before the runoffs. I never had to do this doing DE stuff, but we really pound on these suckers hard for full racing. They are relatively cheap though and easy to replace. I'd recommend doing it once a year for anyone though and keep an old one or two as a spare.
Location: Making my carbon footprint as BIG as possible
Cruise-In III Veteran
Cruise-In IV Veteran
St. Jude '03-'04-'05-'06
Bob....
I'm in the process of changing my calipers today.....got 4 new Z06 calipers from Fred Beans for $350 + shipping.
Got my Motive bleeder this morning....gonna try it out tonight.
Running NHIS Monday....if you want to come up. John will be there, as well as a bunch of other vettes...
Originally Posted by gkmccready
I hope you bought the GM adapter cap; it was a PITA with the generic cap and the J-hooks. :-(
They make one specific for GM now. That is what I used and it was easy...
Under HPDE use, mine lasted 4 years, and started to taper pretty bad toward the end. I went through pads more often and decided it was time to change. At that point, I figured that I would just get the wilwoods and be done with it. Very happy I did. Pads are SOO much thicker, much easier to change, and I have notice an improvement in braking especially once the brakes get very hot. They remain more consistent
Bob....
1 Post
Cruise-In II Veteran
Originally Posted by Sidney004
PFC calipers? Post some pics. What are these monoblock NASCAR calipers for $5000? What type of rotors?
Originally Posted by ghoffman
Nope, PFC ZR33 calipers (about $1350 each) , Hardbar rotors (about $750/pair, C6ZO6 14 inch size).
Originally Posted by 95jersey
How do you think these would compare to the Wilwoods? Just about the same price.
I still think the Wilwoods are head and shoulders above the stock Z06 caliper. Then throw in the cost of race pads for the new Z calipers you really have a reason to dump the stock Z set up for something better.
1 Post
Yesterday, the performance of this system was fantastic at NHIS which is a heavy braking track. On one pass into turn one, I got a very late point by (with another forum member in the passenger seat) and I was thinking "Oh my god, I hope we make it" and we did, no problem. I felt like Jeff Gordon when he drove the Williams F1 car in that I kept thinking I was going to blow it, but it just stopped and I was thinking I could have gone even deeper.
I ran it all day with the fixed rotors (the black ones in the pic above, the floaters had an issue) and it was fantastic, no fade at all with the 97 compound pads on a very hot day. The track temp was almost 130 and in the sun it was 102. The rotors look great and the pad wear is minimal. The rotors were literally glowing bright red observers told me later.
At the end of the day I was very tired after 4 sessions each with 2 students plus my sessions. I had promised my friend Jim (he is a GT-2 driver) and Brian Cunningham (another forum member) a few laps in the car. I did a couple of laps with Brian, let him out, and was planning on only doing a couple with Jim but I saw a yellow Porsche GT-3 a hundred yards or so ahead of me and I just could not let that go so I stayed out and got him a few laps later. Overall, a really good day!
