Auto-X numbers....?
Old 07-03-2006, 10:01 PM
natejohn
natejohn's Avatar
Default Auto-X numbers....?
Looking for a source for vinyl racing numbers. The kind you can squeegie on and use over again.
Preferably the number (83) on a single sheet. Two of course - for each side.
Old 07-03-2006, 10:45 PM
gkmccready
gkmccready's Avatar
http://www.solotime.com/
I just put them on the hatch sides, and the passenger side front this past weekend. They're pretty sticky so I'm not sure about sticking them on the doors, but I'm sure some folks do.
Note that these aren't whatever type you're refering to wrt squeegys... these are "low tack vinyl."
c4cruiser
c4cruiser's Avatar
Try www.solotime.com They have a wide variety of numbers/letters and graphics in both static cling and reusable adhesive.
Old 07-04-2006, 05:19 PM
Webz
Webz's Avatar
Great looking, tacki backing, thick vinyl
http://www.izoomgraphics.com/
Old 07-04-2006, 11:50 PM
xilr8n
xilr8n's Avatar
Here are mine from them. (come as three seperate so I can mix and match)
Old 07-05-2006, 12:31 AM
CoolBlueC6
CoolBlueC6's Avatar
I have a vinyl cutter and make my own. I use a removable vinyl as a base (which is white), then I apply my numbers. Mine is an oval in red with reverse out numbers filled in with a very metallic silver.
The removable vinyl is reusable to an extent, but will lose tackiness after a few uses.
My car is super waxed with about 6 coats of sealants and pure carnuaba. The vinyl is applied directly to the doors. No issues with damage to paint.
I have done numbers for several people in my auto-x region. Thought about doing it as a part time business, but I am such a perfectionest that I spend too much time making unique designs. Not sure if it would justify being a supporting vender here or not.
To Auto-X numbers....?
Quick Reply: Auto-X numbers....?
