Mallett wheels/Ecsta 710
Old 06-28-2006, 09:59 PM
Quacker
Quacker's Avatar
Default Mallett wheels/Ecsta 710
Hi Guys
I picked up a set of Mallett wheels
9.5x18 with 48mm offset front
11x18 with 59mm offset rear
Will I be able to run Kumho Ecsta V710 tires
285x30x18 on the front and
315x35x18 on the rear without any clearence issues?
I am running with a lowered C5 suspension but I seem to remember someone doing this and they had a rubbing issue on the rear or it might have been a bigger tire, I just can not remember.
Old 06-29-2006, 09:52 AM
Kschwamy
Kschwamy's Avatar
Originally Posted by Quacker
Hi Guys
I have run that same setup on my wifes 98 without any issues.
Old 06-29-2006, 11:35 AM
Quacker
Quacker's Avatar
Thanks Kschwamy
Did you have Mallett wheels with this setup.
Old 06-30-2006, 08:17 AM
Kschwamy
Kschwamy's Avatar
Yes I do. They are the one piece 396 wheels. I got them to use on my car but every once in awhile while I throw them on my wifes car if we are out at a test and tune and they work fine. They are the same offset as you listed.
Like I said I have not had any issues with them todate.
Old 06-30-2006, 10:00 PM
Quacker
Quacker's Avatar
Thanks Kschwamy
I have enough tire for next weekend then I'll call Luke and order the new rubber.
Thanks again
Larry
To Mallett wheels/Ecsta 710
Quick Reply: Mallett wheels/Ecsta 710
