63,000 miles, 7 HPDE weekends, lots of auto-x, & hard use.. timing chain/spring swap?
Old 06-27-2006, 11:50 AM
Cobra4B
Cobra4B's Avatar
CI 3-5-6-7-8 Veteran
Default 63,000 miles, 7 HPDE weekends, lots of auto-x, & hard use.. timing chain/spring swap?
Wondering when/if I should service the timing chain and vavle springs on my stock motored '01 (bolt-ons only).
If I'm going to the trouble to do this I mgiht as well put a cam package in the car and an LS2 chain.
What's the concensus?
Oh and I'm pulling my headers to get the air tube hole fixed etc, so it's the perfect time to get a radiator/oil cooler.
Ahhh... it adds up! radiator/cooler and a cam package
Old 06-27-2006, 11:59 AM
RAFTRACER
RAFTRACER's Avatar
Timing chain and new valve springs , very good idea. I've already done this on my own '03 car with only 2600 miles. Ive seen some T1 cars eat timing chains and have catastrophic engine damage..................
Old 06-27-2006, 12:55 PM
95jersey
95jersey's Avatar
Nice time for a cam, if you pull the chain....hmmm.
Old 06-27-2006, 02:44 PM
BBQ
BBQ's Avatar
huh? timing chain job after 2300 miles?
Old 06-27-2006, 03:00 PM
Timz06
Timz06's Avatar
I don't know about the LS1 timing chain, but getting to it on my LT1 is a pretty big job, gotta remove all the stuff in front, balancer front cover etc. On the LT1 you will mess up the seal with the oil pan, so you have to drop the pan to get the new gasket in, major pain.
Valve springs would be easy though. you could change them, but I doubt they are worn with just the few events you have done.
Tim
Old 06-27-2006, 03:13 PM
RAFTRACER
RAFTRACER's Avatar
2600 miles, average throttle angle of those miles 90%, average engine speed 5000 rpm, 7300 rpm rev-limit, max accel and decel all the time
new valve springs, timng chain and new piece of mind..................
Old 06-27-2006, 03:56 PM
VetteDrmr
VetteDrmr's Avatar
Received 1,398 Likes on 749 Posts
What about a bone-stock motor (including PCM)? I've asked this question over and over, but no one has been able to give me any decent data on when to do this work.
It's kinda the old quandry "don't fix what isn't broke" and "why did you wait that long?"
TIA, and have a good one,
Mike
Old 06-27-2006, 04:07 PM
Cobra4B
Cobra4B's Avatar
^ Exactly... I'll proabbaly just wait until it's time for cam and do it all together.
Old 06-27-2006, 04:40 PM
Lancer033
Lancer033's Avatar
It's simple, look far enough into your crystal ball to see if break, then change it the weekend before
Old 06-27-2006, 04:49 PM
VetteDrmr
VetteDrmr's Avatar
The week before:
The week after:
Old 06-27-2006, 05:48 PM
gpm30236
gpm30236's Avatar
Have some recent experience from the teardown of the engine in silver . 83,000 miles. appoximately 50 track days some with 2 drivers / session . always good oil/gas ,
Timing chain somewhat loose.
Valve springs replaced at about 70k 1 broke on easy commute
Replacement valvesprings after overrev Ok
Probably good insurance to replace valve springs yearly if you are doing lots of track days.
Old 06-27-2006, 06:21 PM
John Shiels
John Shiels's Avatar
Location: Buy USA products! Check the label! Employ Americans
My car sees work like that it's on or off. Replaced springs at about 2000 or less then the second set went less than 900 miles. Switched to Comp 921. I rev to 6700 max I have all the cooler so temps are not a factor. Whne they just broke I was lucky it was only one slightly bent valve. Near 1900 bucks. Could have lost the whole motor so I feel lucky. Do it.
Old 06-28-2006, 10:05 PM
0ATI Performance
Former Vendor
ATI Performance's Avatar
Valvetrain failures can be catastrophic, especially on the wallet. Not much remained of this Corvette engine, as valve pieces found their way around the engine via intake manifold, rods got bent, dents in pistons, etc. Pretty much ended up an expensive pile of scrap metal. The valve piece in this picture was hammered into the port by the piston.
Attachment 47594827
And as Murphy would have it, such failures always occur at the worst possible moment. This one happened in 2004 while loading the car in the trailer for the SCCA Solo National Championships, then night before we were supposed to leave.
New valve springs are cheap insurance.
Bob
Old 06-28-2006, 11:01 PM
VetteDrmr
VetteDrmr's Avatar
Bob,
Question: Was that failure due to a spring failure? And, if I'm going to change out my springs (stock engine, 140K+ miles, autocrossed several times a year), do I need to replace anything else (spring retainers are what come to mind).
Mike
Old 06-29-2006, 06:31 AM
0ATI Performance
Former Vendor
On this particular engine, the valve stem broke first. Similar disaster would happen if a spring broke and the piston hit the valve.
If you only autocross several times a year, it may not be a big deal. If your engine spends most of its life above 5000 RPM, and especially if you have a stock engine and tune up the rev limiter to 7000+ RPM, then I'd be changing the springs at least once a year. When changing springs I'd also change the retainers etc. Springs can be changed without removing the heads.
Think of it as buying "engine insurance". Other failures like spun bearings can usually be fixed with a basic rebuild. If you drop a valve, you may find yourself with an expensive boat anchor.
Bob
Old 06-29-2006, 08:27 AM
VetteDrmr
VetteDrmr's Avatar
So, for a stock engine, would you just go with OE springs and retainers? I know that xxx springs from yyy supplier are *the* things to have for a modded engine, but I don't have any intentions of going inside this engine. If I ever have the PCM tuned, one thing I'm planning on keeping is the stock rev limit.
Thanks for the info, and have a good one,
Mike
Old 06-29-2006, 09:32 AM
Maineiac
Maineiac's Avatar
Location: Making my carbon footprint as BIG as possible
Cruise-In III Veteran
Cruise-In IV Veteran
St. Jude '03-'04-'05-'06
Mike
To 63,000 miles, 7 HPDE weekends, lots of auto-x, & hard use.. timing chain/spring swap?
Old 06-29-2006, 10:42 AM
0ATI Performance
Former Vendor
If you don't raise the rev limiter beyond stock, and especially if you don't race much, then stock parts should be fine and save money. Also if you race in a stock class, you can't use different parts.
The primary reason for higher valve spring rates is either higher rpm's or bigger cams. You need enough spring force to close the valves (keeping the lifters against the cam) or else you get "valve float". If it is bad enough the piston could come up and hit the valve before it closes - BAD. Generally though, there is a severe drop in power before this happens so you tend to back off.
Springs over time can degrade and lose their spring rate, decreasing the RPM at which valve float occurs. They can also fatigue and break.
Again on a street car probably no big deal, but if you are going to race and run up against the rev limiter constantly, cheap insurance.
Bob
Old 06-30-2006, 11:01 PM
Dr Chill
Dr Chill's Avatar
Well, last month I lost a timing chain going 120 mph at Sebring. Car had 10,000 miles and medium cam and JWIS timing chain. This is what happened. No better time than the present to upgrade the timing chain or valve springs.
Old 07-01-2006, 12:47 AM
Dirty Howie
Dirty Howie's Avatar
Just asked this question to Tony Mamo (AFR) at the A&A BBQ last weekend.
Answer: every 20K miles for street/track car.
I probably have 30K miles and 14 track days since I did my heads/cam.
I should get this done before ......... :o
DH
Quick Reply: 63,000 miles, 7 HPDE weekends, lots of auto-x, & hard use.. timing chain/spring swap?
