do the ccw corsairs come in a size to fit stock c6 coupe?
Old 06-23-2006, 04:38 PM
RMilla17
RMilla17's Avatar
Default do the ccw corsairs come in a size to fit stock c6 coupe?
what size tires front and rear?
Old 06-24-2006, 07:55 PM
gkmccready
gkmccready's Avatar
CCW will build them however you like 'em... I called them about 18x10+19x11 and 18x10+18x11 ... you can run C6Z sized rubber on the former set... just call or email them.
glen
'06 coupe
Old 06-25-2006, 10:14 PM
Dirty Howie
Dirty Howie's Avatar
Call John at CCW he will answer all your questions and make sure you get the correct setup for your needs/car
DH
Old 06-26-2006, 10:54 AM
0racewheel
Former Vendor
racewheel's Avatar
18x10 front and 18x11 rear, toyo ra1's from a sizing standpoint have one of the better tire packages, 275 35 18 front and 305 35 18 rear
john
Old 06-26-2006, 03:15 PM
gkmccready
gkmccready's Avatar
any reports of active handling issues with the rears 1.7% smaller than stock?
Old 06-26-2006, 06:42 PM
Lancer033
Lancer033's Avatar
rears are still larger than the fronts so that'll be fine - I ran 265/35 - 295/35 all last year without any trouble. Only time you have to worry about AH/TC is when the rear is smaller than the front. Speedometer will be off 1.7%, but that inside the margine of error anyways so you won't know the difference
Old 06-27-2006, 02:05 PM
lloaf
lloaf's Avatar
Anyone know weights of Corsairs ?
Old 06-28-2006, 08:14 AM
TooManyIDs
Support Corvetteforum!
TooManyIDs's Avatar
john
This is the setup I just received.
To do the ccw corsairs come in a size to fit stock c6 coupe?
Quick Reply: do the ccw corsairs come in a size to fit stock c6 coupe?
