5pt harness latch
Old 06-21-2006, 04:16 PM
Jason
Jason's Avatar
CI 4-5-6-7 Veteran
Default 5pt harness latch
Anyone have an up close picture of everything latched? Just want to make sure the only way I see to do it is the correct way.
Old 06-21-2006, 04:30 PM
FasterIsBetter
FasterIsBetter's Avatar
I assume you are talking about the old style pelican hook latch system, not the newer snap latches, which can only go together one way. Assuming your pelican hook is on the lap belt on the right side of your seat, you put the right shoulder harness clip over the tongue, then the submarine/crotch belt clip over the tongue, then the left shoulder harness clip over the tongue, then the left seat belt clip over the tongue, and then lock down the pelican hook. If your pelican hook is on the left lap belt, than start on the left side and reverse the order. Be sure to snug down the lap belts so they are down on your hips before you start taking up slack on the shoulder straps.
Old 06-21-2006, 04:32 PM
Jason
Jason's Avatar
CI 4-5-6-7 Veteran
Found this pic online.
http://www.rv7-a.com/135_3538.jpg
Sounds about like the way I had it figured. Thanks!
To 5pt harness latch
Quick Reply: 5pt harness latch
