Anyone run V710 all around in 315/35/18 size??
I used to run them in the front for a while, with a lowered car, but I didn't like what it did for my ABS running the 335-17 rears........more "ice mode". I think if you ran them all the way around you would be OK. The tires are pretty tall for a front though, if you are low in the front you better additionally be stiff so that you dont hurt your fenders.
V710s
I use V710s in 315/35x18 front & rear on our '04 Z06 and our '99 FRC. Both are lowered in the front to the limit (minus about 1/4 turn for balancing) of the stock spring end-bolts (rear is approx 1/8" higher than the front) and we have no clearance problems. This is using stock '01 Z06 18x10.5 rims.
