Corner weights for auto-X
Florida turtle advocate
I would have to assume that one would want as close to equal wieght on all four wheels with driver(or equivilent weight) aboard and a full tank of gas(on a C4)...Would this be correct? Or am I gonna be wrong as usual when I think I have an answer...
20 gallons at 6 lbs a gallon is 120 lbs you don't need to carry.
Frank Gonzalez
The full tank seems the be the only option on the C4 due to the slosh(weight transfer) and starvation factor.
Unless this is a dedicate race car (scca-prepared or nccc rp) you can not purposely ballast the car to have all corners equal or left to right equal for that matter. When you corner wieght your car you are looking to have your diagnals being 50% of the total wieght. IE; LF+RR=RF+LR. Since wieght always transfers diagnally in a turn , if the diagnals are equal then the car should be balanced. In a non-race car the left side wieght will always be more, there are more neccesities on the left side including the driver.................................. moving the battery to the right rear will help alot on the C4.
1 Post
Cruise-In II Veteran
Not that I would ever disagree with Lord Raftracer of Auto-X anyway!
This is further complicated on a C4 by that lack of a spring adjuster on the front of a stock C4 spring. A Vette Brakes spring or coil-overs would change that but obviously class considerations might prevent that option. On a C5/C6 there are threaded height adjusters on the end of the spring, but not on a C4. I suppose you could shim the spring but that would be a PITA.
So, how much do you run (I actually just started another thread with this question)?
Have a good one,
Mike
More fuel creates more forward bite which helps when on low frictions surfaces (no grip). I thought fuel was a little over 7lbs a gallon anyway?? Wieght is the enemy, but if it helps you put power down which is worse????
If the car is a group 3 car (nccc) you can use the VBP front flat spring with adjusters. group 2 car , this was made illegal last year or the year before based on a "witch hunt" for Don Smith from down in the south. Yes you could shim front spring, and the rear even as stock has some wieght shifting ability. I can scale even group 1 and AS c4's and keep them legal ( and still achieve 50.0% cross )
Location: I tend to be leery of any guy who doesn't own a chainsaw or a handgun.
The suggestions offered by the other members are also definitely worth considering when you have the opportunity to weigh your car and then see what the impact of CW or CCW circuits does to your car. It's a long learning process, and rarely will anybody say they don't keep learning new things as they get more track time. Have fun!!
Originally Posted by RAFTeRACER
Most C-4's begin to sputter in hard cornering around 3/4 of a tank. It's not worth the time lost to save on a few pounds. My car runs best full.
It's defineatly worth someones time to modify the pick-up and save the wieght of all of the extra fuel. Weight is the enemy remember no matter where it is . Lighter is always better ..........
If your car does happen to be black, I think you have some forward mounted wieght that needs to be removed (ie: exhaust manifolds )
The C5/C6 tank and pick-up system is so good it makes you forget past foibles of the brand.
Frank Gonzalez
Frank, note you have quoted the RAFT "e" Racer, the masked marvel........................
C4's stock have severe fuel starvation problems , my dads 86 with the LT4 will do this @ 3/4 -5/8 of a tank if there is enough grip, poor fuel tank/pick-up design that I am sure the Corvette Challenge racers of the late 80's-90's did not deal with ( they would have been in the pits for fuel way to frequently ).
Generally I run my C5 stuff "light" unless I cannot put any power down. The C5's will not fuel starve unless you are damn near empty, happens a little sooner on the roadcourse do to spending longer time a max lateral g's, but still can run very low.
With the tank in the C4 being mounted the way it is it also (if half full) will transfer the weight of the fuel in the corners and cause a very annoying snap oversteer situation.Did the Corvette challenge guys run stock fuel tanks??
Yes, fuel "slosh" is upsetting to the rear of the vehicle. Typically you either want to run full or empty, especially when the tank is mounted aft and high of the rear axle.
I believe the Corvette Challenge car used stock rear tanks, anyone have any insight ?????
I did some digging but couldn't come up with any definitive results. However, considering how they were raced, I would think they would be required to use a fuel cell for safety reasons.
Danny
I have no insight for you, I know a guy here in town that worked on A challenge car team, I will see if i can catch up with him.
I can tell you in mine that I like a full tank, I know the weight is not good but it helps balance the car, and it minimizes the slosh. I think to fix the problem you have to have a pickup that will draw from both sides. The problem is the fuel running away from the pick up.
By the way, what is the deal with this 'MASKED MARVEL', I think he just wants to be like you.
Good running this weekend, it is always a pleasure to lose to you.
Mike
Mike
A fuel cell is starting to look like a good idea.Make the car faster in the name of safety.
St. Jude Donor '06
johnny
