Rear wing design help needed.
http://www.grc.nasa.gov/WWW/K-12/FoilSim/index.html
Foilsim is the one you want.
download and try this applet. You'll want about a 10" wing length, 5-6' wide, and you can experiment with wing camber and thickness.
Probably want chord thickness around 10-15% of chord length. Play around with the program. It gives pressure gradiants, and gives total downforce. It is designed for aircraft, so put in negative angles and camber to make it a car wing.
I fabricated my own wing using a foam core/hot wire technique with a fiberglass overlay. I used a NACA 4415 airfoil with a 12 inch cord and a 4" fixed flap. It is 66" wide. I still have the Hotwire templates that I used to make the wing. If you are interested I could cut the cores for you and you could finish it yourself.
I decided to fab my own wing because I wanted a true airfoil that would have the lowest drag for a given down force. Most of the wings I see in the aftermarket are from the C5R program and are optomised for a coupe. My car is an FRC. It was a lot of work and I could not duplicate it for the price of an aftermarket wing.
I have used the wing on my C5 road race car for about 6 months and the car currently holds the Corvette track record for the West track at Firebird International Raceway, Phoenix, AZ. Send me your email and I will send you some pictures.
Shirl Dickey
Shirl Dickey
Originally Posted by AU N EGL
Shirl Dickey
Shirl Dickey
What spring rates are you using with the wing? A template emailed to me that I could print out and use to cut the hot wire template would work or a hard copy mailed to me would work as well. Is your "4" flap" the end piece that attached to the airfoil that keeps the high pressure side from rolling over to the low pressure side?
Originally Posted by emf
Selig S1223
Dan
Selig S1223
I've been looking at every race car wing for months now and there sure is no concensus on design. Every possible shape is out there. Makes me wonder how much engineering goes into this stuff.
Are not Gurney Lips or Wicker Bills added to wings because the aerodynamic engineering was not perfect?? How many airplane wings do you see with Wicker Bills or Gurney Lips on?? NONE
Basic info: http://aerodyn.org/Annexes/Racing/hlifts.html
Gee, maybe that's why you'd want to use an airfoil that works LESS efficiently with a wickerbill.
Dan -- that profile is very similar to the wing on my car, as well as a few other cars I know. It's worked EXTREMELY well as a whole, although you'll likely want to re-tune front aero.
Yah I guess your right. Perfect aero may not be a good thing.
http://www.mulsannescorner.com/techarticle1.htm
Video at http://www.planetofspeed.com/video/LeMansFlip.mpg
You might want to study some photo's of Lou Gigliotti's wing on his World Challenge C6. Yes it is limited by the rules but was developed and tested by Hardbar and has seen the inside of G.M.'s wind tunnel and we know by the results that it works.
Body parts and windtunnel photos, plus one wind tunnel video
http://www.corvetteracebodies.com/corvetteracebod.htm
