Houston autocross on June 4th
Anyone planning on running the autocross on June 4th at the Gulf Greyhound Park? I'm planning on being there as a first time driver. I also plan on entering the rookie school on the 3rd. I'd like to find someone who has at least a couple of events under their belt to show me the ropes and give me a few tips and pointers.
Thanks! I just registered for the school on the 3rd. I am very excited.
What class will I run in? Super Stock? I was reading in the rules and it looked as if cross-drilled rotors put you in a different class than stock, is that true? If that is the case would you recommend me removing my Baer Eradispeeds and installing solid rotors for the event? I will be on street tires with everything else stock other than a catback exhaust.
Don't bother changing rotors out, get your first autox done before you decide what class you might want to channel your self in. Crossdrilled rotors will bump you a class in most classes in NCCC. We started taking our crossdrilled off to stay in a mostly stock class, while doing that I;ve come across more than a few stories about crossdrilled cracking. One happened to a friend of mine in Denver, T-1 car doing high speed track day. Small crack that started at one of the holes,(and he saw it) He went ahead and ran it anyway. Rotor shattered, locked up front of car at over 100mph, rolled end over end a couple of times. I only put my crossdrilled on after season for street looks. But your probably running this event at relatively slower speed, don't worry, but keep checking those rotors!
Is this a SCCA event? If it is, do you have web site to check it out. I'm free this weekend, maybe some of my buds will like to try this.
Chuck Holden
Governor
San Jacinto Corvette Club, Houston
www.chucky713@aol.com
832-640-7006
Chuck Holden
Governor
832-640-7006
Since it is your first time, I would not sweat the class you will run in. You will get a raw time and a PAX time (click on event results). The PAX time is a handicap system that you can use to compare your times across classes. When you really get into it for the points and year end trophy, then hone in on the class you want to compete in and adjust your car appropriately.
Chuck Holden
Governor
832-640-7006
Chuck Holden
Governor
832-640-7006
First time? You are sandbagging right? (impressive times)
11/SS DERRELL BIRD 02 CHEVROLET CORVETTE
TIMES: 1) 60.903 2) 60.851 3) 60.695 4) 61.454( 1)
Here is the Z06 that runs regularly in Houston:
99/SS DENNY FEIGENSPAN 03 CHEVY VETTE Z06
TIMES: 1) 59.261( 1) 2) 56.388 3) 60.824( 1)
I wasn't there but your last run without the 2 second penalty would have been 59.454.
Hope to see you in July!
