NCCC Roll Bar
Old 05-16-2006, 08:31 AM
0ATI Performance
Former Vendor
ATI Performance's Avatar
Default NCCC Roll Bar
What are the minimum roll bar requirements in NCCC for a modified Z06 Corvette (SCCA SM2 prep level)? I don't have a copy of the rules or am able to find them on-line.
Thanks,
Bob
Old 05-16-2006, 08:58 AM
acrace
acrace's Avatar
Bob:
If you don't get an answer through this forum, look me up at the CenDiv event this weekend. I usually carry around a NCCC rulebook in my documents box; I can lend it to you. I don't know the rules off the top of my head; haven't ever had to worry about it. I'm going to assume that your car is a Group III car, but don't take my word for it.
Al Chan
Old 05-16-2006, 09:02 AM
RAFTRACER
RAFTRACER's Avatar
Bob,
I'll dig out my NCCC rules also, but I believe that your SM2 car would be considered GRP 3 or RP. Which means your car will defineatly be requiring some tubing.
Old 05-16-2006, 09:33 AM
NV MY C5
NV MY C5's Avatar
Senior Member
Cruise-In V Veteran
Default roll bar
I run 3H and only have a roll bar. It has to "extend the full width of the drivers/passengers compartment. Be foward or rear braced with the braces being located a maximum of 6 inches from the top hoop at an angle of at least 30 degrees. Steel tubing must be at least 1.5 inches OD with a wall thickness of .125 or .095 for a 1.75 inch bar." For RP the bar needs to be foward and rear braced. You also need a .125 inch inspection hole. Rule book does not specify DOM or electric weld tubing.
Hope this helps.
Old 05-16-2006, 10:25 AM
69autoXr
69autoXr's Avatar
Bob, I have an electronic copy (pdf) of the NCCC rules I can email you, and anyone else that is interested. I find it convenient to have a copy on my computer at work.
Old 05-16-2006, 10:29 AM
69autoXr
69autoXr's Avatar
Originally Posted by RAFTRACER
Bob,
Very likely RP, coilovers (not sure if the car has them) will bump him to RP, and the lightweight body.
Old 05-16-2006, 10:57 AM
AU N EGL
AU N EGL's Avatar
SCCA Solo Rules are here:
http://www.scca.com/Solo/Index.asp?IdS=0035D2-F9F6E50&x=050|070&~=
Technical Bulletins in the SCCA Garage areas
Old 05-16-2006, 05:46 PM
Kschwamy
Kschwamy's Avatar
Chris can you send me one also. Thanks Kurt
Old 05-17-2006, 07:38 AM
bad-zr1
bad-zr1's Avatar
Chris could you Email me a copy also. Vette68@charter.net
Thanks,
Jim
Old 05-17-2006, 08:34 AM
Gordy M
Gordy M's Avatar
Chris,
Could you also email me a copy
Gordy
gmccann@comcast.net
Old 05-17-2006, 07:52 PM
djvett
djvett's Avatar
Default Rulebook
Chris,
I would like a copy also.
Thanks, Dave
Old 05-18-2006, 08:01 PM
GTB/ZR-1
GTB/ZR-1's Avatar
Originally Posted by djvett
Chris,
Thanks, Dave
Ditto pls:
gtbzr1@yahoo.com
Thx!
Old 05-23-2006, 01:04 AM
97coupechuck
97coupechuck's Avatar
Please send me a copy as well, thanks, Chuck
Old 05-23-2006, 01:05 AM
97coupechuck
Whoops, address is chucky713@aol.com
To NCCC Roll Bar
Quick Reply: NCCC Roll Bar
