HELP ASAP - Hoosier Choice???? - NOW PLEASE
Need HPDE tires. LONGEVITY and COST is the only thing that matters for what's available. I'm only out having fun with 18" R compounds all around, ducts, race pads, etc. 2001 coupe driven hard at Hallett. Again, I'm poor and am wanting longevity.
Hoosier choices:
R3S04 @ $128/tire
R3S05 @ $199/tire
A3S05 @ $199/tire
Tire sizes are 285/30/18. Again, I will give up a lot of performance for longevity. Car has aggressive alignment for a street/track car. Running 1.5 camber front and 1.0 rear with max caster. If I haven't said it before, I want max heat cycles. Your thoughts ASAP please.
Rick
Hoosier choices:
R3S04 @ $128/tire
R3S05 @ $199/tire
A3S05 @ $199/tire
Rick
either R should be fine. the A's are for autocross, they heat up alot faster, and will wear faster. if i recall, the 04 or 05 at the end of the part number is the year they were manufactured in. r3s04's look like a good price.
Hoosier choices:
R3S04 @ $128/tire
R3S05 @ $199/tire
A3S05 @ $199/tire
Rick
Hoosier choices:
R3S04 @ $128/tire
R3S05 @ $199/tire
A3S05 @ $199/tire
Rick
Not sure what you mean by $70/tire? That is not the price listed. I've been paying $75/tire for scrubs.
Maybe I'm hoping for something for "nothing"?
This price and tire is direct from Hoosier and includes shipping at the prices I listed. Your comment concerns me????? I know all about "aged" tires but once again, these are direct from Hoosier, for what it's worth.
Supply is gettinig low, I NEED TO DECIDE.
Originally Posted by wallyman424
what hes sayiing is the 70 dollar difference between the ones manufactured in 05 and the ones manufactured in 04. r3s05 vs r3s04. you just need to decide if the extra year of storage is worth the premium on the new tires. if it were me, and i werent racing competitively, i'd go for the r3s04's.
Rick
Talked to tech support at Hoosier today and he DID NOT recommend the R3S04. We discussed the wear issues related to these tires with their "square" sidewall and need for a very aggressive alignment. I do have a somewhat aggressive alignment with 1.5 front and 1.0 rear but he said that's not enough. I don't think the R3S05's at $200 are a very good deal for me.
I'm scared of the quick wear rate I've read about with these tires. I got lots of heat cycles out of Kumho ECSTA V700 and don't want new tires which will wear out quicker than the scrubs I've been running. I have a decent set of Kumho's on now and a set of RA/1 scrubs in the garage.
At their price I'm leaning towards sticking with scrubs. Just not sure what to do? Do the Hoosiers really wear out as quickly as discussed? I've gotten over 500 track miles out of the Kumho's. I've also put 500 street miles driving to the track and back.
Sounds like Hoosiers wear out in just a couple track days.
I know the Hoosiers are quicker but that is not really an issue for me....
Rick
Rick
imho, if you are looking for longevity and value, i would avoid buying new hoosiers for DE's...if you can find some scrubs for cheap, go for it, but imo, its just not worth it for DE's...
and the hoosier rep was right, you need quite a bit more camber than what you have for the S04's...the S05's are supposed to be better for "camber challenged" cars...i've run both with great results but my car is far from camber challenged
good luck!
