Danica Patrick Weight advantage
St. Jude Donor '05-'08
I know it is last year's news, but do you think that Danica Patrick has a weight advantage?
She is 5'2" at 100lbs.
BTW here is a comment that she made regarding weight
"I don't think (my weight) plays that big a role," she said. "I can't control what size I am and how I'm built. The NBA doesn't lower the hoop for short guys."
Does she realize that being short in the NBA is a DIS-advantage while being light in an IRL car is an AD-vantage
Well, you could take the arguement a bit further. All other things
equal, a female typically has a lower center of gravity than a male.
There is only so far a driver can recline, so it helps if nature places
more of your weight at floor level while seated.
However, females also have a higher percentage of body fat, ergo
less muscle mass than males. Add to this the difference in upper body
strength and so on. I'm sure that someone with more knowledge about
the physiological differences could continue to reel off more points. But
I feel safe in saying that pound for pound, a female is at a disadvantage
in a physical strength/endurance event.
My take is that she has good car control, she is gutsy, she is smart
and she has the Rahal team behind her. That why she is fast. Go
ahead and add some sprung, non-rotating ballast - it won't be fair
but she'll still be fast.
Actually...
Females are at a slight advantage over males as drivers of fast/race cars. Specifically for the reasons you mentioned (lower CG, smaller, fat weighs less than muscle, etc.) and that their circulatory & respiratory systems are made for giving birth - something that allows them to withstand more g-forces without blacking out (which is why tests show them physically to be better suited to fly fighter and test aircraft.)
Lastly, the argument could be made that they use less testosterone in decision making. But that arguably puts them at an equal disadvantage in that they can lack the competitive spirit due to the same hormonal discrepency. Personally I think this one's a wash at about the same level as the fat vs. muscle situation. It can take a LOT of muscle to drive a car so if it's missing, the weight advantage is likely offset by lack of strength and endurance. JMHO anyway.
As far as the whiners are concerned (umfoytmph humph hum), Lessen the advantage - GO ON A DIET!!!
1 Post
Cruise-In II Veteran
Originally Posted by AU N EGL
No advantage, cars have mininum weight they must achive. If the car & driver are under the min weight, then ballest is added to be at that mininum.
Former Vendor
More power to her for being light. She is lucky that the rules are setup for her to do well in. The rules are what they are. Is it huge advantage for her to be light, yes! You don't see many big people in open wheel racing!
She's cute too!
Randy
She's cute too!
Randy
Given that it is a disadvantage in most cases, the fact that she gets a slight advantage in an IRL car, then Go For It! Got to believe that as tired as I get after 25 minutes in a 1050lbs Formula Mazda on Sears Point that conditioning and strength are other factors that provide some offset. If she can beat the guys heads up, I'm all for it.
Randy
Randy
Randy
Randy
Aggressive, good driver, committed to the sport, AND cute & lightweight?!? Sounds like a GR8 combination to me!
If she's kickin' your butt, either move over or lose weight!
(of course that whole move over thing's gonna be doubtful... it is racing after all.)
In go karts, being 100lbs would be an advantage over larger drivers.
With the weight and power of the cars she's driving it probably makes much less difference than any other aspect of set up, suspension, tires, aero, etc...
Dog
Dog
Originally Posted by MattW_VA
It is a little advantage, but it's within the rules so WGAF? It's the teams job to gain advantages that are legal, no?
if HP and car weight are rules then I dont see why they dont change it to HP, car weight and driver weight. Then when someone loses to Danica they will not have an excuse....
1 Post
Well, it is still a matter of setup, teamwork and driver, and of course some luck. If body weight was that important in IRL, then there is no way Tony Stewart should have been champ! He is now called Nascar's Michelin Man.
isnt he like 200 lbs. I guess that is heavy for racing
sorry 170lbs 5'9.
I am looking to see the heaviest racers.....
IRL
Driver Height Weight
- Thiago Medeiros 6`3 178
- Buddy Lazier 6`0 175
- P.J. Chesson 5`8 175
- Jaques Lazier 5`11 170
- Eddie Cheever Jr. 6`0 170
- Marty Roth 6`0 170
- Sam Hornish Jr. 5`11 165
- Richie Hearn 5`7 165
- Ed Carpenter 5`9 165
- Townsend Bell 5`11 165
- Tomas Scheckter 5`11 160
- Jeff Simmons 5`10 160
- Dan Wheldon 5`9 158
- Scott Sharp 5`8 155
- Dario Franchitti 5`9 153
- Scott Dixon 5`10 150
- Buddy Rice 5`8 150
- Roger Yasukawa 5`7 150
- Alex Barron 5`10 150
- Bryan Herta 5`11 150
- Tomas Enge 5`7 150
- Kenny Brack 5`7 148
- Helio Castroneves 5`8 147
- Patrick Carpentier 5`9 147
- Felipe Giaffone 5`8 145
- Tony Kanaan 5`5 145
- Adrian Fernandez 5`8 145
- Jeff Bucknum 5`8 145
- Kosuke Matsuura 5`8 143
- Vitor Meira 5`7 141
- Paul Dana 5`6 140
- Ryan Briscoe 5`7 135
- Marco Andretti 5`6 135
- Jimmy Kite 5`4 125
- Danica Patrick 5`2 100
NASCAR
- Jimmy Spencer 6`0 230
- Dale Jarrett 6`2 215
- Michael Waltrip 6`5 210
- Tony Raines 6`2 210
- Ryan Newman 5`11 207
- Joe Ruttman 6`0 205
- Ken Schrader 5`9 200
- Kyle Petty 6`2 195
- Elliott Sadler 6`2 195
- Jeff Green 5`8 190
- Jeremy Mayfield 6`0 190
- Ron Fellows 6`1 190
- P.J. Jones 5`11 190
- Kevin Lepage 5`10 187
- Bill Elliott 6`1 185
- Joe Nemechek 5`9 185
- Rusty Wallace 6`0 185
- Carl Edwards 6`1 185
- Robby Gordon 5`10 180
- Sterling Marlin 6`0 180
- Kirk Shelmerdine 5`11 180
- Derrike Cope 5`7 180
- Martin Truex, Jr. 5`11 180
- Boris Said 6`0 180
- Jimmie Johnson 5`11 175
- Bobby Labonte 5`9 175
- Greg Biffle 5`10 175
- Carl Long 5`10 175
- Joey McCarthy 6`0 175
- Dave Blaney 5`8 170
- Tony Stewart 5`9 170
- Larry Foyt 5`9 170
- Morgan Shepherd 5`9 170
- Johnny Miller 5`10 170
- Kevin Harvick 5`10 170
- Dale Earnhardt Jr. 6`0 165
- Terry Labonte 5`10 165
- Jamie McMurray 5`8 165
- David Green 5`11 165
- Scott Riggs 5`6 165
- Ted Christopher 5`11 165
- Denny Hamlin NA 165
- Ricky Rudd 5`8 160
- Brian Vickers 5`11 160
- Geoffrey Bodine 5`8 160
- Casey Mears 5`8 158
- Jeff Burton 5`7 155
- Hermie Sadler 5`8 155
- Matt Kenseth 5`9 152
- Kurt Busch 5`11 150
- Jeff Gordon 5`7 150
- Kasey Kahne 5`8 150
- Chad Chaffin 5`10 150
- Brandon Ash 5`11 150
- Scott Pruett 5`8 150
- Mark Martin 5`6 135
St. Jude Donor '07
OK-some of those weights are just laughable. I've stood next to Jimmy Johnson and Tony Stewart before-No chance Johnson weighs and ounce more than 150, the guy is a smurf. Tony Stewart 170? Hahahahahahahahahaha
Kenny Schrader 200! WTF???????
Hell, I bet he's not a sausage biscuit away from a deuce and a quarter.
