Craftsman Aluminum Jack?
my jack seems to have a bit of failure. when you go to use the jack it does nothing until you reach the last 10% of lowering the arm. any suggestion on how to fix it? or is rip!
I am on my second one from Sears - first one the cylinder failed. Sounds like what you have. They replaced it - second one has been working fine for about a year now.
There is a bleeding procedure to use also in the owners manual. Try that
If you store it on it's side, like throwing it in the back of your vehicle, and the valve isn't closed the oil will leak out and/or air will get into it. Easy fix. Add more jack oil and bleed it per the directions (pump with the valve open and then close it).
Good luck.
Good luck.
RTFM or some other nice acronynm and insure it is sufficiently full of JACK oil and then bleed it.
Steve
Edit: Opps, I forgot the smiley face : ,)
Steve
so i added some oil and bleed it. seems to work but is not as strong as before. takes more strokes to raise up!
