Square Setup on a C5 for Autocross?
Based on my experience and driving style I had always felt that my F45 suspension had a little too much push.
I added Z06 sways, and although I understand that this theroretically added more understeer, I did not feel there was a significant difference here. The bars did make for significantly better cornering though.
Suprisingly (at least to me) was that lowering the rear of the car by approximately 3/8" made a bigger impact on this. I would not say that the car is as neutral as I would like it to be, but I felt that it improved.
My thought was to move to a square setup to decrease understeer. Is this far too radical for a C5? Would 275mm x 4 cause the rear to be far too loose? Should I consider 285 x 2 and 265 x 2 instead.
Any thoughts would be appreciated.
Craig
Craig
If your racing in autocross, you have to decide what class your going to run in for starters. Alignment would be the next change I would make. How aggressive do you want it to be? Go for a bigger rear sway-bar. Smaller front. Try different air pressures.
Where does the car understeer? Entry,Mid or Exit. Adjust your driving style. These are some of things I would look into. There's nothing wrong with a square setup either.
Steve
Steve
You left out a lot of information for us to help. What group are you running with (SCCA,NCCC,NASA.DCSCC, etc.) stock class or a prepared class, street tires or sticky tires, upgrades permitted, and others. Horsepower mods make another difference.
