disconnect and remove abs
Since I never had the ABS working on my car, I want to remove the front sensors and modulator unit in the rear. I'm fabricating improved brake cooling spindle duct plates that will perform better with the sensors removed.
1. Does anyone see a related problem to other systems if I remove both including the ABS wiring harness at the modulator?
2. Can anyone confirm the ABS unit port sizes? They look like 11 mm x 1.5 pitch.
Originally Posted by larryfs
My car has the ABS and traction control built into one unit.
