metric and standard (fractional) sockets and wrenches
1 Post
St. Jude Donor '10
does the c5 have any bolts that are standard (i.e. 9/16) or is everything metric sized?
I do not want to bring anything more to the track that I do not really need.
Does the c5 have any special tools other than a torx T55 socket?
Received 8,915 Likes
Everything I know of is metric although I use a 5/8" on either the front or rear brake guide pin bolts. I am not sure if 5/8 crosses directly over to a metric size like 3/4 does to 19 mm but I do not have a complete set of metric sizes. Most of the sets skip a few of the less used sizes and some times an english size will come to the rescue. You will probably need an 18 mm combo wrench as well as a 22 mm socket.
Bill
Bill
1 Post
Cruise-In II Veteran
Everything is metric on C5's and up. C4's are a mix of both. You will need a set of Torx bits as well, there are many Torx head fasteners from small sizes on the fenders headlights, etc to T-47 for the seat belts, T-55 for the wheel bearings.
18mm is one that you might want to be sure is in your track kit. Some tool kits don't have it. The bolts on the C5 rear spring use a 18mm and I'm sure there are a few other places.
34mm big socket is required if you ever need to remove the large nuts on the rear hub. I think I got an impact version of that one on ebay. You will not find it many other places. Sears does not carry it, at least in the stores and none of the autoparts places have it either for sale. You might be able to get it as a loaner tool from advanced or autozone I think.
