Anyone own a Trailblazer SS?? May be buying one for towing and commute.
Well really it's because I always liked the typhoon as they used to launch great.
May be able to get a fully loaded AWD with every option for $35k.
They tow up to 6,500 lbs and haul *** normally .
Any feedback or thoughts??
Will be towing vette on aluminum trailer with it to events.
6500 lbs is not enough.
Need to take 3/4 of the towing capsity min.for a safe tow. Also with those big 18 wheels pass you, you will be doing the wiggle dance with truck and trailer. i.e truck goes one way trailer goes the other way.
3/4 ton min. even with open trailer. Suburban or Tahoe 2500.
I know a few guys with Dorango v8s and by they wish they had something bigger.
I have a Durango and no problems with the tow to Road America. About 400 miles one way and a 16' w/ 2' dovetail flatbed and hardly new it was there. Now it does have a HEMI though.
Good luck with the search.
Tim
Tim
Originally Posted by Z06 Silver Bullet
Problem is I definetly don't want a pickup or a giant suv.
Figure only 8-10 weekends a year racing then all the rest of miles and driving is commute or fun.
Today, the only options to tow are Suburbans, Tahoes, and pick ups. Anything else is risky, because every liability lawyer has the companies rating their vehicles at 3500 or 5000 lbs max towing.
I've got no problems with my F150 towing a 20' open trailer - about 5500 pounds loaded I figure. Sure, bigger would be better, but I don't have too long of a tow and no mountains to deal with. They do look cool - I know one guy on the board - nitroc5 I think - on the southeast forum has/had one.
I used to tow a 24 ft enclosed Wells Cargo with a short wheelbase 3/4 Chevy van. The distance from ball to axle was very little, and sway was non-existent unless loaded really wrong.
This is the real reason a fifth wheel is so stable, the distance from axle to ball (or pin) is nearly zero.
I have a 1st gen 4.7L V8 Durango that is rated to tow 7500 or so max. I tow a 2000lb steel trailer + car, tires, etc. and it works great. With an SS with MORE HP and an aluminum trailer you should be fine. I would recommend a load distributing hitch. Worst case you can do an add-a-leaf (if that has leaf springs) or air bags to aid in load leveling. Everyone tries to say you need an F350 dually to tow but you really don't. You need HP to move it and suspension to hold it up. Trailer brakes should slow it down enough.
If you find that the SS is a bit of a wiggle worm, examine your car on trailer placement. More or less tongue weight will effect your stability.
(I've found that more tongue weight = more stability, but then again, I'm towing with a short bed big block truck )
Also, there are sway system stabilizers that can be installed too as previously mentioned.
I'd say go for what you like if you're not seriously trailering consistently.
The SS is a bad hauler. I had actually thought about hauling with one of those when the SS first arrived at the dealership. If you get one loaded pretty well minus the DVD based Nav system I think you come in at a hair over $39K. Nav will set you close to $42K give or take a grand. If you get the employee price obviously it is a bit better. People haul with reg and EXT trailblazers all the time and they both are a bit more underpowered or heavier than the SS. If you have a reasonable trailer and a nice load bar setup I dont see why you should have any problem with it. For the love of pete its an suv with an LS2! I was very impressed and I will check all the capacities tommorow at work but I dont see why you would any trouble. If you are anywhere near SE Michigan I have a couple on the lot now. (sorry for the shameless plug)
You're talking closer to $42k for a loaded SS...
Still, for what you are hauling it will likely work just fine...
Figure that with an aluminum trailer and a Z, you are looking at 4,000 pounds, and maybe another 500 lbs for the other stuff, so maybe 4500 pounds max. That is about 75% of the rated capacity. You might want a sway control slider damper, but other than that you are good to go..
I was thinking the same thing, for the few events that I want to tow, maybe 8 or 10 times a year, I isn't really worth the day to day hassle of a big smudge pot... I know, all of the guys driving Topkicks are going to say you are crazy, not everybody is towing a 24 foot enclosed trailer with a workshop inside to a weekend solo event...
Besides, the SS has that "Extra margin of highway passing safety" that makes it enjoyable as a commuter car...
I considered an F250 diesel, but didn't want to use it as a daily driver. Settled on an F150 5.4L V8 with towing package. Lariat, 2wd. Great daily driver, very adequate towing my 18' open trailer, 4 adults and 1 kid, all luggage for the weekend, and the bed full of tools/spares/wheels.
No complaints for about $28k - list was over $35k.
Originally Posted by Solofast
Figure that with an aluminum trailer and a Z, you are looking at 4,000 pounds..... :
Yeah almost all of the new aluminum trailers are around that now.
I figure if it can tow 6,500lbs than 4,000 lbs should be no big deal on the open roads I would drive on to say Road Atlanta, Roebling, and VIR from Charlotte.
The sticker is near $40k but you can get them for $35k no problem.
See the big issue is I want my cake and to eat it to.
My tow rig needs to double as a fast as hell 12 second street truck also.
Dont worry I think the capacity of an SS is around 7000 lbs give or take 500#. I also have an awesome tech who said 12 seconds in the SS is very attainable. You bring the cash and I got the truck and the mechanic! Even got one in silver! Just remember its only paper and ink if you dont spend it someone else will!
Former Vendor
BACK FROM THE DEAD
I drove an 08 TB SS today, 48k miles, very good condition, never towed anything, good price. It was pretty cool overall, I will two 5k at the very most with it if I get one.
If I do it will have air bags, stabilizer/sway bar on the trailer, etc...so not asking about using it to tow, just it any known reliability issues. long term issues
Fun stuff like tuning it, I have EFI Live, might help on the fun factor or fuel mileage which is not great.
My other option is a 4runner V8, costs more, super reliable, high resale so have to shop hard to get a good one for a decent price. My wife likes it better and she is a lifelong GM fan. Adequate power and not easy to add more but it is a real off road truck if I want to hit the deserts on our travels.
I like them both, the hot rod part of me likes the SS a great deal I must admit
Let me know if you have any experience, stories, someplace to search for such info, etc...
Thanks and have a great rest of the holiday
Rick
Rick
C2 of Year Finalist (track prepared) 2019
2017 C2 of the Year Finalist
I towed a 1200pound alum trailer and 3000 Corvette with a I6 Trailblazer, without issues (except I really needed more HP)
there is no trailer brake plug under the dash, and the OEM hitch is a 2.5, not a class 3
Had one. Great power. 4.10 gears made it very quick. Only ever got about 13 MPG. Probably fine for towing a very light trailer.
Traded mine for a crew cab diesel Silverado. Still get 13 mpg. (Of course thats pulling an enclosed 24' trailer with lots of gear.)
