Any tips to minimize noise from VBP urethane control arm bushings?
I've had these on a vette in the past and they were *really* noisy. I can deal with it if I have to but if anyone has some tips on grease that will last and keep the noise away I'd love to hear em =)
Even waterproof grease will eventually work it's way out and they will make noise. I sometimes spray this Cheetah synthetic penetrating grease that the dealer gave me, but you have to "keep up" with it.
Why is it noisy? The bushing has the bronze guide glued in the bushing, and this rotates over the steel bolt. The bushing should also be fixed in the control arm and not move at all. Is this correct? If it is, how can the polyurethane be causing squeeking? Could it be solely from the ends of the bushings? I'm thinking that maybe you, and others as well, have installed the bushings so they stick out to far, get stuck up on the subframe bracket, and ends up rotating within the control arm.
