What do I need to know going to comp/R tires?
Ok guys, with a few seasons of street tires under my belt, I'm ready to make the jump.
I've got a hitch, workign on a trailer, tracking down some scrubs etc. etc.
What else do I need to do know about the transistion?
Current setup is
- Wilwood 6slr in front, w/ cooling and H pads, stock rears
- Z06 springs/sways and Bilstein shocks (sport version but std valving)
- lowered a little
- 17" / 18" although if I can't find some 17" tires I may have to track down another set of Z06 18" so maybe 18" all around
- -1.5*/-1.0*, -8* caster, out in front, in in rear (I forget how much I don't have the sheet with me).
and a bunch of other stuff that doesn't impact ride/handling...
Will I NEED to increase camber? Will I likely need to raise the car to avoid rubbing?
Thanks for any pointers!!
Current setup is
- lowered a little
You will most likely need more neg camber no matter what you are doing. The racing rubber will give you the CAPABILITY of going faster...but it's up to you to use the new capabilities.
Build up your speed slowly and adjust the pressures and such to suit your driving style and handling. The racing rubber probably won't feed back info (squeal, etc) like the street tires so you'll have to go by feel...probably more than sound. That can take some time getting used to.
Most racing rubber does better if you don't slide the crap out of the car. You can drive it that way, but they will most likely begin to get greasy if you do. Use small slip angles at first and get used to the new feel.
Before I'd do anything though, I'd get it to a pro shop to set your car up properly - cornerweighting, ride height, etc. That's really the only way to get the best out of the new rubber.
I plan on stopping by LG (10 mins from my house) for some ideas/pointers too.
Thanks!!
Originally Posted by jmautox
more camber will let the tires last longer, which is always nice since race tires are $$$$
If W2W a new set of tires per race for maximum grip.
also depends on what tires you go with. Goodyears GSCS are consistant but take a little longer to warm up. Hoosiers will fall off dramatically when they are done vs. the Goodyears which more gradually loose grip. I just did my 1st track event on Kuhmo V710's and they seem like they have a lot of grip. Also are you running 17/18 wheels 18/18, or 17/17?
Originally Posted by joemoia
If you ran in comp mode with street tires, turn AH/TCS off. With an aggressive track alignment and R compound tires AH becomes way too intrusive.
Also, how long do these typically last? I'm a DE'er, not a W2W'er so a weekend normally consists of seven 25 minute sessions. Can I expect a set of tires to last a few weekends?
Thanks again!
I have run Wilwood C type in the front and Hawk HP+ in the rear the last two events and have gotten very good balance. The Cs are less aggressive than the Hs. The HP+ have a higher bite than the Cs so it helps even out the f/r balance.
You should be able to pull much more braking with the race tires make sure your brake balance is not too much to the front or you may have problems.
I have Nitto R2's on Z06 size rims and I keep them on the car full time (it is not a DD). I get about 5 trackdays out of them.
We'll find out
