LUGNUTS: Where / What to buy????
Location: Making my carbon footprint as BIG as possible
Cruise-In III Veteran
Cruise-In IV Veteran
St. Jude '03-'04-'05-'06
Is everyone running stock lugnuts, or some aftermarket brand??? I lost a wheel stud/ lugnut last fall, and now have a mismatched set on there. Any recommendations, any specific brands?
Thanks.
Thanks.
I bought a bunch at the local tire store and use them. I got the open ended ones so that stuff couldn't get trapped in them and possibly prevent good contact with the lug threads. Some guys get them at the NAPA store.
Make sure that the lugs have the correct 60 degree taper and that they are the "Bulged" style. Torque them to the proper setting (the studs should be dry - no lube!!) in a star pattern and re-check after 23-30 miles of driving.
Originally Posted by AU N EGL
NAPA ARP hardened open ended lug nuts $1.10 or so each
I am on my second set of ARPs on a new set of hubs.
The item # on the invoice from ARP says 100-7708.
The description is 12mm x 1.50 Late Model GM WSK at $14.77 for a 5-pack of chrome moly studs.
These are longer than the stock studs. They have shorter ones, too.
ARP does not sell lug nuts.
SLP Lug nut package
Here's a good deal from SLP. I'm sure they have tons of them from their old FBody program.
http://www.slponline.com/view_produ...555&BIG=82555-1
Depending on the number of tire changes per year, you should change them regularly.
Works out to about $1.50 each and they are GM OEM.
Steve
Steve
