Post your Race Parts 4 Sale HERE
Old 03-22-2006, 08:59 PM
ERND IT
ERND IT's Avatar
CI-3 Car Show Winner
CI-4 Car Show Winner
Cruise-In II Veteran
Cruise-In III Veteran
Cruise-In IV Veteran
Cruise-In V Veteran
St. Jude Donor '06-'09
Default Post your Race Parts 4 Sale HERE
Feel free to post your Race Parts for Sale here AND , as usual, in the "parts for sale" section you would normally use for your generation...(cross reference)
Questions? PM me...
BTW - if you are unfamiliar with Forum FOR SALE guidelines - you can re-read them here...
http://forums.corvetteforum.com/show...6&forum_id=109
http://forums.corvetteforum.com/show...8&forum_id=109
ERND IT is offline
Old 03-26-2006, 01:05 PM
95jersey
95jersey's Avatar
Out of date harness for sale (RCI), works well and looks great, just past it's date. THey are normally $150, I'll take $30 and you can get them rewebbed for cheap and still save $75. PM me
95jersey is offline
Old 03-26-2006, 06:40 PM
Falcon
Falcon's Avatar
I need a transponder, anyone got one for sale?
Falcon is offline
Old 03-30-2006, 11:49 AM
ZR1 MK
ZR1 MK's Avatar
Hawk HB101 pads (Wilwood Super Lite and other similar calipers)
HP Plus with 25 street miles $55
HPS with approx 500 street miles $50
ZR1 MK is offline
Old 03-30-2006, 01:33 PM
Bink
Bink's Avatar
Cruise-In V Veteran
St. Jude Donor '09
SOLD!!!!
DRM C5 Master Cylinder.
From DRM site -"DRM C5/C6 Modified Master Cylinder
This is a must for all enthusiasts with an upgraded brake system and it works good with any brake package, our AP setup, Willwood, Etc. For use with street or race setup. With this Modified Master Cylinder you'll get a bigger Master Cylinder that means that there is more brake fluid flow and a upgraded brake pedal feel. With this Master Cylinder the proportioning valve is added so you can control how much rear braking you want. That comes in handy at the racetrack. The DRM Modified Master Cylinder fits under stock location designed to clear the stock hood. If you are looking for maximum in braking performance this is the ticket."
http://www.dougrippie.com/drm/brake_...re%20Regulator
Bought it (used) last year from dmtnt -I've changed plans and never used.
$400 + shipping.
Bink is offline
Old 04-04-2006, 12:10 PM
edsalinas
edsalinas's Avatar
St. Jude Contributor
Default 383 stroker, D44 /w 410's etc. etc.
Anyone looking for a new 383 stroker?
How 'bout a newly re-built (zero miles) D44 with Dana 410 gear set?
Or a newly re-built 700r4 on steroids? That and much much more.
$8,500 buys it all. Check it out.
http://forums.corvetteforum.com/show...12&forum_id=54
edsalinas is offline
Old 04-05-2006, 04:03 PM
racerwannabe
racerwannabe's Avatar
St. Jude Donor '06
Default make offer
front and rear extreem springs for C-5..from VBP
went to coil overs,
johnny
racerwannabe is offline
Old 04-05-2006, 09:45 PM
C6400hp
C6400hp's Avatar
Location: DFW This user does not support or recommend the product or service displayed in the ad to the right
Used DRM brake ducts for a C5 or C6. Has modified factory C6 ducts pop riveted to the end to work with a C6. If you inted to use on a C5 you can simply remove the additional ducting. The flexible ducting that goes to your spindle has been worn through so you will probably need to replace. Less than a month old.
***********************SOLD************* **************************************** *********************
C6400hp is offline
Old 04-05-2006, 10:14 PM
snaketr
snaketr's Avatar
Rebuilt Dana 44 w/ 3.45 gears, no miles on it. Includes rear bat wing $1500
snaketr is offline
Old 04-10-2006, 08:21 PM
Ag-z06
Ag-z06's Avatar
Default FS:18x11 CCW track wheels and Goodyear race slicks
http://forums.corvetteforum.com/show...post1554822348
wheels used 5 weekends
Tires are take-offs from a Daytona Prototype from this year's Daytona 24 - have between 1 and 3 heat cycles - Goodyear G19 475 compound - fit great on the CCW's
Located near Charlotte, NC
mstam55@hotmail.com
*****SOLD*****
Ag-z06 is offline
Old 04-11-2006, 04:49 AM
jdonnelly
jdonnelly's Avatar
Default R3 B Head and Neck restraint
From the Engineer that invented the Hutchens Device®, comes the most advanced carbon restraint yet. The R3 passed the most comprehensive and brutal SFI spec. ever written. The R3 is a revolutionary new concept in head and neck restraint systems. The R3 solves issues with current carbon restraints. The R3 head and neck restraint travels with the occupant during a crash to help keep the relationship of the head, neck and torso consistent.
The R3 is a state of the art Carbon Fiber Head and Neck Restraint System certified SFI 38.1 and tested at 70G. Years of development and hundreds of sled test’s have made the R3 a Comfortable, Effective, Multiple Impact capable Head and Neck Restraint System. Size Large for chest measurements 42-48. This unit has been used for fitting only and has not been racing yet. New cost is over $1000 delivered. On sale for $785 shipped to anywhere in the continental US. Please e-mail me with any questions drd@bewired.com
Jeff
jdonnelly is offline
Old 04-11-2006, 08:57 PM
C5ontrack
C5ontrack's Avatar
why are you selling these ducts? I couldn't make them fit my C6
C5ontrack is offline
Old 04-11-2006, 11:20 PM
C6400hp
C6400hp's Avatar
Are you referring to me? If so , you can make the DRM's fit a C6 it just takes some work and alot of time with cutting/sizing the existing factory ducts.Plus the instructions that come with the rippie's are the suck. I have already done all the work that DRM fails to tell you about and these come with the duct for the C6 already trimmed and attached.
C6400hp is offline
Old 04-21-2006, 12:03 AM
joseph796
joseph796's Avatar
Default VBP C5 Springs
went to coil overs,
johnny
What are the spring rates?
joseph796 is offline
Old 05-03-2006, 08:09 PM
TmillerC5
TmillerC5's Avatar
St. Jude Donor '08
Default Big Azz mirror
Panaromic mirror See everyone behind you.
$35.00 Shipped
Clamps on you mirror Paypal or Money order
17" wide
TmillerC5 is offline
Old 05-08-2006, 04:07 PM
Mag Red Mike
Mag Red Mike's Avatar
St. Jude Donor '12
Default FS: Delan Trailer Hitch for C5
Like new. Used for one season of racing. Includes ball, new mounting hardware and instructions. $125
Mag Red Mike is offline
Old 05-10-2006, 04:11 PM
davidcheese
davidcheese's Avatar
Default T1 shocks and springs
Used T1 shocks and springs. Got them 2 years ago from LG Motorsports in Dallas. Combined with T1 bars and slicks my 98 stock vert could run circles around Z06's with slicks on the road course. Asking $950 plus shipping firm. On GM Parts direct they are $1900 plus shipping new. email david.cheese@sbcglobal.net
davidcheese is offline
To Post your Race Parts 4 Sale HERE
Old 05-12-2006, 02:00 PM
fmrfast
fmrfast's Avatar
Default L98 Corvette A/C eliminator bracket
See link to C4 parts for sale
http://forums.corvetteforum.com/show....php?t=1389787
fmrfast is offline
Old 05-17-2006, 09:18 AM
GRB
GRB's Avatar
Default 4 Michelin Pilot Sport Cups
275/40x17 less than 50 street miles so like new. $750 Atlanta area only.
GRB is offline
Old 05-24-2006, 08:50 PM
BQuicksilver
BQuicksilver's Avatar
......sold
BQuicksilver is offline
Quick Reply: Post your Race Parts 4 Sale HERE
