Crotch Strap on 5 Point Harness
Guy's I drag race and am using a 5 point harness. Knowing that more of you race with a harness is why i'm posting here. I have a 5 point harness with a 6 point roll bar. What are you doing with the crotch strap? I have it hooked to the Wolfe Racecraft FRONT of seat mount, but the distance is longer than I like. I then saw some posts here about running it between the upper and lower portions of my factory seat. Thought that was an excellent idea until I did it and realized the family jewels will no longer be where god placed them in event of impact. Thanks for the help.
Bob
Bob
Bob
Bob
Bob
In front of the seat is dangorious. If you slide down the cam lock could or may crush / crack your sternum.
Yes run the belt between the upper and lower portions of the seat and Sit on the sub belt. However, as you found out. A baseball cup is a good idea to protect the family jewels.
Other option are to modifiy your seat so the sub belt come though the seat bottom or switch to a doulbe sub belts as in 6-points.
Good Luck
Originally Posted by AU N EGL
Bob
Good Luck
Good Luck
Received 8,926 Likes
The purpose of the sub belt is to keep the shoulder harness from pulling your lap belt above the hip. With your sub belt mounted in front of the seat you are actually using the sub belt to pull the lap belt away from your body rather than holding it down. If you use the Brey Krause belt mounts for the lap and sub belt you can then use a two point sub belt which will allow you to sit on the sub belt without cutting off major organs. Basically the lap belt and sub belt make a circle around your legs and the sub belt pulls the lap belt down where it is supposed to be.
Bill
Bill
Let me add a recommendation for the two-point sub. I know it isn't an answer to the question you asked, but I think this will sove your problem. I use it comfortably.
Bill
Bill
Alright guy's I took everyones advice and swapped the harness for a 6 point. I also purchased the Brey Krause lap belt mounts. After doing the install I have found a couple of "issues"
1) I am very thin, so mounting the lap belts to the BK mounts gives me ZERO adjustment as the belts that close are in the sewn ends after snugging them down.
2) There is no real adjustability in the BK mounts for the clip in mount to "swivel" When I sit on the subbelt the left side is fine. I need the right side to pivot down a slight bit. Can I enlarge the hole a touch on the BK mount? Thanks for the help.
Bob
Bob
If you're real skinny, it's better to look elsewhere for lap belt mounts.
Originally Posted by Lancer033
I had the same problem too (<32" waist). Crow made a shorter inside lap belt for me and it worked pretty good. The downside is that 1 side was not adjustable, so I had to set that side and use the left belt to tighten it down
