Where do you mount race transponder??
Only spot that looks like an option is the front z06 grill but I can't imagine there isn't a better place.
I just want to use zip ties also.
Originally Posted by emf
Assuming rechargable -- in a C5, the center hump. Stuff it under the carpet, at the bottom.
Center hump not an option, then rear license plate screw.
When you say center hump, what do you mean? Under the carpet? How does it attach to the rear license plate screw?
Do these things have to have line of sight to the track or can they transmit through the floorboard or other obstructions?
What bout zip tieing them to the struts that are under the nose?
Originally Posted by Falcon
How about some more elaboration.
Umm . . . 2 separate mounting ideas.
1) In the trunk of a C5, stuff the transponder in the center storage compartment. The carpet has a seam in the back -- lift the carpet up slightly, stick the transponder underneath the carpet, and don't forget to take it out when you're done. The transponder is close enough to the ground to get picked up by the detection loop, and does not have any problems w/ reception through the composite floor. If you do NOT have carpets, tape the transponder in place with something suitable.
2) If this is NOT for a C5, if the center hump is occupied by something else which cannot be easily moved, or if you've cut the center hump out for . . . . something else, utilize the rear license plate or license plate screw.
I'd avoid mounting on the front skids . . . one bad off, and there's a good chance it won't be there when you get back to the pits. Of course YMMV and I'm sure someone will chime in and say "But I put mine there all the time", but I'd recommend against chancing it.
Ok my transponder has a mounting bracket.
How do you use a rear license plate screw to hold that down?? Or do you just zip tie it without the bracket and let it bang all around??
So it actually works being inside the car? Mine is rechargeable so you want quick access but maybe center well in rear on Z06 under the carpet is the place. Do you just tape it down or just place it under there and it stays in place??
Just went out and checked and both side rear compartments are velcro in the middle for real easy undo and then place transponder under carpet and it should sit and stay no problem.
Key question is does it still get read from there?
Normally I'd just stuff the transponder under the carpet, and barring carpet then use tape. I guess, if you have a removable holster, you could get a bit fancier w/ attaching for a more permanent mount . . . not required IMO, but an option.
Put it someplace it won't get knocked off, if you brush a wall or engage in a little impromptu bump-drafting.
In W2W racing the location, unless mandated by the sanctioning body, is irrelevant. Race 'scoring' (the 'S' in T&S - Timing & Scoring) is supposed to be by visual observation, not by transponder 'passings'. If it's not, your racing organization isn't 'trying' very hard.
