Feedback from owners of LG coil-overs
First let me say I recognize Lou makes a great set up..
My very specifc question (don't really want to discuss the pros and cons of coil-overs vs. composite springs, etc.) is "over time do the solid-links / shock mounts make noise?".
This is still a street car, and the last thing I want to hear is squeaks and rattles every time I hit a bump.
I realize this would not be an issue on a race or track-day only car.
Feedback appreciated.
I just bolted my LG coilovers in last weekend and have not yet driven it other than around the block. have not yet gotten it aligned. But I can tell you about installion. The front lower mount is the same as stock, the upper fronts are a big bolt and it is long enough that you could use rubber bumpers on it to cushion. I just bolted it up hard to the mount cuz I don't care.
There rear uses the stock rubber mount and the upper is a heim type joint which might make some noise. Might be dead quiet.
They fit perfectly.
Dan
They fit perfectly.
Dan
