What brake fluid to use?
I just went to WSIR (Willow Springs International Raceway) and intend to do these HPDE events several times a year. The car held up great, no problem to report. I understand that the brake fluid should be changed periodically if the car is run hard, as it was at WSIR. Should I just stick with the stock fluid? I used Motul 800 in my 02 Z06, but since I didn't track the car that often, I noticed no improvement with the GM stuff vs. Motul. I also saw no problems with the padlets either. I guess for an occasional tracker like myself, all the stock stuff is more than enough, just add seat time.
Thanks,
Thanks,
Former Vendor
Good fuild is a very cheap insurance. Have you ever had the brake pedal go to the floor at over 100MPH? It would not be cool at all. 16-20 bucks a bottle is well worth the money.
Randy
Randy
Change your fluid and mazimize your seat time.
Dot 3 will work as well as Castrol SRF if neither is boiled. If you aren't yet to the point of creating maximum brake heat, the fluid hasn't met its maker yet. When it does, you will be presented a rude awakening. Going into a corner w/o meaningful brakes is an experience you needn't go through. You've taken a very prudent step in changing to a good race fluid and you've made your car safer on the track for yourself and others.
Race brake fluid provides additional head room regarding the resistance to extreme heat. If you don't generate a lot of heat, any fluid from Dot 3 to the best race fluid will work fine. When you get to the point of exceeding the Dot 3 limits you'll appreciate your switch to an improved performance fluid.
steve
Edit: Opps, I see you switched to Moutol in your last car. Do the same for this car and you won't regret it. It doesn't matter that you didn't experience a failure. The stock fluid has a very limited heat range when exposed to race heat. Change it!
steve
Former Vendor
Castrol SRF
Just use the best. Expensive maybe, but running on the track, will you risk boiling your brake fluid to save $60? Losing brakes sucks, and can be far more expensive. Save the money somewhere else.
http://performance.accuratetechnolog...products_id=20
Do NOT use silicone brake fluid (DOT 5) because it can damage the internals of the ABS system.
Originally Posted by ATI Performance
Castrol SRF
I found it to be the cheapest per mile plus less labor.
Big track isn't too bad on brakes, and as such you won't see nearly that much wear or heat. That said, Motul will be more than adequate for occasional track days @ WSIR and mostly highway driving. If you routinely head up to Buttonwillow, then that may be a different story . . . . .
SRF works well, but the fact of the matter is you won't put enough heat in to need it on that track.
Kailo's event fairly uncluttered this time? the last event I went to in November had 9 billion cars per run group
Castrol SRF. Just today spoke with someone who crewed for a Porsche at Daytona. The car came in with it's brakes on fire but the SRF never boiled and the brakes still worked!
emf:I was in the beginner group, and it wasn't that crowded. The intermediate group was more crowded, my friend who's a very good driver, got held up multiple times due to his group having too many cars.
Does anyone use ATE Super Blue? I've used it in other cars on the track and it works great. Never had a boiling problem with it. Had planned on putting it in the Z06. Any thoughts?
Originally Posted by Rapid Transit
What do you mean "less labor"? Is changing to Castrol SRF somehow different than changing to another brand brake fluid?
[qutoe]Does it have the highest wet boiling point?[/quote] YES
Also some "race" brake fluid has to be changed more often, even if you don't race the car, because it absorbs moisture more readily than others. I believe Motul 800 is good in this respect. Was that wrong info?
Most DOT 4 fluids need to be flushed before each track day.
I use Motul 600 in the front and Valvoline SynPower in the rear. If you change your fluid immediately before each event, thats all thats needed. I like Motul because it changes color after one event and makes the next fluid change easier. Never heard of Motul 800. Is that a new product?
Originally Posted by AU N EGL
Before each event just bleed each caliper a bit. With other fluids yoru doing a FULL FLUSH before each event
I was there in November too ..... funny, I only counted 8 billion cars
I'm using Dot 4 (Prestone) ...... but it held up very well at Button Willow along with Hawk HP+ pads. No fade and no soft pedal. But I did bleed a whole pint in right before that track day
DH
What do you mean "less labor"? Is changing to Castrol SRF somehow different than changing to another brand brake fluid? Does it have the highest wet boiling point? Also some "race" brake fluid has to be changed more often, even if you don't race the car, because it absorbs moisture more readily than others. I believe Motul 800 is good in this respect. Was that wrong info?
I don't bother to change it or bleed it as often. Requires way less maintenance and way less fluid so it is cheaper. Like Red Wing Boots vs cheap work boots mine last more than 3X as long.They work better while wearing them so they are better and cheaper.
[QUOTE=AU N EGL]Before each event just bleed each caliper a bit. With other fluids yoru doing a FULL FLUSH before each event
QUOTE]
Why do you recommend a full flush with other fluids, but only caliper bleeding with Castrol SRF?
QUOTE]
I've used motul and Gs610 without having to do full flushes... I think once you've gotten in the top shelf fluids, they tend to last quite a bit longer, and with less full flushing than the lower end fluids...
Mike
Mike
Randy
Randy
(2.83MB)
