More camber
More camber
I have an 86 and am looking to increase the negative camber. The car has almost no shims and I am not allowed to machine the black spacers.
I had heard that I could possibly use later model control arms but have not been able to find anything about this using "search".
If this is true what combination is needed? Do I need the later model spindles too?
I'm assuming that you are in a street prepared class and not stock.
The usual way of fixing that in street prepared is with offset bushings in the lower control arms.... Swapping in later model control arms would make the geometry a mess as would putting in the spindle and lower control arms from a late C4 and using the upper control arms from an early one...
Just get a set of offset lower control arm bushings and go with that.
I was told that there was a post some time ago on hear about intermingling different year C4 front suspension parts to accomplish more negative camber.
