Brake control module with aftermarket brakes
I am either going to go with stoptech or apracing brakes and i wanted to know if needed to keep the brake control module? What exactly does it do? The reason I am asking is because i want as little useless crap in the car as possible.
The EBCM/BPMV controls ABS, AH, and TC. I'm guessing that there is a way to turn those systems off so you don't get a warning light, but I'm not sure. Personally I wouldn't give up ABS unless I had to.
Speaking of which, I'm looking for an EBCM, so if you're going to be doing this soon, let me know.
Received 8,928 Likes
There are some pretty good descriptions of how that crap works in the Service Manual. Also some very well written SAE papers available from SAE. Since you really do not know what you are messing with I would suggest you leave it alone. A C5/6 is not a clunky 60s era vehicle.
Bill
Bill
Former Vendor
All the boxes and lines do have a role in these cars. There is more trick stuff then what I can rember. Rule of thumb, either leave everything alone or take out everything. IF you start taking out one thing here and one thing there. You will have a huge nightmare. The car will go into backup mode, or lock up brakes or something stupid. When you go to aftermarket brakes, everything should work just fine.
Randy
Randy
