View Full Version : C5 Scan & Tune
Pages : 1 2 3 4 5 6 7 8 [9] 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32
  1. mpg
  2. Tune after Vararam?
  3. Advice please explain to me the differance between a tune on a dyno to a loaded dyno
  4. efi live timing question
  5. Tuner in Kansas City
  6. Milwaukee Area Good Tuner!
  7. how much for a compression test?
  8. Tuner needed in DFW area
  9. Mike Norris Motorsports LS Tuning In Tuscon, AZ Sept 18-19
  10. 97-98 Vette PCM ?
  11. need feedback on cause of dip in dyno
  12. OBD-II Communications Protocol
  13. chicagoland good tuner?
  14. monitor boost w/ efi live
  15. tuners using Hp Tuners in AZ
  16. what would be the best way for me to have more power
  17. Anyone in the Wichita KS area have HP tuners?
  18. LS1 Edit FS
  19. C5 Tune Question - Throttle Decay
  20. Code C1265 and ABS Fixer
  21. need help with 418 tune
  22. Missfire (code 0300) @ WOT
  23. HP Tuners Users, I need your stock tune please.
  24. New LS1 Edit software
  25. Passenger side leaning out, blowing #2 HG
  26. Predator question
  27. Predator PC cable & power
  28. Predator OBDII AIR EGR & O2 settings
  29. Removing Fuel Cut-off ?
  30. HP Tuner in Portland Oregon ??
  31. Texas Tuner
  32. dyno tune thanks don slowhawk
  33. Predator Tune Suggestions
  34. Major P0300?? Help!!
  35. looking for good tuner in east texas.
  36. how to monitor boost pressure in efi?
  37. Good Tuner/Shop in SC/NC/GA/TN Area
  38. Cammed C5 stalling at idle
  39. C5 Tuner in Bufffalo, NY
  40. Tuner in the Florida panhandle area?
  41. need HPT file for H/C/C for 98 a4
  42. rear cat o2s
  43. Tune pcm help please!
  44. PCM plugin ??
  45. 59cc AFR's and 91 octane
  46. vararam compensation
  47. Tuner for 04 Z06
  48. Middle Tenn Tuner Needed. .
  49. Will hyper tech 111 help!
  50. ECS returns to Carlisle with the $99 tune special
  51. Nate @ Classic GT Motorsports
  52. Best way to semi tune it
  53. Headers and Predator Tune
  54. Tune Needed in Detroit, MI area
  55. !!!Cartek will be at Carlisle!!!
  56. Need advice on tune for C5
  57. Which is better for a stock car (vram intake)
  58. Charley @ RPM = MAGIC
  59. The best upgrade you can make to your car in in the driver
  60. Unlocked tuner?
  61. maf sensor
  62. Quick Question Regarding the loss in HP after 5500 RPM
  63. Question regarding fan settings
  64. FREE TICKETS from COD
  65. Starting out tuning 03 Z06
  66. Scanner/tuner for 98
  67. Need Help , Failed Penna. Emissions today
  68. What a waste of a Day!!!
  69. 99 how to pull codes
  70. Really want a good tuner
  71. fianal locked Predator question
  72. Want to put headers and cross-pipes on...
  73. Cats or no Cats
  74. Wide Band set up?
  75. What should my rwhp be? S/c stock 01 z
  76. How much would you pay for extra gas mileage?
  77. Spark plug question for tuner
  78. Basic tune info
  79. Review Of Cold Idle Needed ( HPTuners )
  80. Need a tuner ..........Pomona CA area
  81. Two step/efi live
  82. No power to passenger door
  83. Tuning?
  84. Installed diablo program any ideas
  85. Header tube temps and infrared thermometer
  86. Reccomended Tune Changes?????
  87. No A/C after mail order tune?
  88. How do i know if my preditor is unlocked
  89. Power at rear wheels PID
  90. Nice job ECS
  91. Diablo Predator LS3 finally shipping?
  92. Service:Active Handling/Traction/ABS
  93. low rpm miss
  94. Whiplash Cam only Tune
  95. MTI Racing's(Marietta,Ga.) Annual Dyno Day and Open House on Saturday, August 16th
  96. Need a tuner in Dallas/Fort Worth Area
  97. Need a tuner near EauClaire, WI
  98. Tuning out TPS w/HPTUNERS
  99. PCM re-pinning Diagram???
  100. IFR Tables: 96lb. injectors
  101. How to disable codes with a Predator?
  102. start up problem
  103. CEL: Can someone make sense of these codes for me?
  104. Formato Tuning and Porting in Gettysburgh - Same Time as Carlisle 8/22 -8/25
  105. Anyone else tune an STS TT set up?
  106. please delete
  107. LS1Edit & HP Tuners Compatiable
  108. Diablo unlock, how for sure ?
  109. Mail Order Tunes And More Codes!
  110. Install Hypertech or similiar program to tuned vehicle?
  111. Brake light fuse?
  112. Difference between O2 sensor codes P0141 and P0140?
  113. long and short term fuel trim help please
  114. How do I remove the PCM?
  115. Bad to run WOT until AIR Delete codes programmed out after race headers?
  116. anyone still use ls1edit
  117. Lc1/XD-16 and Hptuners Pro log readings don't agree
  118. Need tuner near Dover, DE
  119. problem with hp tuners
  120. Lost Hypertech Power Programmer
  121. Minty 2.10 version Diablo for sale....
  122. The Predator did a DANDY job so far...
  123. good ls1 tuner in New Orleans metro area
  124. What's a normal A/F ration in closed loop?
  125. Gotta post about a good experience with Chuck @COW!!
  126. I would like to 'rent' your HP Tuners
  127. Calibrating Speedo'
  128. Can you tune to run on 4 cylinders?
  129. Just got first numbers today - not there but close!!
  130. Apsis' C5 Splash Guard (C6 Z06 Style) installed, *PIC SHOWN*
  131. torque management via DiabloSport?
  132. Engine Codes - Advice on Data Parameters
  133. ### St Jude Auction #49..Tuning is not a city in China...####
  134. Will any of the hand held tuners allow me to...
  135. Diablo Predator after HP Tuner?
  136. Are my dyno numbers jack'd?!?
  137. CAGS being used as a shift light!!!
  138. C5 Tuner in West Texas/NM/Arizona
  139. Anyone recognize part of this spring??
  140. Timing Question
  141. Got my DSLogRedux for Predator...
  142. TCS codes killing engine power?!
  143. What would cause bogging under boost?
  144. need help PREDATOR TUNE (newbie)
  145. 1st Corvette and Tuned by RPM. Dyno sheets posted.
  146. Looking for a tuner !
  147. Motorsports Xtreme Blountstown FL
  148. So I just pulled the trigger on my Predator
  149. Help with first boost logs in HP Tuners
  150. P1133 & P1153 Please help me!
  151. efi live/hp tuners ???
  152. thank you vette doctors
  153. Ok tuner people, why not a laptop and appropriate software?
  154. Got another one...
  155. Professionally Tuned Opinions - File attached for EFI live - Need opinions please
  156. Race Proven Motorsports Now Doing Mail Order Tuning
  157. Here's one for ya...
  158. 1997 p0102 no clear answer
  159. tuning a stock 98 - dyno chart.
  160. Anyone have E-9 error code problems with their LC-1?
  161. Jeremy Formato tuning and porting 7/10 in Gville
  162. Car back from Tuner SEVERAL codes please help!!!!!!!
  163. pcm update by dealer now car runs very bad
  164. Predator Tune
  165. what temp settings are best
  166. should i add a 160 stat
  167. Can someone recomend a Tuner in Springfield MO?
  168. ECS is Awesome!!
  169. Bad deallings with spindoctor. so call tuner
  170. vette tuners in south jersey
  171. Idle hunts with AC
  172. KR during gear entry... Normal?
  173. HP Tuners VCM Suite 2.22 is Now Available!
  174. Need advice as I am throwning traction control code 1214, do you think I need service
  175. need some help from you tuners
  176. Is it normal to lose power above 200 deg's
  177. twin turbo tune?
  178. Trying to pass safety inspection, computer not running tests needed to pass
  179. Active handling warning light
  180. Troubleshooting knock
  181. diablo tuner help
  182. Willing to Pay for Tuning Help!
  183. new to everything
  184. HUD Shift light
  185. Start up Tune
  186. Cylinder Charge Temp Bias for SD
  187. need to be dyno tuned in upstate new york
  188. Installed LT's Do I need a Tune????
  189. • • • Mail Order Tuning from $99 • • •
  190. Efi Alchemy
  191. 1998 corvette conv. (No Competitive Mode)?
  192. HELP ! NO Instrument Cluster or HUD after READ
  193. What is this worth?
  194. ***mail Order Tuning By Ecs***
  195. need help with pcm10 0153
  196. Rich-Lean Comparison Article on Innovates Web Page
  197. Chuck Cow Mail Order
  198. Any good tuners in Raleigh NC area???
  199. Tnuing out fuel cutoff for the column lock
  200. Air Fuel Ratio ?
  201. P0102 code maf low voltage after STS TT install
  202. A Gen IV w/a 58 Tooth Reluctor into a Gen III C5?
  203. Went extremly lean all the sudden
  204. Can you delete front O2 sensors?
  205. Where is the performance chip located in engine?
  206. help finding a tuner
  207. Any tuners in south eastern Michigan you can recommend?
  208. Code P0343 and other issues with my Procharged FRC
  209. Reduced Power
  210. Tuners in South Texas
  211. *****Gettysburg PA Tune and Porting session 7/18-7/26*****
  212. P1133 & P1153 Codes after Install
  213. having problems with hypertech
  214. What should I set the rev limiter at with My Cam???
  215. EFI Live help/Good tuner in northern Va
  216. Will a tune give me power low down?
  217. Wideband bung location
  218. lap top hoked to the car and head squairly in as...
  219. Mail Order Tuning From Chuck CoW
  220. What tune do I need.
  221. A tuner in Miami!
  222. **new Engine Tune Question**
  223. tuner needed north louisiana
  224. I just bought the lc1 A/F raito guage and unit for the c5..Installed 02 after x pipe
  225. How to correct WOT AFR for each gear?
  226. CARTEK ***CHANGES and SPECIAL***
  227. Tuning interface
  228. Cincinnati Dyno Tune?
  229. Returning locked pcm to stock settings
  230. Mike no Predator for a 04 to be found
  231. Any one have a stock 2000 mn6 tune?
  232. what do I need to re-program the ECM
  233. left and right bank lean codes with Vararam
  234. Hey Guys....I'm here in Orlando today June 5th....
  235. Diablo Sport Predator Question
  236. How to save your stock tune/image B4 modding in HP Tuners
  237. AFR heads in stock.....
  238. highest octane you can tune stock?
  239. Which gas to use with a Diablo Predator?
  240. Jeremy Formato Tuning and Porting Session Friday In Gainesville and Saturday in Tampa
  241. Tuned? 327 RWHP FRC?
  242. EFI Live & Column Lock
  243. Anyone with a tech 2 near joliet,illinois need updated
  244. had some problems with the car today, can someone help me out
  245. Can an EFI Live tuned car be tuned with HP tuners?
  246. Diablosport Predator Porblem with Modify Parameter
  247. Note For Vengeance Racing.
  248. NOS filling cost
  249. P0443 and P0481 Code Help
  250. Looking for EFI tuning help in Central PA
