- Tuning question on my vette about commanded AFR
- Logging through EGR Unable to parse log?
- HP Tuners Sale @ KY Speed
- codes c1232,c1233,c1248
- 250 mph fuel shut off
- Lost HP But Gained Torque, is that good?
- Happy with shop in West Florida...
- Racing Gas?
- Tuning by east coast supercharing
- What's Tune?
- Thanks BLOWNBLUEZ06!!!
- Knock, Knock, Knock..
- Need a good tuner in NC or SC
- The Tuning School Live Seminar Beginners HP Tuners June 27-28th Tampa, FL
- Tuning 04 Z06 for Vram and LTs
- Amazing C5 Red Carbon Dashes..... how do you like it?
- Is a Cam only (MS3) swap with a tune worth it with no other mods planned?
- ECS Mail order tunes, still only $149!
- Would you road tune on a mountain pass?
- Changing MAF possible with Predator ?
- need tuner knoxville tn
- Looking for tuner in Wichita, KS area for fuel cutoff reset
- Need a tuner
- Fuel Gauge?
- Good Tune Read (LONG) Tuners Input Desired
- Question about a power programer
- Need spark plug Gap for 99 FRC
- My Chuck CoW tuning day pics
- Switched power source for wideband
- need a source for PCM harness pins
- IAT sensor malfunction - how does this affect how my car runs?
- Car dies
- Tune
- New to the Vette world
- Need help with error code c1214
- Problem with spark advance, any know about this?
- SKF Hubs
- tuner?
- Question about how an A4 car is dynoed?
- GP Special: C5 D-Type SW .... *PIC*
- Did I kill my Gas Gauge?
- Need Some Pro Tuner Help
- Help with (hypertech) programmer
- I got a Check engine light today!!!
- MTI Heads and x1 Cam Tune question
- another weird problem after tune
- New Vette for me - Tune question
- A Good tuner
- stock 03 z06 will tune help?
- Logging Wideband through EGR on 98
- Jeremy Formato Tuning and Porting in Gettysburg PA June 13-20th
- NEED a good tuner in San Diego, CA
- Weird Problem after tune
- problems after tune
- what will a tune do for me?
- Experience with MC Racing in KC area
- new exhaust/no CATS/ O-2 issues HELP
- Innovative LC-1 users
- Are there any good handheld tuners?
- idles but dies
- Upgraded to a Z06 85mm MAF do I need to change anything other than the MAF Table?
- check engine light reset
- LM1 Mounting
- I'm looking for a tuner in the Pensacola Florida area
- Need Help logging lc-1 w/ hpt standard
- *** Unlimited HPTuners Pro Box *** See Inside!
- Diablo Prediator
- Need a good tuner in South Eastern MI area
- Engine swap...... ECM??
- looking for mike norris tuner in fla
- Emissions Problem
- Hypertech Max Energy
- SD or MAF TUNE
- idle problems/ idle decay
- tune only still stock?
- Formato tuning and porting in S FL (Davie) May 15-16
- how much kr is too much?
- 408 or? need help...
- Which O2 sensors to tuners use to tune with?
- Do these numbers look right?
- My first dyno - stock
- collaped lifter on a 402 with YSI
- Problem Code
- spark plugs
- Is my vette worth a street tune?
- Harland Sharp tells Charlie to " go pound sand"
- Problem at Smog Check
- Mike Norris "tuning trip"
- How can I wire an LC-1 to replace the DS stock NB O2?
- Tuner in San Diego, CA ???
- Using a Predator after I have a tune ?
- Any specials going on for tuning?
- Hypertech power programmer...
- tuners ????
- Jeremy Formato tuning in Gainseville FL 5/7
- which MAF sensor
- Stalls after cam install
- ques about tuning my 01.(have mods)
- fast fsx
- Missfire @ Idle in Closed Loop Only
- 01 Z06 Cold Idle Hunting
- Vararam+Tune=?HP
- FS: HPT VCM Suite (Professional)
- Wtb hp tuners at home course
- ABS light stays on
- C5 o2 sensors- customer w/ odd happenings
- Which Wideband 02 do you use with HPT or EFILive?
- Tuning
- Need some help in Detroit
- Mechanical or Electrical gauges?
- Out of Whack Tune root cause of Noticable Engine Vibe??
- Perfect Predator tune
- oem navigation system
- How to tell if MTI (Houston) locked my pcm??
- Need a good phone number for The HP factory
- Are there many types of Trickflow215cc
- a/f for a stock car w. bolt ons
- Easiest way to adjust fan settings?
- PLX M-500 Diagram
- Someone help me with tuner
- PM-FL Tuning Package Sale!!!
- Dyno Graph
- What Air Fuel Ratio you running under boost and how much boost?
- Help if you will
- Tuners - Anyone near Colorado - ?
- Those with Varaam and wideband, notice on windy days
- Can anyone Help With Tuning???
- Can someone explain what a HP Tuner Credit is please?
- AAAAAHHHHHH!!! Please Help!!!!!!!
- Anyone having a sale on for HP Tuners?
- ~~~~ St Jude Auction #34 mail order tune for C5 / C6 from Chuck Cow ~~~~
- cost of tune
- Employee pricing is back for a limited time!
- Diablosport Predator Tuning
- Beautiful C5 D-Type Carbon Steering Wheel..... *PIC*
- need tuner in fayetteville north carolina
- Looking for a old thread with a tune....
- need a good tuner
- Looking for SoCal tuner
- Dashboard light and computer problems, pls help!!
- 36lb flow rates for Bosch injectors
- Redline or New Era Performance in NY
- Valet tune
- Best tuner in Chicagoland
- Tune Specials?????
- EFILive is V2 better?
- need a part number:
- Is it time for a tune?
- LC-1 and HP Tuners
- Inspection Woes
- dyno help
- Can rear O2's be eliminated?
- Switch '98 PCM tune to '99 PCM
- Grease Points??
- Time on a Dyno
- Any Good Tuners in Greenville, NC?
- Innovate Wideband Gauges/Controllers On Sale!!!
- Help me solve a Tuning Problem.. I have HPtuners
- Diablo sport predator?
- Tune in Savannah,ga
- •• Purchase HP Tuners Pro and get an Innovate LC1 for $139 or NGK AFX for $239!!! ••
- Ran against a Porche GT2/3 (?)
- MAF housing, stock 98 with Novi 6psi
- Perfect Laptop for tuning $350
- FIRST D-Type Steering Wheel installed *PIC*
- Houston (Pearland/Clearlake)
- Where to find a tuner in Boise, Idaho
- Will O2 codes affect preformance
- Racetronix 79 lb/hr high impedance injectors
- rear cat o2s
- The Tuning School Live HP Tuners beginners class Dallas April 19-20th
- Anyone make any custom configs for 97?
- already tuned?
- Can LS1 Edit be removed for a different tune?
- New Best with Predator
- Tune Question
- Tune Help ASAP!
- Some general info about tuning from Fasterproms, basic to advanced
- Predator Install PLEASE HELP!!
- Nice 3/16" dia hole drilled in the TB blade of my 2001 414 cid.....
- Strange wideband issues, reads way lean at idle yet ok at WOT, ltrims good.
- car uses OBDII or Controller Area Network (CAN)
- torque converter (problem)
- Tune - How much and where? Western NY
- Newbie questions, Flame resistant suit on
- Computer relearn?
- >> MONSTER CLUTCH Group Sale << Only 8 Slots Left >>
- $$ NEW FAST 92mm Intake Manifold $799 $$
- New dyno and tuning business
- How far out of whack do you Tuners think this is???
- Plug Wires
- My new numbers
- Predator Tuner Question
- can I get more when dyno tuned? how much?
- Tuner needed in Buffalo
- Plug for Local Tuner (Raleigh, NC)
- Info please on predator tuner
- need tuner
- Startup Airflow help
- I need a good, cheaper tuner :)
- Removing F45's from computer??
- Do you have C5 core Steering Wheel for sale? We are still buying.
- LM-2 and EFI Live
- C5 D-Type SW Limited Spring Special $588 *PIC*
- Retune needed when moving?
- a/c and heater fan
- Does restore unlock the predator tuner
- FS-2003 Factory Polished Thin Spokes
- Suggestions for Changes using HP Tuners?
- Any tuners in Sacramento CA?
- Whats best for O2 sensors ?
- Tuner in Tampa/St Pete Fl area
- Vengeance Tune in Hawaii
- ******Gettysburg Tuning and Porting March 27- April 4******
- POLL: Which D-Type steering wheel you like better? *PIC*
- WTB: Do you have C5 stock steering wheel for sale?
- SPECIAL: Apsis C5 Silver Carbon or Burlwood Steering Wheel *PIC*
- Formato tuning and porting 3/6 in Gville
- Tuner in KY area????
- Mustang dyno to Dyno Jet comparison?
- EFI Live + F/I + Index Racing = Problems?
- O2 sensor readings
- Loss of Communication Code Question
- POLL: Are you interested in C5 Carbon Exhaust Diffuser? *PIC*
- injector install
- Tuner in Vermont or New Hampshire
- SD tune and SES
- LS2 motor swap injectors?
- DTC P-1416 Help
- Tuning w/ HPT and EFI Live?
- WTB: Do you have C5 steering wheel for sale? *PIC*
- Exciting News: Apsis C5 D-Type Sport Steering Wheel now ready *PIC*
- Vararam causing lean condition with stock PCM calibration?
- My bolt on dyno
- k&n filter, long tubes, 42# injectors, HSW plate... tune questions
- MS/AL/FL Owners - Need Assistance with tuner
- 85MM MAF and 30# injectors
- free Y2K C5 tunes in Tampa
- TCS and ABS lights on...looking for a little help
- Headers - Tune??
- Drivability question after mods on 02 coupe
- East Texas Muscle Cars Awesome Tuner
- Which Tuner?
- Intake Manifolds? Which one to buy?
- Corvettes of Dallas wants to help you get ready for PINKS ALL OUT
- wide band hook up
- Need advice/ tuner in PA area
