View Full Version : C5 Scan & Tune
Pages : 1 2 [3] 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32
  1. Any Reviews on Jon Lund tunes?
  2. '98 model service soon sisplay warning?
  3. Local
  4. Diablosport Predator... Good for all stock 03z?
  5. handheld tuners
  6. The Tuning School Beginners Live Seminar Twinsburg, OH April 16th-17th
  7. Need a Tuner in Chicago area that Tunes with Meth????
  8. Tuner in Houston?
  9. Tuning to increase "raw" feeling of c5z and c6?
  10. Oil Pressure
  11. Horsepower At 50mph
  12. How much hp from a mail order tune
  13. Help! Need tuner! East Texas!!!!!
  14. Help, 0 degrees advance off the line
  15. Emissions question
  16. Professional tuner needed in Southern Cal
  17. JET Dynamic Spectrum Tuner
  18. Tuners for a 1998 Vert?
  19. Help P1631C
  20. Tuning Supercharged Vette for Headers Cat΄s and EGR removed
  21. Old U7198 .CROM update needed
  22. Disconnect battery erase tune
  23. Questions about going E85
  24. laptop diagnostic software
  25. Fasterprom's Gettysburg PA Tuning Session April 1-9
  26. Service Traction Control
  27. check engine light on
  28. Engine light is on with a DTC code or P0420
  29. •► ► CHUCK CoW TUNING @ VARARAM in TEXAS - MARCH 24-27 - SIGN UP NOW !!! ◄ ◄•
  30. Ecs
  31. Flashing CEL, no codes, 02 Z06
  32. John Rovner?
  33. Diablo Predator u 7198 question
  34. intermitent high idle any thoughts
  35. Po 492?
  36. New Dyno
  37. best way to tune a cam only diablo or hp tuners
  38. **HOT DEAL-Vette Doctors on a complete installed Vortech Supercharger Kit $6,599!**
  39. **VetteDoctors Hot deals on American Racing Headers-$1,995 Installed and Dyno Tuned!!
  40. 2 mph fuel shut-off
  41. Installing Wideband question?
  42. RSD "VetteZilla" Suspension Kit
  43. Tuners in the Atlanta/Georgia Area!!!!!
  44. DiabloSport Predator Custom Tuning Available!
  45. Transitioning from other EMS and software to HPTuner...advice please
  46. rev limiter problem on dyno
  47. Where do you plug a hand held tuner?
  48. Injectors at there max... need help
  49. Tuners in memphis area
  50. what do i ask for in a mail order tune?
  51. LC-1 Wideband ?
  52. HP tuner ?
  53. JR Rovner?
  54. help with P0172 and P0175 code
  55. LS2 MAF 97 PCM Question
  56. Wanted Tuner SW NC!
  57. Diablo Predator Tune Question
  58. Can I use HP Tuner?
  59. ***RSD NHRA Roll Bar***
  60. Can you tune the rate at which the throttle opens?
  61. Attn Tuners, Need help....
  62. tune tweak
  63. The Tuning School 2011 Seminar Schedule
  64. Dyno tuning, installs, and full builds in Richmond VA!
  65. So i got DIC code P0156 C, help. Cant seem to find what it means.
  66. E85.....special tune needed?
  67. Dyno idea?
  68. Tuner Brand advice needed
  69. What type of scanner
  70. tuners help
  71. Loss of comm codes W/updated PCM
  72. ECM help
  73. NEED HELP! 05 C6 will not start - service charging system occasionally
  74. 26lb to 28lb injectors
  75. Loss of communication codes? Need advice
  76. Tuner in Cincy/DYT/SW Ohio Wanted
  77. cat delete and tune?? on 98
  78. south GA, north/central FL tunning
  79. Trying to locate Jim aka Hex formally SWTuning
  80. ~~ St Jude Auction # 3 MSD Wires and NGK Plugs ~~
  81. PCM Fuses
  82. 02 sensor voltage to AFR translation table
  83. Looking for Z06 Spyder wheels for C5 in gray
  84. explain these bumps on my dyno graph?
  85. Wideband through AIR System?
  86. If you turn off the rear O2 sensor ....
  87. 99 corvette electrical problems! need help
  88. Seimen's 83#inj. data needed
  89. SD tune or stay with MAF tune for my needs?
  90. How to fix P1071 & P1074
  91. Check engine light = P0133 code
  92. Stock C5 Z06 Tuen or no Tune
  93. 04' Z06 stock vs diablosport tune
  94. Predator and A4 Trans Settings
  95. sct custom vette tune?
  96. Car already tuned? How to tell?
  97. Diable vs HP tuners
  98. Diablo Predator Issue
  99. Tuner in southeast IA or central ILL area
  100. •► ► MERRY CHRISTMAS & HAPPY HOLIDAYS from CHUCK CoW & CORVETTES of WESTCHESTER ◄ ◄•
  101. 160 thermo and tuning
  102. •► ► CHUCK CoW TUNING in CORAL SPRINGS, FLORIDA - JANUARY 13th - 15th ◄ ◄•
  103. Noob tuning software?
  104. Detuning with timing question
  105. Anyone use the PLX SM-AFR and DM-5 and put a plug on the DM-5 wire?
  106. My Predator
  107. Dyno Tuners near Springfield, MO
  108. Recent problem after tuning
  109. I put my car on a Dyno today.
  110. AIRAID, K&N, S&B FILTERS & VARARAM INTAKE SALE o_o
  111. Perfect Christmas gift and it fits in your stocking! :)
  112. Help clutch question
  113. Tuning out lean codes with VR power duct on HPTuners
  114. •► ► IN STOCK! - AMERICAN RACING HEADERS - ON SALE @ CoW ◄ ◄•
  115. •► ► CHUCK CoW's HOLIDAY AutoCal TUNING SAVES YOU CASH!!! ◄ ◄•
  116. Turn Signals
  117. Couple Questions: Map and MAF sensor readings; ignition timing
  118. MAF or no MAF??? that is the question
  119. Good tuner/dyno near Melbourne Fl ??
  120. DiabloSport Predator problems?
  121. Tuner and great race Shop
  122. Dyno Tuners in Greensboro, NC area
  123. HP tune program for LS1 with Hotcam?
  124. Tuners in Central Alabama ?
  125. dyno tuners in indy or close
  126. Afr
  127. dynojet wideband 2
  128. strange noise on acceleration
  129. •► ► CHUCK CoW - BOOKED in ORLANDO THURS December 9th - SUN 12th ◄ ◄•
  130. Who knows how to unlock a HyperPAC?
  131. Tuners or Dynos in Iowa?
  132. •► ► CHUCK CoW's HOLIDAY AutoCal TUNING SAVES YOU CASH!!! ◄ ◄•
  133. HPTuners...Unlicensed File?
  134. wide band quick question
  135. THE TUNING SCHOOL WILL COME TO CHARLOTTE NC, look here for details
  136. For a daily driver A4 and just a K&N FIPK and Z06 Ti's . . .
  137. C5 Newbie - Which Tuner?
  138. Throwing Rich codes on decel. Ideas?
  139. The tuning school - Is it worth it?
  140. Proctect your Lower Radiator Support/Skid plates!
  141. Larger injectors incorrect instant/average MPG?
  142. LTFT's at 25 after Blackwing install, is it related or something else???
  143. Dialing the VE table and MAF
  144. Tuner
  145. Dyno Tune Today - Cincinnati
  146. HP nc6220 P4 M 1.7GHz Notebook-$179.99-GREAT FOR TUNING! FREE SHIPPING!
  147. The Tuning School Beginners Live Seminar Tampa,FL December 7-8th 2010
  148. lookin for a tune in st louis, mo
  149. Rich trims at idle and TPS 5% at idle
  150. 2003 AUDIO BUTTON aux
  151. **ECS can now e-mail tunes via HP tuners or EFI live**
  152. Headers...tune
  153. TUNING QUESTION...I am new.
  154. O2 Sensor ?
  155. Tac Issues
  156. 31mpg highway with E85 fuel :)
  157. po code 1514 and 1278 need help
  158. 2000 FRC no start after reading PCM
  159. P 0171C and A1RDCM U1064H after long tubes+vararam
  160. laptop and tuning software
  161. Help! Which tuner should I get??? What can they do?
  162. What coolant temperature do you tune your car to run?
  163. •► ► Chuck CoW Tuning In Wichita, KS ◄ ◄•
  164. Predator tune
  165. Can the AIR system be "tuned out?"
  166. 42lb Delphi/lucas injectors settings/data
  167. Which Dyno is correct?
  168. October Special! Get your C5 Fangs for Halloween!
  169. Severe wiring issue
  170. street tune
  171. The Tuning School Beginners Live Seminar San Diego,CA November 6-7 2010
  172. need a great tuner in st.l. missouri
  173. service TCS after hard braking???
  174. Good tuners near huntsville al.
  175. Seperate tunes?
  176. Pinging with Preator
  177. Need help with fan settings w/Predator
  178. Fuel Pressure Regulator Question (looking to upgrade fuel pump)
  179. Whats should I ask for my HP Tuners
  180. Pos LTFT with Neg STFT?
  181. • • > CHUCK CoW TUNING in VEGAS week of SEMA < • •
  182. looking for numbers/facts about the 2004 C5 fuel system
  183. All of a sudden I had to reduce my Injector Slope even more
  184. Just a shot in the dark
  185. Help: DTC P0351 Ignition coil 1 control circuit
  186. NA Guys on E85 - Step In
  187. Tuner in Upstate SC
  188. Slp 7197
  189. 2003
  190. DTC C0594 Right Rear Solenoid Circuit Open
  191. ac problems
  192. Need Tuner in So. FL east coast
  193. CA Smog - Can C5 Z06 pass with Headers, Cam, Tune? Possible?
  194. Any so. Cal tuners to program pcm
  195. z06 runs rich
  196. Normal o2 mv range?
  197. 97 tune ?
  198. needhelp with tune idle 2003 cam only
  199. 2000 c5 base to 2002 z06 ecm replacement
  200. October 2010 C5 Specials - www.PartsTaxi.com
  201. Wanted: EFI Live
  202. Siemens 60lb Injectors
  203. C5 Tuning and other
  204. •► ► AUTOCAL E-MAIL TUNE TOOL @ Corvettes of Westchester - ON SALE NOW! ◄ ◄•
  205. Hypertech Max Energy programmer reviews
  206. Competitive Driving Mode Available to Tweak?
  207. Predator "performance tune" specs compared to stock? Timing help also
  208. Mail Order tunes, who's offering them?
  209. Turbonetics injecors? Scale?
  210. Predator and 91 octane
  211. 1998 corvette code p1441
  212. Noob Question difference between MAF / SD tune?
  213. General n00b question
  214. How do I get the MPG display to agree with..
  215. So nice to be tuning a vette again :)
  216. Using pin 55 (EGR) for reading in HPtuners, need help
  217. Gainesville Area: Formato Fasterproms Tuning Oct 15th
  218. Anyone using Proscan software?
  219. •► ► CHUCK CoW WANTS TO TUNE @ EUREKA SPRINGS CORVETTE SHOW ◄ ◄•
  220. installing Predator Tune..fuse removal??
  221. need help ,99,00 pcm wont flash
  222. Check engine light
  223. Virginia / North Carolina Tune
  224. Options for tuning a '97 C5?
  225. ABS Fixer- C1214 (C & H) Standard fix or Surge Supression Upgrade?
  226. Weird Warm up issue
  227. rattling noise on acceleration
  228. Someone with a Tech II in So Oregon
  229. Checking on race tunes
  230. Getting Car's First Tune
  231. Vette Doctors Performance C5/C6 Vortech Supercharger install and Dyno Tune -- $6,599
  232. Vette Doctors Performance $1,995 ARH Header (w/Cat's) installed with Dyno Tune
  233. tune needed?
  234. error codes with tire sensers
  235. Who/Where is the Best to get a Tune in Kansas City
  236. Ft Myer's and S Florida Formato Tuning Sept 28th, 29th and 30th
  237. To Ian @ Tuning School Live Seminars
  238. How many gears did you dyno in??
  239. KC area Tuners
  240. got the dreaded service steering column lock i have questions
  241. Getting DTC "insufficient switching" on O2's
  242. HELP!! 2 issues i cannot figure out with my C5
  243. September 2010 C5 Specials - Tons of New Product! - www.PartsTaxi.com
  244. P1516 Command vs Actual Throttle Position performance (TAC ,module) -A
  245. Timing Tuner hook-up for timing retard only?
  246. Help with base tune.
  247. Formato's Fasterproms Gettysburg, PA Tuning From Oct 19-24th
  248. Innovate LM2 On Sale! $100 off!
  249. the Right place for tuning advice.....
  250. rear end gear change
