- Need help tuning out knock retard.
- Predator tranny settinga
- Need help on AFR and KR.
- HP Gains
- New OBD2 scanner
- Predator warranty
- Autotap EFILive Pro and EFILive Std sale!
- Tuning the 3.15 to 3.42 change...
- My Tuning Results afer Predator.. Help?
- Getting a couple codes......P0153 and P1154
- LS1 Edit and emissioncheck?
- Modified maf?
- C5/Z06 Computers
- Predator and warranty
- What to Purchase?
- Hypertech RFG Vs. Non-RFG?
- PREDATOR REPROGRAM
- CODES
- Dyno Questions
- Predater Help
- Can u add more wot timing to a Z06 after a big cam install?
- Poll: Best Diagnostic Scanner
- What clutch to buy
- Having a dyno tune done next week, ??? inside
- Too much line pressure
- Anyone know what code 1513 on 02 Z06??
- How do you learn turning?
- Speed Limiter
- codes ???
- I need some help!
- Ken’s latest news published-New rebates, Corsa sale
- paging nevernuf/tom garland
- Ls1Edit - new code loaded - dash lights stay off - needs a reset - How?
- think about before dyno tuning
- What aftermarket injectors are compatible with an 01 LS1?
- Do I need to upgrade Predator software?
- i hypertech mine
- tune with headers installed????
- Paging James: What's the difference between Bios version 03 and 04
- PCM Part Numbers
- Tuner's in Austin, Texas area
- Autotap oil temp and gear for manual?
- Possible to burn a 2001+ image into a 2000 Computer?
- SV0 30# Injectors...what do I put in LS1 edit for them??
- Predator Fan Settings... is this right?
- Can good LS-1 Edit wideband O2 tuning be done with the stock thermostat?
- New Wideband Info
- fan adjustment
- IAC counts stuck at 310
- Timing question.....
- Dyno Tuning - Maryland
- P0101 Hypertech Programming????
- HELP! Still having trouble with new cam and hot starts!
- anyone know what all these codes are?
- Predator: "normal" shift adaptation vs. "Performance"
- GRIZZLYS AND LS1 EDIT TUNE WOW OH WOW !!
- Can't upload Predator files. Help!
- RWTD, please reply to email I sent/emailed you on 7/7
- FS: LS1Edit license, 2000 model year
- Autotap questions-help with TPS and spark knock counts
- Bought a Predator from RWTD...
- Quick LS1 Edit question...
- Quick PCM?, 99 in a 2000
- Any Tuners In Raleigh, NC
- Predator and Headers?
- "gear class" please
- programming options?
- 4.10 gears west coast?
- Autotap and LS1 Edit ?
- Anywhere in the St Pete, FL area for tuning?
- Good tuner in Nashville Area?
- LS1-Edit PCM Tuning NE Ohio and W. Pennsylvania
- LS1 Edit -- Oakland County Michigan -- 2000 Vette -- Mostly stock
- SLP 85mm MAF Tuning
- LS1 edit compared to Gm software
- TPS shows 70% with foot glued to floor
- Horsepower and Torque numbers sound low. What is the cause?
- Edit users see inside
- Initializing New Computer on 98
- Programmer and Manual Trans?
- Ken's Weekly News - July 3, 2003 - Happy 4th of July!
- Autotap & Analysis spreadsheet (MAF Flow vs MAF HZ)
- KR at WOT
- Can you put ls1 edit on a hand held?
- Torque management question
- Is there an novice's guide to Scan/Tune?
- How to get rid of Rich Idle?
- Is an AEM available for the C5?
- Predator and Window Valet
- Calling RWTD/Predator Owners.......Upgrade Needed ??
- Code keeps coming up. p0410??
- About to buy a 99, but has these H codes..
- Predator Installed WOW!! Now some ????
- EFILive 01 Z06??????
- Predator results 13.42 at Challange!
- Fuel and spark on predator
- Auto tune equalizer on the OEM radio changes evertime.......
- how to get the "EXT" temp. to read higher then 85 degree?
- P0106 code
- Tuning for Blackwing ?
- How to lean the car out at idle....
- need best bodyman and mechanic in st. louis,mo.
- KR blips on EFI-Live WOT runs
- Predator vs HyperTech???
- Knock Retard?
- Predator,Spark,Fuel
- Predator and X-box
- PREDITOR HELP ALSO
- Check engine light flashes - does NOT set code??
- Party Time LS1 Edit Just Arrived
- Predator Version 1.4
- will ls1 edit help ???
- My car still thinks its an A4?
- Predator replaces O2 sims?
- AHHH! Starting to mod my Z and getting very confused on tuning issues!
- apologize to cruise inn 4 vendors
- CODE P0113....Need to know what it is and how to correct it.
- Schematics for SAEJ1850 VPW interface cable?
- Big THANKS to James!!
- PAY FOR LS1 EDIT OR BUY THE DIABLO PROGRAMMER?
- LS1 Edit gurus...have a few questions...
- 3 people needed for ls1 edit and dyno tune in StL
- New motor and now new engine codes please help!
- Just bought 2000 vert with a predator
- ls1 edit this guy knows his stuff [BV PERFORMANCE]
- Autotap 02mv Question?
- Drop in HP at 5600-5800 rpm at Dyno
- RP Motorsports
- EFI Live Log Questions
- Predator Settings Question
- Predator and downshifts
- two newb Predator question
- Predator Help
- I need some help with code P0420 H C .. LS1 edit ?
- Predator and CAGS
- One more tuning tool :-)
- Codes: 1571 1514 1278
- Any tuning issues with m12 ?
- LS1 Edit: Conde to turn off cats?
- OTC Genisys Deluxe Scan Tool or Tech II
- please help quick (predator)
- please help I'm getting frustrated.
- cost of 99- C5-4500 miles
- Help fixing idle on a warm start with a aftermarket cam in a Z06
- CODE P0161 ????
- Predator and vararam install today
- Some Novice Predator Questions...
- Predator Questions
- live wire!
- Predator edit-feels strong first shot!
- "Predator" help needed: axle ratio supplied
- EFILive vs Autotap
- Predator on a truck
- Who is best in Georgia to do dyno/LS1 Edit Tune?
- Is LS1 Edit easy enough to use for "a non car guy"?
- Don’t miss “what’s new” this week, including 2004 Corvette Prices!
- Basic Tune Help
- Can LS1 edit set the fan to kick on at 178 degrees?
- Code help Please?!
- Wheres James?I need predator help!
- ease / scanner
- LTFT bank 1 and 2 + 10%....
- Need some Predator help here-novice!
- P 1870 code, can this code be tied to programming???
- LS1 Edit changes to help with Cam surge??
- Getting Dyno Tune in 1 week, what other features can I change?
- flashing check engine light throwing P0118 C code
- Predator shift firmness experiences
- WOT and PE questions...Important for Part throttle performance Tuning (LS1edit)
- WOT A/F ratio tuning without a dyno
- Auto tap/ ls1 edit ?
- Predetor Changes What??
- efilive #8 injector fault validity?
- Torque management with Predator
- Don’t miss “what’s new” this week!
- scan tune suspension
- Need some help tuning.....
- Service Engine Soon
- how much cam can LS1-edit tune for manners?
- LS1Edit and the A$
- OBD-2 Scan Tool Question
- TB position reading at idle?
- Predator and gear changes
- predator settings
- forcefedperformance in the sacramento area?
- Idle Relearn w/ a Predator installed???
- How do yo improve part throttle, low rpm power?
- LS1Edit, anyone tried this?
- increased fuel pressure, LTFT changed how do i get them back ?
- LS1 Edit Program
- Request C5 tuner in North Bay area/ Santa Rosa
- How can you tell if your injectors are maxing out?
- Anybody ever see this.... about GM ECM stuff..
- What does code P1571 mean?
- More trouble using LS1 edit. (Long)
- EASE vs EFILive
- Cooling fans and the Predator......
- Header Question
- Tuning places in sunny Cali
- 10% increase in PE table-LS1edit
- HypertechIII- help ,screwwed up, car won't run
- Who sells Predator in Central PA?!?!
- A/F tuning on almost-stock 99... worth it?
- 382 & 229cam - idle spd & shift pts?
- torque management on 6-speed cars??
- Best tuning approach to minimize "cruise control" effect on BIG cam..
- Locked ECM + Programming help?
- oil pressure help!!!!
- For you tuning Guru's...
- Fan 1, where are you?
- NGK/MSD wires next mod - looking for tips
- Anyone have a flash file for a t1 mti cam?
- any flash files for 50# injectors and ATI?
- Flash files for LS1edit????
- Need info on LS1 Edit options?
- Autotap results are in...very disappointed...need some help.
- LS1edit
- MAFT Starting point suggestions?????
- Idle speed a little too high until car is FULLY stopped??
- EFILive Manual
- PPL II data compare with Stock via LS1Edit?
- AWESOME Autotap Analysis Spreadsheet!!
- For those interested in PCM Hacking and self programming, scantools and flash files
- The folks at Carputing ( LS Edit ) are Amazing!!!!!!!
- Does IPW affect PE mode?
- Question about Autotap exporting data into an excel spreadsheet
- Broken Valve Spring & Bent Valve
- HELP with ATI programming problem
- SLP 6L MAF and SVO 30# Injector Settings
- GM part # for '02 PCM??
- AutoTap Start up problem
- Predator Settings Needed ......2002 Vette (RWTD ??)
- LS1 Edit, spark retard limit?????
- Injector size table. What are your numbers for 42# SVO?
- Will Removing Pre-Cats throw error codes??
- How to...
- Fan turn on temps
- dyno tuning got me....worth it?
- Reflash Computer to stock what about 3.42's?
- HELP!! IAC count too low! + DTV codes
- Problem with car detonating
- Made the trip from DC to Vette Doctors for tuning
- Ken's Weekly Newsletter Has Been Published
- corvette emblem removal
- Intake manifold water bypass question.
- Having tuning issues, i think there might be an exhaust leak???
- Where's the cheapest place to buy AutoTap Enhanced...??
- Thank u James (runningwiththedevil)
- Adjusting Cruise Control effect?
- If you need PCM tuning advice in the Northwest, drop me a line
