- Anyone have LS1Edit changes for ford 42lb'ers?
- Got LS1Edit tuning done @ East Coast Supercharging....
- Added headers, now it pings. Add fuel ?
- Palm OS PDA Dyno-Scan tool - anyone have experience?
- Check out this weeks’ news!
- Dyno Discrepancies?
- LS1Edit tuning in So Cal
- Need advice on Tech 2 in Tampa area and on coilovers instead of factory
- Questions regarding editing and scanning!! Help me decide
- how to stop P0300 code with edit
- Got confused- AUTOTAP question
- N/A ---> Nitrous what needs to be tuned
- LS1 Edit tuning in central FL???
- LS1Edit question- Advance timing
- What does the COT do if you change it in LS1Edit...
- What does the PCM do when car is low on fuel?
- Z06 feels like rev limiter at 6200 RPM
- LS1 Edit in MD, Northern VA?
- 3:42 swap tuning
- Dyno in Houston?
- who is the best tuner for ATI in South Florida
- Anyone with LS1 edit in Alabama?
- vortech and ls1 edit
- my ati car was tuned for ny, now lives in Fl and needs adjusting,
- Tuner needed in upstate NY (Albany area)
- predator unlock question?
- Anyone good with LS1 edit in the Tampa area
- CAGS and LS1 Edit
- LS1 Edit software problem
- Code C1281 ever since tuning with LS1-Edit
- tc and gears....... must you remove the code for tc slippage so you don't get a code p 0751
- Auto shift points, mph / rpm with 3.42?
- Anyone heard from RWTD?
- LS1 Edit for 2004?
- New Lingenfelter 427 add - I have questions
- Supercharged '01 C5 throwing code... need help...
- LS1 Edit -- Max Torque
- ABS / Traction control & active handling disabled
- 03 Z06 PCM Problem, Can not reset P1518 code ???????? WTF?????
- Anyone know a good tuner for C5
- What type of 1/4 improvements should I see with a good tune?
- TRQ by Gear question- LS1Edit
- FS: Diablosport - Predator programmer *NEW*
- A4 lost 3MPG around town after LS1edit... normal?
- Possible to swap a 2001+ Computer into a 2000?
- '97 runs rich from factory - Best way to lean out????
- Predator, thermo and shipping - $429.99!
- Help! code on s/c car
- Predator Tuning to squeeze out any possible HP from a 03 Z06 using 100 Octane Racing Gas
- First trip to the dyno... mods comparison
- LS1 Tunning Question
- What the F@#$ need help on this code
- Code "P0140" / I know what it is..How to fix it?
- Hypertech and Predator
- Diagnosis Ideas on my "Backfire" Condtion?
- New EASE user looking for guidance
- F-Body Guy with Vette EFI Live ? TPS only going to 70%?
- LQQKING FOR A LIST OF ALL chassis dynamometer systems/services in the SE
- Electronic Throttle Control question
- Resetting oil life
- Looking for dyno/tuner in Boise or Seattle areas
- Why? Laptop wont communicate with pcm, but will communicate with Tech2
- Measuring AFR's on a chassis dyno
- Any professional tuners (LS-1 Edit) in Hawaii?
- bad noises
- Drag wheels
- Cylinder size parameter in LS1-Edit, how-to??
- Predator Shift Adaptation on A4's?
- A4 to MN6 Conversion & PCM Programming.......
- Cylair calc.pid EFI v6
- DIC
- "Abuse Mode" questions
- Nebie Q: Predator, LS1 edit, or A-tap and custom tune?
- EFI V6
- Orange County LS1 Edit?
- first dyno run....please comment
- Is tune\edit worth it?
- LS-1 Edit and Autotap??
- AEM IS working on a LS1 ECU! Interesting....
- WB Programing C4
- Predator question for those who have one with an A4
- SAE Correction Factor - What does it mean/do to HP ratings????
- A NoGo Lesson
- LS1 edits around Sacramento, Ca??
- Best Spark plugs and wire combo to use.
- Just noticed PCM says 3.15 gears, rear is 2.73...
- help with codes
- Can you Ls1 edit after having different type of tunning?
- can LS1-edit effect traction control..bug?
- I got LS1 edit done.....
- looking for LS1 tuner South Carolina
- Reprogram by Breathless
- A challenge for you tuning experts
- Fairly Stock is it worth a DynoTune???
- Tuning on a dynojet with a wideband.....
- I got engine charge fault before...what is ti & why did I get it???
- OBD-II & PCM Tuning Books
- Anybody in Colorado that might be interested.....
- Dyno Results on a Modified 2001 with Diablo programming
- Column Lock, Please HELP!
- Stop by for the latest news and save a few bucks!
- any dyno questions to ask
- predator installed today
- what is max PE/RPM value ?
- PE tables...H & C users....
- Check Engine light ?
- Any interest ia an Ease Scan Program?
- Questions to ask LS1Edit Tuner????
- ls1 edit,Retune?
- Black Box data
- looking for LS1 tuner seattle area
- Wideband O2 meter(Innovative Motorsports LM-1)
- predator ..just got it
- Predator Question about fuse 51
- Hypertech Question...
- Edit ( IAC and Running airflow)changes for a G5X2 cam
- Need temp settings for fans when changing to a 170 Thermostat.
- New LS1 user, Help please!
- pulling cats what do I toggle off in ls1edit
- MAFT Changes Get Learned Out?
- help..car wount start?code U1160, u1176
- Headers and exhaust (does it need tuning?)
- North Carolina LS1 edit tuner
- LS1 Edit install files
- Z06 85mm MAF: ISO mass air flow vs pulse width/duty cycle table
- Is my A/F ratio too rich for my setup?
- ok, the end all be all post of predator parameter setting changes
- Lower numbers on Dyno but faster at track?
- C5 tuner in the Atlanta-Columbus-Auburn area???
- After $2700 in mods results of recent DYNO tests
- Where to buy LS1 editor
- Benefits of Tuning for MN-6 '99, questions
- bad detonation after header install ***help***
- [LS1edit] swap stock converter to the yank3000 on 3.42 HELP!!!!
- New EASE version with "turbo" mode???
- All you DC Metro drivers- finally found a tuner with LS1Edit in the area
- I need of some serious tunning advice
- New LS1 Edit tuning forum
- LS1 Edit tuning, who can do it by e-mail?
- HELP HELP HELP HELP !!!
- FastChip - Ed Wright Custome Tuning
- Need Help! Engine sluggish/Borrowed AutoTap
- Predator Version 1.04
- alignement specs for a coil over shocks suspension
- HELP!!! with 3.42 and YANK3000 converter!!!
- Best way to "flatline" air/fuel ratio??
- Laptop For EFI Live
- what do 97 & 98's do for custom tuning....already searched
- I need help with a code.
- PLEASE HELP
- My DIC says the car is running lean....
- TUNING OUT ABUSE MODE
- Predator Issues HELP!!!!
- my 99 has low washer fluid on dash, new sender, still on dash
- can someone tell me exactly what is an LS1 edit?
- Anyone in Austin have LSEdit?
- Anyone in colorado with LS1edit?
- Help someone!...newbie(Predator).
- Looking for a LS1 tuner for my Z06 in the Cinn/Columbus - Ohio areas
- New LS1edit Tuning Forum
- Air / Fuel ratios
- Where are you James???
- Need More Help (408 Iron Block)
- Need help with LS1 Edit
- Anyone get any "Pending" DTCs in EFILive
- Predator Custom Tune
- Values for BRAKE PRESSURE & BASE PRESSURE vs TORQUE TABLE
- Can you load Predator tuning OVER existing PowerloaderII programming?
- Idle relearn, AFs, and spark retard
- Looking for recommended LS1 Edit Tuner in Chicago Land area.. Anyone?
- LPE's Magnacharger prog. locked, not possible to change with LS1-Edit??
- LS1Edit vs. Predator??
- What's the latest version of LS1Edit available to the public?
- Check out this week's news!
- Who's the best LS1 Edit tuner in Southern California???
- Andy Pilgram C5R headlights
- Lots of Pinging down low in RPM
- What is this item?????
- Predator settings for truck?
- Predator Problem, can't return to stock tune
- Need Tuner In Southwest Florida.
- Now fine tuning with Predator-C5 running real strong.
- new power programer for the Z06
- BVPerformance - LS1Edit. Thanks Brian!
- Anyone zero out IAT table on nitrous?
- good LS1 edit tuner in eastern Massachusetts
- LS1 Edit: Desired Shift Time
- Basic LS1 Edit Question...
- LS1 EDit does not work after......
- Ls1 Edit.Code 10pcm.i'm worryied.
- auto tap sample rate?
- Does anyone have the new Escort GII or GI Timers?
- Some One Help (Predator)
- HP Guess
- [help] Reading a dyno graph
- Reprogramed thermostat
- Cheers to RWTD (JAMES) again
- Low Octane fuel map?
- My PCM went poof while using LS1Edit
- 160 Deg. Stat
- Adding timing.
- LS1 Edit Settings when going from 2:73's to 3:42's ?
- LS1 Tunning Advice For my Setup
- MAFT, 25%rich base setting, does this sound right?
- Adding a mod maf to a LS1 edit tuned car?
- Impression from new Predator Owner
- Loss of power in second gear. help.
- Predator V1.04
- Predator Re-Set?
- anyone in sacramento area out there good with ls1edit ??
- Tuners in SO Cal
- Had the LS1 edit done today.334hp,341tq
- Has anyone tried putting predator?
- Tuners in Denver, CO
- Predator PC ???
- Bump steer, any one else notice it?
- Top Speed Limiter? How High Stock?
- Will LS1 Edit work with Windows XP?
- Seeking Autotap user in Baltimore area
- Predator reset?
- LS1 Edit tomorrow What to expect on base line?
- WHAT OTHER MODS SHOULD I PERFORM
- Low cost wide band..............
- Scailing wheel sizes in LS1-Edit
- tune stock c5
- Should I use Hypertech PowerStat on C5 ?
- Poll: Danger of LS1Edit Flashing
- Paging all tuning whizez - interpret this
- Pagin DiabloSport
- "Tune" Advice PLEASE!!!!!!!
- What is stock rev limiter set to and what is safe?
- Help!Just ordered LS1 Edit
- What is ideal timing at WOT for power?
- 00 M6 Bosch 42# with ATI SC... Anyone have an .LS1 file
- done with my modding whats next???
- Can we get JUST ONE CABLE?
- Advantages of a Tech 2???
- Pro's and con's of LS1 Edit
- Hey LS1 Edit people,I've arrived!
- Dyno tuning in MD
- Just did 2.73 to 3.42 needd re-program in ATL
- codes ???what to do now?
- Predator and re-calibrated iat sensor
- Predator Question
- CAGS elimination with Predator
- Check it out!
- Predator and dyno results!
- HELP!!!!Lost communication while programming with edit!
- Need help tuning out knock retard.
