- Wester's computer programming
- A.I.R. psi ?
- Anyone in Dallas/Plano area with a scanner I could test to see which one to buy?
- mileage
- (RE-POST) Please Help! What size rims will fit my C5? 20",19"?
- Tuning questions
- Usb or serial?
- MAF table with 85 mm MAF ends and no screen???
- LS1 EDIT??? How $ & Where?
- What does code P1416 AIR System Bank 2-B mean?
- Can I get a PCM update without going to the dealer?
- When do you need a tuner.....
- What are the minimum miles before LS Edit ?
- Predator Info
- Hypertech vs Superchip???
- NEEDING A LS1 EDIT
- Transmission Fluid mixing.
- Southeast Pa Tuner
- ltft difference bank 1 and 2
- Need to add 50 Horses to my Vette,,,
- Techedge WB replacing the stock O2 sensor
- GP on Wideband Commancer
- Predator Rocks!!
- Loyal customer paging James@RWTD
- DIC code reading.
- Jet power chip
- Autotap-How many parameters to monitor for best log?
- 2003 vette PCM data field definitions values chart available?
- Tech Edge WB
- Predator Results on 02 Z06?
- Predator LTFT question...
- Is the so called black real?
- Who has the best deal on LS1 ECM programming
- Anyone using a Palm Pilot based scanner on OBD 2 cars?
- What's New?
- Predator for a 1998 LS1
- Tuning Questions
- how long before ltft adjust?
- Allow TCC lock during shift???
- James, Predator for the 04 yet??
- New O2 Wideband Product
- anyone know how to use ls1 edit to fix start up idle issues
- How long does it take to get LS1 Edit shipped to u?
- looking for a GM LS1 LS6 flash file.
- B&B triflo exhaust
- Predator Results
- I have a PCM code that's not listed in my documentation?
- Can anyone tell me how to reset the check engine light?
- tire monitoring system not active, please help
- Fine Dyno'ing: All Chassis Dynos Are Not Created Equal.
- Autotap for USB and other updates!
- Injector percentage 90%, do I need more fuel pressure?
- LTFTs changing all the time
- Program for my laptop?
- LS1 edit for ZO6 in NC?
- Take a peek!
- Blackwing cold air shroud surging. Could this be tuned out?
- LAPD GRAND OPENING OF SHOP FACILITY SPECIALS!!!!
- What are people using to tune/program a 2004?
- ls-1 edit
- Questions about a scan/tune setup
- How does the Diablo "Performance Tune" compare to stock?
- LS1 edit gurus inside
- The truth about tuners!
- Predator Performance Expectations
- GM Technical Info/support contacts (Engineers, etc)....Anybody have some?
- Checking Interest
- Help needed analyzing Autotap Data
- MSD ignition??
- How do I get rid of KR of 9.9 degrees?
- PacificNW LS1Edit purchase - want 3 more to share and get low cost
- C5 Tuning in FL
- Need Help!!!! LONG
- ls1 Edit and timing ??
- Buying a laptop today for edit. Which one???
- auto tap
- Tuners in Phoenix AZ
- Twin Flow Air Intake Needed?
- Installer tuner Boston Mass Area
- Topic: Auterra OBDII scanner
- does anyone have a list of codes
- Bailey AFM1 Wideband->Where to go through the car?
- ls1edit ??
- Effect of zero LTFT at part throttle?
- would like to D.I.Y. service
- Will ls1 edit affect diagnostic emission test?
- obdII code p0172
- stock injectors
- Tuner in west texas? Midland area.
- my first MOD :)
- USB port & LS1 edit -Autotap
- AC Unit Not Working Please Help!
- C5 Newbe - EFILive - Best Setup for Dragracing???????????????????????
- Looking for tuner in Atlanta, Ga area
- hypertech products
- Cobra 9210
- LTFT's - How to best correct?
- LS1 Edit and new laptop
- Just got EFILive, how can I diagnose misfires?
- Cruise Control Effect
- Spark Plugs
- Any recommended tuners in Richmond, VA?
- Service Column Lock Soon
- Denso Iridium Plugs
- Learning and would like your opinion on my EFILive scan log
- Tire pressure sensors.....need help
- AFR adjustment Help!!!!!
- Aprrox. Horssepower based on MAF reading?
- LS1 Edit vs Predator ?
- Change 2002 camaro predator to 2004 corvette
- Ls1 vs. Predator air/fuel difference
- Fan settings for a 178 T-stat on a Predator (James-RWTD)
- PCM Question
- LAPD GRAND OPENING OF SHOP FACILITY AND DYNO DAY SATURDAY JANUARY 24, 2004!!!
- Happy Holidays, Latest News Posted Here
- OBD2 emissions scan with the LS1Edit AIR/EGR disable
- O2 Voltage vs Air/Fuel Ratio Relationship?
- EFILive Price increase at the biginning of the year!!!
- Just want to say, "Thanks!" to James (RWTD)
- PC Based Scanner only?
- Strange smells when I punch it ????
- LS1 tuner in the panhandle of Florida
- Please Help! What does the Code C1288H mean on the IPC
- anyone have : LS1 Edit in Rockland County , NY
- What does this mean? LS1 Edit ScreenShot
- Where to get LS1 edit.
- Buy your Autotap now - BIG price increase coming soon!
- Magnuson Fuel Injectors (Rating)
- Tuning Newbie
- Adding mods,retune engine?
- What does the Predator base tune change?
- Effects of LTFT's on PE-mode fuelling?
- need a tuner in central ohio
- Looking for a tuner in North Carolina
- Tuning help Please / Blackwing & GHL Exhaust/ & EFILive
- Help with codes after LS6 Intake swap
- Cooloing Tune Question
- 2002+ ls1edit users should read this
- Finally, High vs Low Octane explained
- LS1Edit file Viewer?
- Wildly varying O2 sensor voltages with Predator
- Anybody in the Houston area
- No Comm from all the codes... Any ideas
- LS1 Edit and EFILive - Tuning/Learning sources
- Which version EFILive Standard or Pro?
- Chassis Dyno VS pcmforless.com VS Hypertech/Predator/other
- Can I...
- Anyone know when the AEM will come out for our cars?
- Sigh, first drive in a month
- Next Q: EFILive vs "regular" ATAP? What does the extra $150 get me?
- Help? my car doesnt run PLEASE READ
- How are my LTFT's / KR?
- Happy Holidays, check out the latest news!
- Will I lose my LS1Edit tune program if I disconnect the battery?????????
- Just installed Predator... initial impressions
- Tuning with a laptop.
- LS1 Edit owners- how do you tune the car?
- I must plead dumb for a moment!!!
- East coast edit tuners...any specials?
- Had car tuned by 2 different tuners - need advice.
- December Sale of the Month - Predator programmer package!
- LS1 Edit : Reversible ?
- Ideal/Optimal Amount of Timing
- PCM Codes - Running Lean Bank 1 + 2
- Thanks to C4C5-Tech, you rock!
- Tuned and confused
- HELP, check engine crap!
- Can't up rev limiter on M6 Z06 with predator??
- LS1 Edit in Massachusetts or New Hampshire??
- Happy Thanksgiving, check out this weeks’ news!
- LS1 edit ?'s about ditching the maf and using a 2bar
- Is there a place where people share their files?
- Finally found someone to give my car a real tune... but
- LTFT, WOT O2 readings, and the Predator. (Paging James)
- Tire pressure warning
- Any good tuners by internet??
- No Traction Control but no messages
- PCMforless.com? Anyone tried it?
- LS1 Edit Tuner in Dallas area
- LS1Edit in SF Bay Area, or group tune for traveling tuner?
- excessive time to centre steering--C1283
- What can you do with Predator???
- P0160 and P0140 after header install
- Is there a table in LS1Edit to change the MAP mapping?
- ABS, Active Handling, Traction Control
- LAPD's -Edit 1 Tune Up
- Hitting 1-2 rev limiter on 1/4 mile run...Why
- LAPD"s Edit-1Tune Up
- Tuner HELP - dangerous to my magnuson?
- 2004 A4 stock dyno numbers
- Value of Long Term Fuel Trims for Stock Cars
- Predator for the 2004....When?....James?
- James (RWTD).... are you out there?
- LS1/LS6 Tuning Book Recommendations!
- What should i expect to pay for a cam install and spring upgrade?
- Predator web site? Anyone have the web address
- Whatever Happened to James and RWTD?
- Anyone used the Predator on a M6?
- New or Old?
- Dynotune Pricing (located in Chicagoland)
- IFR/MAF changes and questions...
- Service ABS, Service Active Handling, and Service Traction Ctrl!!!!
- Flippin Light / Predator?
- Check out the latest news and more!
- bought auto tap
- G-Tech Pro & other Performance Meters
- Best Tuner in Orange County (LA AREA)
- Install Instructions for V 1.3
- Rich vs. Lean
- How are my #'s after Dyno Tune?
- Help with idle issues please
- Why are Dyno numbers lower for higher rear end gear ratios?
- Dry Nitrous post your A/F and what kit
- Air/Fuel ratio gauge question...
- Air/Fuel Controller from Halltech
- basic performance help
- Looking for MECHANIC in or near Los Angeles, (Santa Monica) CA area.
- Got her dyno'd yesterday... chart within - Need help
- Best Filter and Oil
- Custom MAF tuning question
- Quick Question Please Help!
- PREDATOR, SERVICE AFTER SALE????
- predator results
- Another Happy Predator Owner
- Predator + ATI s/c..... Can it be done??
- Tuner in Central GA???
- Need tuner and good shop with no attitudes in Phoenix Az
- Solid rollers w/ edit check-in please!!!!!!
- Need HELP!!! with codes =(
- Any Tuners in NE Ohio?
- LS1 Edit
- D.I.C says NO COMM. car won't start
- What would be involved with putting in a year 2001 pcm into my 98 C5?
- Predator Rev Limiter Question
- LS1 Edit - Question on gains
- What do I need for a Mag Charger
- ls1 edit tuners that travel???
- LS1 Edit in St. Louis area???
- Can LS1 Edit file be emailed?
- LS1 Edit V1.3 Brake Torque Timing table
- Do O2 Sensors Wear Out?
- SALE ON 04 Z06 SHOCKS!!
- pcm replace now ls1 edit won't work?
- Scaled Fuel Curve Also Scales DIC Mileage Calc
- LS1 Edit The Vette Doctors Amityville, LI NY
- Best way to adjust timing with LS1 Edit
- LS1Edit- So I'm full of questions- 1 more
- LS1Edit- next question- need to config for 10 % richer
- LS1Edit -Can somebody answer these questions?????
- Does This Seem About Right???????
