View Full Version : C5 Scan & Tune
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 [25] 26 27 28 29 30 31 32
  1. GM updates
  2. looking for 98 c-5 stock flash
  3. VE Table tuning
  4. 98 Camaro--->97 C5 tuning software ?
  5. Ltrims out of control?
  6. Does this sound like false knock?
  7. For those using HPTuners - What do you think of it?
  8. ?'s about HPtuner
  9. P1133 and P1153 codes... Are the 02s dead again?
  10. P0151HC and P0300H code after header install. Help?
  11. ANY OTHER GTR's OUT THERE?
  12. Front Transverse Spring Bushing GONE!
  13. Z06 ls1 edit tuning with bullet exhaust vs Ti exhaust
  14. LS1 Edit, Predator, etc. -- Subscription Fee?
  15. Predator: bottom line gain?
  16. A/F Ratio
  17. EFILive6 question
  18. For those who can't decide between Edit and Hptuners
  19. HP Tuner report
  20. Remove check tire sensor code
  21. LIMITER ADJ
  22. Codes, Codes, Everywhere I look...More Codes...ARRGGHH!!!
  23. what is tourqe managment ????
  24. Check Engine Lite
  25. LS1 edit/tuners in Balto/DC area
  26. Phoenix Autotap help needed
  27. a-tapv1 and 98 vette?
  28. Detonation need some help!
  29. List of the best Corvette mechanics/garages in Houston area
  30. A change in LS-1Edit?
  31. New Predator Tunes
  32. Downloading Predator Program Question
  33. Factory Settings Z06 03 vs 04'
  34. De-Coder's Check engine and P1133
  35. new hp tuner
  36. Recommendation on a good tuner in the Northeast Ohio area?
  37. Predator Use With Other Programmers
  38. Off Topic: What's a good program to tune...
  39. speed sensor problem -Traction control problem
  40. Anyone know an LS1 tuner in Vancouver Canada
  41. Does anyone know of a good tuner in KY?
  42. O2 sensor ??
  43. LS1 Edit in the St. Louis area?
  44. Anyone with a Tech II in Columbus Ohio area?
  45. Anyone used PCM For Less?
  46. Good place near in orlando or kissimmee to do LS1 tune ups.
  47. A/F leaned out, more horsepower?
  48. 2.73 to 3.42 differential upgrade on 99 A4, hypertech vs predator?
  49. new Trouble Codes
  50. Predator Custom Tunes
  51. O2 voltages on the bottle
  52. Need parameters for changing to 3.73 in A4 - LS1 edit
  53. service vehicle soon
  54. LS1edit question
  55. what forum tuners are using hp tuning?
  56. ANYONE successfully tuned the 90mm TB/Manifold combo?
  57. Traction Control Problem, 97 six-speed
  58. VE table
  59. Predator: download update
  60. Least $$ to correct rich A/F w/ only Blackwing
  61. My day time running lamp keeps burning out
  62. WHY DID MY PLUG GO BAD?
  63. Oil Pressure at 80 PSI is this normal?
  64. How do you turn off 02 with edit?
  65. Need a little help with auto tap
  66. preadtor vs. ls1 edit
  67. A4 shift duration times.
  68. Wideband sensor location
  69. PCM Changes for different torque converter
  70. a4 with 4.10 file
  71. DynoJet Commander vs LM-1
  72. Crane Power Tuner
  73. Thank you for the tip on parts
  74. How to disable TM?
  75. LS1Edit V1.4 s l o w. . .
  76. Review of HP Tuners Software
  77. C-5 Rich under 2000RPM
  78. If you want a Predator, Don't call RWTD or James !!!!!!
  79. need a PCM for my 2001 LS1
  80. codes P0300HC , P1571H and check engine light
  81. seek 35k mile tune advice
  82. 02 28.8 injectors in a 99 what to change
  83. Engine code help.....
  84. Computer Relearn - Disconnect Battery or Pull Fuses???
  85. [Misfits] Local Florida Events!!!
  86. Help! Headlight retraction noise
  87. Rear o2 codes - using Sims but still coding
  88. Help with P-1416 code
  89. Dissapointed with LS1 edit.
  90. Change MAF, require a new A/F Ratio adjust????????
  91. Check Engine Light
  92. where did you start with edit?
  93. help w/ turning off check engine light
  94. Help! TCS, ABS, and Traction control not working.
  95. Head and Cam GP - for the after tax set..
  96. Help! TCS, What is TCS error code 1247 and 1283?
  97. Detailed tuning Question on IFR to LTFT and the dreaded P/N Decay table
  98. dynojet update
  99. A stupid question...where do you plug in the cable for LS1 edit??
  100. turnaround on edit??
  101. Help with tuning on 98 w/ 3.73s & pt2400
  102. Need Help Check Engine Light Code reads P0200 HC
  103. Ideas for New Radio Unit for 2000 FRC
  104. MAF-T and Autoatp Tune success
  105. James.... are you out there?
  106. Editing cells cheaply?
  107. help with hosting an MPEG of dyno run
  108. Codes: What are P0136 and P0156??
  109. Looking for tuner in Columbus, Ohio area
  110. LS1 Edit...USB Ports Only...What Are My Options?
  111. Anyone seen RWTD??
  112. Hypertech Power Programmer Plus for 96-99 GM
  113. Anyone ever hear of "Superchips Model 2725 Max Micro Tuner ?
  114. Am I too rich?
  115. Tune\Edit Gains.
  116. Predator and AH/TC
  117. Tuner in Pittsbugh, PA area
  118. Tuner in Washington DC area?
  119. 04 LS1 Edit
  120. What AF typical or optimum for stroker--
  121. Z06 H-pipe and code P0430
  122. DTC 1571 code
  123. Ls1edit and pumpshot?
  124. ls1 edit ? and header
  125. Need Stock 1997 C5 .ls1 file
  126. Is a P0300 misfire code normal after H/C & no tune?
  127. Does it help to reflash PCM ??
  128. Granetteli MAFS
  129. Paging Hool97
  130. big problem?
  131. maxium torque
  132. Code P 1431 H What was it?
  133. LS1Edit Tuning for a Vararam
  134. Bizarre... Service Active Handling / Traction control
  135. 02 Vert Fuel Tank Sending Unit Connection?
  136. Turn Signal Bulb keeps burning out... no moisture present. Any ideas??
  137. Headlight Winking problem
  138. Scaning/logging software?
  139. Tuning for emissions... can it be done with a 222/222 112 LSA?
  140. LS1 Edit and ODB-II emission testing
  141. Tuner question!
  142. Do I need LS1Edit or Predator?
  143. Predator Tune ? Questions
  144. Does CARTEK 'lock' PCM codes when they tune?
  145. any good tuners in southeastern Wisconsin
  146. gear install any edit needed?
  147. Hypertech???
  148. Predator Version 1.04 Still Missing in Action ??
  149. Predetor tune for 3.42 rear on C5
  150. HELP! What does code P1514 mean?
  151. AUTOTAP NOT recording WOT Wideband O2.. Anyone know why?
  152. Latest 2005 C6 News and More!!!
  153. Need to record sensor data without a laptop or palm
  154. just added a blackwing and the Service Engine light is on
  155. Competition for LS1-Edit
  156. LS1 Tuner needed in Louisville, KY area
  157. need help finding local tuner
  158. 97 wiring schematics needed
  159. Code question: What does this code mean? PCM-1416 HC
  160. codes are in...
  161. MAF location
  162. Code help please
  163. Any good tuners in OHIO
  164. Need stock 99 A4 3.15 file
  165. spark plug wires (differance between)?
  166. More LS1Edit questions
  167. PREDATOR VS LS1 EDIT
  168. Fraudulent use of Predator.
  169. EFILive and LS1 Edit
  170. I have some autotap data.. WHO can interpert them for me?
  171. Have 99 LS1edit, can you add a 00 to the cable?
  172. Basic ls1 edit tune
  173. LS1 Edit group purchase in Eastern Canada?
  174. General adjustments on an A4 with the predator?
  175. New Editor
  176. does this make any since (TM GURU hopefully)
  177. Will car run with new cam and old tuning.
  178. 2002 Z06 Head/cam
  179. LS1 Edit tuning questions
  180. I broke my PCM, 10-pcm no comm. error
  181. Innovative Wideband
  182. PCM TACH Signal -- Voltage Range??
  183. Installing 3.73s on a 98 ?
  184. How many degrees spark advance at WOT
  185. Thanks RWTD
  186. FICHTNER CHEVROLET SPRING SPECIAL 03/05/04
  187. ECM replacment ?
  188. LS1/A4 Techie opinions please
  189. New Toy
  190. Disconnect battery resets LTFT? What about my tune?
  191. Need suggestion on idle setting with new setup (LS1-Edit)
  192. LSI Edit in Utah?
  193. SF Bay Area Tuners
  194. predator tnstall
  195. Chicago area members............LS1 Speed open house
  196. (Dallas Area) Best place for LS1 Edit in DFW area?
  197. Need help clearing codes using the DIC
  198. Injector Offsets - Lucas/Delphi 36lb inctrs???
  199. What is burst knock?
  200. 2.5 vs 3inch pipes c5
  201. Pace performance MAF for LS1-LS6 conversion.
  202. superchips
  203. MAF High-Frequency DTC when I go into boost
  204. Who has the best price on EFILive?
  205. 2004 A4 IDLE ?
  206. Help With Code P0442
  207. Code help please
  208. Timing & KR????
  209. Speed Density tuning--anyone have it done-where-
  210. Newbie to tuning, I have some basic questions
  211. LS1 edit?
  212. Hey all you scan gurus, what does this mean?
  213. Anyone Heard from James RWTD Lately?
  214. Denso spark plugs
  215. FICHTNER CHEVROLET PARTS SPECIAL..EXTENDED ONE WEEK 02/27/04
  216. Whats involved tuning wise, going from a 97-00 MAF to a 2001+ MAF?
  217. Anyone willing to autotap my car?
  218. Guidance for a neophyte tuner
  219. Friend trying to sell his Predator
  220. EUROPEAN INSTRUMENT CLUSTER
  221. Given the extent of my Mods will a Hypertech Power tune help or hurt?
  222. Scanner for only pulling and reading codes. Equus or Actron OK?
  223. Anyone know how to reach Mike Morgan?
  224. Steering column locking recall reflash PCM?
  225. Tuning issue? TC RemovED, BUT When power braked, still launches sluggish.....
  226. EASE report with MMS then TeamZR-1 tuning
  227. -------Question about computer relearn after mods-------
  228. C1233 RF Wheel Speed Circuit Open or Shorted
  229. HYPERTECH
  230. placement of wideband sensor
  231. Total Timing ?
  232. LAPD GRAND OPENING/DYNO DAY SATURDAY MARCH 13, 2004!!
  233. Tuner in So Cal quick
  234. Cat codes shutoff help
  235. Diagnostic Scanner Recommendations??
  236. Header Tune?
  237. Disabling TPS...Can the dealer do it??
  238. x pipe
  239. Save 10% at VBP-Vette Brakes & Products, Inc.
  240. Any good source for the LS1 Edit in Northern Colorado
  241. Need help- Have Codes
  242. ecm location
  243. LS1 injector "size" on offsets...
  244. A/F ratio help
  245. ls1 edit
  246. LS1 edit?
  247. Am I screwed?? please help...maybe James has answer?
  248. Those with data acquisition software...
  249. B0026 Code?
  250. Wester's computer programming
