View Full Version : C5 Scan & Tune
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 [24] 25 26 27 28 29 30 31 32
  1. Motor build-up questions ?
  2. Where can I get my car dyno tuned?
  3. Group Purchase on Vinci Turner
  4. What to Change for Cam/Head Swaps
  5. 2 Questions T/C lock and force motor pressure
  6. HELP! My car keeps throwing a P0106 and now a P0300!
  7. Cold Air intake
  8. Difference between 3.15 & 3.42
  9. Will the Vinci Performance Programmer fix this problem?
  10. need hptuner bin file for 2002 'vette
  11. 160 degree thremostat
  12. 98 C5 Heads/Cam/Headers. What is the best programmer I can buy?
  13. updating 97 MAF to 01Z MAF
  14. Best Temperature-stat
  15. How Long Does It Take To R&R The PCM ??
  16. Tuning needed after changing heads?
  17. Tuners and Licensing
  18. Tuning HP/LS1 Edit??
  19. File to share or help with IFR tables for 42# injectors
  20. problem with the thermostat
  21. lowering problem
  22. Question about the techII mods
  23. Question about Halltech TRAP-Tunnel Ram Air Pak
  24. Anyone use LS1Edit 1.51?
  25. Was it worth it? Getting Dyno tune on stock C-5
  26. IPOD in C5
  27. Anything I should really be looking for.
  28. Powerloader, Reflashing PCM to Stock, LS1 Edit - Need HELP!
  29. 3.42's and the blues
  30. head/cam swap, tuning after?
  31. Problem reading Superchips Magnacharger calibration
  32. newbie "?"
  33. I have a big problem folks... and NEED HELP!!!!
  34. 8995 RPM REV limiter in 5th ????
  35. Best way to upgrade my computer?
  36. Varavan
  37. Where is blowor motor contol module
  38. A4 shift point Changes with new gears?
  39. Need scan tool
  40. Predator for 2004 MN6..what am I missing?
  41. logger program?
  42. 04 Speedometer Cal
  43. What's wrong with my clutch?
  44. Vinci
  45. Whats an SDM Code?
  46. Rearend and Warranty leaning toward 3.15 cost
  47. Help...Check Engine after exhaust install
  48. Traction control - Competetive driving
  49. Rearend and Warranty?
  50. Spark Plug Gap
  51. which relay for rdcm?
  52. My GM Dealer told me......
  53. 2003 Z06 bin file?
  54. Torque weights for the crank shaft
  55. p1120 p1220 p1516 TAC module bad?
  56. Car bucks between 1500-2000 while cruising after 42# install
  57. Please help. Bulb Removal
  58. What's this? "Service Traction Control", "Service ABS"
  59. TUner software
  60. help car throwing codes batt. #2fault
  61. Misfiring injector
  62. C1226 - Does anyone have experience with this code?
  63. Fan Temp set up by using Predator..Which temp?
  64. Dealer est: $2100 for new clutch! Berger Chevrolet, GR Michigan
  65. Where can I buy a copy of LS1 Edit?
  66. Looking for inexpensive tune in DFW area for 98 Vette. Can anyone help?
  67. What does this code mean exactly?
  68. fan temps on edit
  69. Looking for help with Predator
  70. 1st to 4th skip shift not woking?
  71. installed LGM longtubes, getting 135 and 300
  72. C1214 Solenoid Valve Relay Contact or Coil Circuit Open -- ????
  73. AFR tuning - First attempt; Predator and LM-1
  74. 1225 CODE. Throttle position sensor. What causes this code?
  75. Programmer for the garage or the track
  76. Tuner? Bullhead City, Az. Laughlin, Nv.
  77. 2001 z06 oil pressure
  78. new tune after lifter install?!
  79. Why Aftermarket MAFS and MAF Ends do not work
  80. Need help with LS1 edit first time use
  81. Bolt-ons only + Gen 3 MS pcm tuning = 405rwhp!!
  82. Fuse box help
  83. Can you make the A/C Compressor stay on during heavy throttle.....
  84. Rear end fluid
  85. Latest 2005 C6 News and More!!!
  86. DTC c1282
  87. No reprograming needed?
  88. Tuned it - SOTP DIFFERENCE!
  89. Anyone in Arizona have HP Tuner for a '98?
  90. ANYONE INTERESTED IN A LAPD DYNO TUNE GP?
  91. Need a starting point for ATI procharger LS1 edit
  92. How much total timing?
  93. How much timing do stock C5s like? Also PE questions
  94. here are my AFR graphs from Innovate; opinions wanted
  95. Dyno'd
  96. LS1Edit flashfile?
  97. Best plugs are iridiums IX?
  98. Best wideband meter?
  99. Code PO342
  100. Do i need to be concerned with pcm (tranny code) 0705?
  101. what are the Best Spark Plugs
  102. if my car only runs good with octane booster, does it give me an idea of rwhp limit
  103. Going from 3:15 to 3.42. Reprogramming needed?
  104. Tuning Hardware: Several Questions
  105. Hi-Speed Missfire in 427 with FAST Intake and 90mm TB
  106. help me make a list! please
  107. Seattle Based Tuner?
  108. Summer recomendation
  109. EFI Live...Way to find date codes were thrown?
  110. Tuning for Dry Shot
  111. Changing tire size. Do I need to reprogram computer?
  112. Looking for factory HPTuner .bin file for 2001 C5 Coupe, 6spd
  113. EEC Bin Editor
  114. Allow TCC lockup during shift
  115. Uncoiding Diagnostic codes
  116. New to tuning PCM's and could use a little advice
  117. Where do I get it worked on?
  118. Latest 2005 C6 News and More!!!
  119. Thin head gaskets?
  120. F55 UPGRADE COMING! VERY LIMITED AVAILABILITY- PRE ORDER NOW!
  121. Recommended Shift Points for A4 3:15 Using Predator
  122. Help!!! Service Steering Column Lock up :(
  123. Best Scanner for Pocket PC???
  124. Anyone used the Predator to adjust shift pressure for jerky shifting?
  125. 1998 C5 Mystery noise when accelerating.
  126. Code P0103
  127. HP TUNER
  128. Whats the verdict on the HPTuner?
  129. Question about tuning a Procharger
  130. Help Auto Tap and 1134 Misfire counts on cyl 7
  131. my car bucks like a bronco
  132. 98vette auto..no power on low end "help"
  133. HP tuners for 97's
  134. car goes in to "reduced power mode" after hard launch on street
  135. Any experiences with East Coast Supercharging????
  136. Does anyone have a file with the stock PCM program that I could copy
  137. rise compression by grinding the cylinderheads
  138. LS1 Edit question -- Mods installed (FINALLY) but can't get to the tuner....
  139. Ls1edit.com file library
  140. Can HPTuner be users on a locked down PCM
  141. Help with GM Scan tool in Minnesota
  142. Need some help with codes: P0430 & C2120
  143. Tuning @ L.A.P.D: They are for real!
  144. Where can I find out more info about HP Tuner?
  145. Tuner in Kansas City, MO Area
  146. Need Help with Codes - ABS, Active Handling/Traction Control
  147. What's new?
  148. Transmission algorithm changes..can this be done?
  149. Street Pro - C5 Electric Cutout Sale
  150. Nitrous Tuner In SoCAL
  151. Engine Miss
  152. Anyone else toss their mass air flow sensor?
  153. When is it best to shift gears when at a street light?
  154. Can turning off the traction control improve performance?
  155. HPTuner 1.3.0 has just been released
  156. Anyone Use this??? Windows or Palm OStm OBD-II Scan Tool
  157. Inattention can mess up your tune!
  158. new cat back and halltech stinger - do I need to retune?
  159. Hypertech or Predator
  160. HP tuner and traction control
  161. Any interest in HP Tuner for 1997 C5's????
  162. About to use LS1 Edit for the first time. Need your advice...
  163. Predator Factory Tune Backup and Dealer Reflash
  164. what are u codes
  165. Street Pro - Performance Exhaust - New Supporting Manufacturer
  166. Where's the PCM connection?
  167. Disabled VATS, car still wont start, phelp
  168. Where to purchase LS1 edit
  169. Tuner in the Baltimore area
  170. autoxray!
  171. LS1 EDIT?
  172. Looking for a tuner Chlt, NC
  173. Timing ?
  174. Threw 2 codes this evening....
  175. any way to erase ls1 edit
  176. HP Tuner or LS1 Edit?
  177. Quick KR questions...
  178. Does anyone know why this is going on its weird!
  179. Showing KR in 3rd at WOT but not 2nd
  180. scanner ???
  181. C1281 & C1743
  182. Air pump solenoid vacume line routing...
  183. 2 codes tonight, need help with what they mean.
  184. DTC codes after LS-6 Intake help!!
  185. SHIFT POINTS SETTINGS...ADVICE?
  186. Any codes that would make my PCM think it is receiving 25 volts and shut down
  187. Help, do I need bigger injectors??
  188. anyone with a 1998 Magnuson PCM file ?
  189. North Cal. engine tuner???
  190. programming a4 with hp tuner
  191. HP TUNE CORD??
  192. Possible to buy LS1 edit without upload cable?
  193. Upgrading LS1 to LS6. PCM files for HPTuner out there yet?
  194. fans not working after ATI install
  195. need tuning on my car soon...ATI install coming shortly..any help??
  196. DTC codes HELP
  197. Need help with Idle with AC On
  198. HP tuner help
  199. Any tuners in Harrisburg/Hershey, PA area?
  200. Door Codes. Anyone else got 'em?
  201. LAP TOP MOUNT FOR C5 INTERIOR.............
  202. Recommendations for the Drags at Cruise Inn V with my Predator?
  203. vinci programmer
  204. 04 Predator
  205. 0-60 performance for '99 A4 Vert with 3.42 diff and Predator tune
  206. Any tuners in Utah?
  207. Share HP Tuner for 2000??
  208. Shifting changes
  209. idle tuning
  210. LS1 Edit - What all parameters need changing?
  211. Predator Return
  212. HP Tuner for '97, Want to split or buy
  213. LS1 heads,cam interchangeable?
  214. interesting thing regarding FTC tables
  215. Any Tuners in Greensboro NC ?
  216. help with codes
  217. Dagnostics best tool ?
  218. Just bought HPTuner
  219. Why would timing be lower then tables in HP tuner say they should be?
  220. Interested in splitting HP tuner year 1998???
  221. Interested in splitting HP tuner year 2000???
  222. PE vs. MAP question re: hp tuner
  223. If you don't have the edit software...
  224. I couldn't wait any longer so I order the HPtuner
  225. Got HP tuner, could use a little help/
  226. Turn Signal/Running Light Not Working--Blinks Rapidly
  227. Codes B0361 and B0441....how can I fix it?
  228. No dyno gains from Predator.
  229. 98 C5 PCM in a 97 C5
  230. LATEST PARTS AND TECHNICAL BULLETINS..PROMO CLOSEOUT!
  231. ls1 and hp tuners
  232. Knock Retard and Traction control-cross posted from Tech/Perf
  233. Need help with Stock 1998 Bose Cd Radio, PLZ HELP!!!!
  234. Aftermarket Flow Power Duct with Vararam?
  235. Need LS1edit help
  236. Short Term and Long Term Fuel Trims
  237. Anyone knows the best TUNERS in New Jersey?
  238. 2004 Predator programmers are now available!
  239. Car running very rich...can I fix without tuning?
  240. HELP with Codes
  241. HP Tuners and Gen III Motorsports....
  242. problems using LS1 Edit after had mail order tune
  243. Vararam and Air Straightener Question.
  244. Where do you buy HP Tuner?
  245. Best Price for EFI-Live? Who has it?
  246. Need Stock Flash for 99 C5 Automatic!!!!!!
  247. IFR table for 2001 Coupe???
  248. Magnuson blower tuning questions.
  249. ideal air fuel ratio?
  250. A4 Tranny Slipping After Programming
