- Tuning help low end?
- 04 Predator with 3.42s: 2-1 downshift?
- Loading a new program
- Favorite Tuning Threads
- any help with 230/238 cam tune?
- Just installed h/c, injectors. Need some help with LS1Edit
- ? for Predator Users w/A4 and 3:15
- Predator, differences between years.
- NEWBIE TUNING - Great link and success
- Dyno Tuner or Specialist in Virginia
- What is PCM Code 1416 H C ?
- 2002 Stock Z06 MAF/IFR tables
- Vinci hand held tuner???
- Input on "Superchips" Tuner
- Has anyone received their order from Hptuner
- AutoTap Serial or USB?
- Steering Column Lock Recall Question?
- Fuel Filter - When to Change?
- Column Lock PCM Flash Kills Ability to Tune?
- LS6 intake modded so you dont need ls6 coolant tubes.
- Going MAFLess...How?
- car wont start is it fuel pump?need some help
- tunning a4 ?
- LS5 Tach signal
- HP Tuner & A4
- 3:42 Gear
- Oil residue sprayed across engine. Please help!
- Can DiabloSport Predator compensate for a POS MAF?
- don't want to void my warranty
- Ok longtube headers installed. Got a ?
- Predator performance tune installed
- Need C-5 tuner in Dallas/Fort Worth area
- whoops
- Speed Density tune is in...
- removing cats
- Steering Column Lock Question
- Looking for a good tuner located in SE ....
- 2:73 to 3:15 A4
- hand held programers,help
- what is cags
- First time with LS1 Edit and Scanner - LTFT results
- Best Tuning System For A 97 C5????
- need help w/ a lt1
- HP Tuner - '03 C5's in the Phoenix AZ area!
- High idle problem....Suggestions?
- HP Tuner & 2004 A4 Settings
- Bone Stock C5
- Need help with O2 sensors readings..........
- For those who have installed headers/cats. Questions???
- ATI on a C5 File Needed
- newbie with Hypertech question
- LS1 edit help needed
- Need to find a good tuner
- Question about wideband sensors.....
- NC area, More Performance VS CAM
- Anyword on the HPTuner GP
- Zeitronix wide band sensor review
- Predator Present!-Question?
- MAF Table & Vararam????
- LS1 Edit - should I return it?
- Dyno Tune Still only 299.99
- Effect of Stingers on A/F
- Adding a resistor inplace of the IAT(nitrous)
- Slp Zl5, 6, 7 ??????????
- new intake
- Any thoughts on this elctrical problem
- IAT resistor to retard timing nitrous..
- Request Forum Input on Superchips Tuner
- Please explain difference of LS1Edit, EFI LIVE, Autotap & Co
- Need Help finding the TPS Singnal Output Wire
- 2000 C5 + 3.92 + Transgo + SS3800 tuning...
- Need help on codes I discovered...
- FS Programmer
- Need help with codes
- Idle issues...PLEASE PLEASE HELP
- HO2S Circuit Low Voltage Bank 1 Sensor 2??
- Please Help! Vette just accelerates to 110mph
- Who can install gears
- Traction control system problem
- Intake
- Which LM-1 do I get?
- ls1 edit and tq managment ?
- Hp tuner GP....Revisited
- Hypertech III for 03 LS1/LS6 for sale, OH
- In search of Sacramento area tuner...
- Calling On Techies and Tuners for Help!! (linked)
- Want to see some really cool tuning stuff?
- Vararam installed, more power with tuning?
- LS1 Edit hard to use?
- Explanation on codes, please..
- 315 gears to 342
- Anyone have stock '03 Z06 LSIEdit file?
- Tuning- Hand held or HP for A/F Ratio
- Tuners in Nashville??
- Can the Predator overcome a 160 thermostat?
- Whats causing the P0158 code
- MAF table needed
- Help!!! Low Oil displayed on DIC
- Help me PLEASE!!!
- Interested in a group buy for the Predator?
- knock retard and questions.
- Can LS1edit take off check engine lights
- got several codes..need recommendations..
- Help bad noise by shifter
- Code: B0367H
- code 1416??
- Breathless LS1 Maf Housing With Air Foil
- Can LS1-Edit or HP Tuner be used to turn off my F45 suspension controller?
- help! question about heat shield
- Changing 315 gears to 342 gears
- noob question on HP Tuner software
- a/c compressor noise
- Any experiences tuning a Procharged C5?
- Incorrect machining on head recall?
- auto tap!!!
- Upgrading Gears.... Use of Predator?
- WARNING: LS1 Edit & GM Column Lock Recall Don't Mix
- Tuners In Boston?
- Fast Chip tune
- Anyone heard of this???
- Idle problem
- noob Q, please be kind :)
- DIY Tune and Dyno
- This can't be right! Can it???
- HP Tuning, are you going to Carlisle
- Bryan Herter Dyno Tuning in DFW
- Cheap effective wideband for use with EFILive?
- Took Z to dealer for column lock recall - tried to reflash LS1 Edit - car won't start
- Tuner in Chicago area
- Rising the ignition timing
- Surging on light throttle application
- how did you guys route your LM-1 harness?
- Chaning the PCM
- ed wright
- Newbie question - flip chip?
- Correct RPM for Idle?
- How to stop Shift 1 to 4
- Another Pinging Question
- Programmers
- What MPH to shift 1 to 2?
- $10,000 for OBD II programmer - Mosler MT900 supercar
- LS1 Edit and "Normal" Shift Point Settings
- limiter?
- Is Autotap LS1 Upgrade Worth The Money ?
- Hypertech PP3 for a '97?
- Vette Doctors information!
- Help needed with tuning large cam/high stall converter
- Any vendors dynotuning at Carlisle?
- 3 Huge Pages of News – Don’t Miss This!
- LS1 edit for 04 coupe
- What paramaters should I set up in autotap to monitor Air/Fuel
- HP Tuner group buy?
- new LG longtubes do I need tune?
- Programming Device or Software
- New Piggy Back?
- Emissions almost failed inspection
- My 98 has been acting really wierd lately....
- What is the stock '99 rev limit?
- 99 A4 tuning!
- Any competitors of Carputing/Ls1edit??
- Can my tuned PCM be copied and reloaded?
- What Wide Band O2 Monitoring / Logging Set-Up is Best?
- A4 and rev limiter questions
- 04 predator-vin# locked????
- Who has had their 98 A4 dyno tuned?
- Tuners in the Bay Area?
- Z06 Edit File with heards/Intake???
- Setup my LM-1, WOW something is off (dyno or LM1)
- Edit scanner
- dyno tuning question
- A unique tuning question
- Custom program or programmer
- Where's best place to wire in WBO2 controller...
- Help: tuning with LS1 Edit
- Best Tuner between Sheveport and DFW?
- a4 tuning? any experts out there?
- Sticky Shifter on 98 C5
- Sorry but what is ls1 edit? Is it a chip?
- Exedy installed, do I need a re-tune?
- HP Estimate Please.....
- HP Tuner & WBo2 Analysis Automation
- Any tuners (LS1 Edit) in the Boston area?
- hypertech power programmer problem?
- Do I need to make an LS-1 Edit change for this?
- Interest in Laptop Stands?
- Knock?
- MAF Translator and the Predator
- what is the average gain using HP tuner?
- How to view an Edit File??
- Is this a fuel filter problem?
- Column Lock reprogram and Ls1-edit
- Sacramento Area Tuner
- I think my a4 is breaking please help me and let me know if this is normal
- GM Tech 2 Programmer
- Can this be fixed with tuning?
- vinci tunner wow
- How many horses
- Tuning 3 ways???
- Active Handling working?
- Need help!!!! Column lock bypass!
- Need Tuning Info !!
- Programmer possibly voiding warrantee
- C5: rising revolution speed
- Dealers can't tune anything?
- Next Dyno Day???
- LS1 Edit Manual ?
- Clutch Slip Test - Please help
- What is AFR on stock LS6
- PREDATOR Flash Tuner
- What is QC Code 32441?
- Ylwy2k
- P 0160
- Where in Sacramento, CA to get rev limit increased?
- Looking for a shop w/ Ls1 Edit in Northern Ohio
- DIC does not agree with EFI-Live.
- Tune causing oil consumption?
- Help with A4 shifting
- I need HP Tuner '03 D1SC w/10#(bin file)
- Good vs. bad A/F ratios....I have some questions...
- KR only in 4th???
- What RPM shift point
- Can u disable torque management with the Predator?
- Not at all happy with the Vinci Programmer!
- need help tuning out ping
- Port and Polish Job
- Idle Problem after Header Install
- HP Tuners
- tunning bigger injecters
- BPP shifter installed
- 04 Predator install
- Question about torque management?
- Is the 04 computer different?
- Surging on Idle after Header install
- Vinci vs. Diabolo Predator ... which one to chose??
- C5 Ping, Programmer, Intake and Exhaust
- Engine dies
- is there a way to tell if the dealer flashed my computer?
- Tuner explain this autotap results from race
- IAT sensor mods
- Will AutoTAP help me here?
- Tuning an '04 Z06 with a handheld but without a dyno
- First day with my new Autotap
- ABS Reprogram Question
- System Readiness Test - Evap Purge System
- tuner in SE MICH
- Engine Stumbling...wanting to quit
- Texas Speed Mail Order Tuning Special & Info!!
- Is it just me on the LAPD Dyno Tune GP?
- whats happened to my car?
- How long before a code gets the "H" attached?
