View Full Version : C5 Scan & Tune
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 [22] 23 24 25 26 27 28 29 30 31 32
  1. Hypertech III Question
  2. Will Predator's OBDII work on ANY car?
  3. Need predator help bad!!!!
  4. Predator performance tune works w/91 octane???
  5. EFILive's online store is available.
  6. Am I running hot?
  7. 100 Mph Top Speed
  8. RI Tuners
  9. Bank 2 Sensor 2?
  10. how to use diablo
  11. Any place in Pa to get a Dyno Tune?
  12. LAPD 3.42s, Varam & Dyno Tune done today(numbers)
  13. Tuner in No. CA.?
  14. Diablo Predator 04 ?
  15. injector size
  16. Prepping car for tune questions??
  17. LS-1 Tune vs. Hypertech vs. Professional Dyno tune
  18. LS1 vs LS2 Knock Sensors
  19. How do I use my HP scanner to stop bucking.
  20. Save Big $$$ - Year End Sale at Fichtner Chevrolet!
  21. predator fan settings backwards?
  22. Merry X-mas to you all
  23. Important - Please Read!
  24. WBO2 Sensors...one more time
  25. All roads lead to MAF~~ Dat Pesky MAF
  26. Where to buy Scan Tool LS1 Edit or HP tuners?
  27. Special tune for Yank 3600 TC??
  28. Granatelli MAF sensor
  29. Anyone use e.c.s. in jersey(tunning)
  30. LS1 EDIT Tuner near Fredericksburg Virginia???
  31. LS1Edit / AutoTap available in C5 Parts
  32. Who has LS1 Edit in GA
  33. Dyno results after TPIS and Random Tech
  34. Any luck with Wideband 02 signal to PCM?
  35. Need Opinions On tuning options
  36. LS1 edit Dyno Tune Results
  37. Anyone get Autotap to work on Tungsten E
  38. LS1-Dyno Tune question on A4
  39. Is there a good Tuner in KC?
  40. R there any good Tuner in KC?
  41. Service Tech
  42. Ran across a 2004 Predator being offered...
  43. do i need to tune after cam or ls6 intake install
  44. Happy Holidays from Fichtner Chevrolet!
  45. 2004 C5 owners with LS1Edit version 1.51
  46. Tune for start up at 160 degrees
  47. Actual Hp Intake Gains?
  48. HP Tuners and Column lock disable?
  49. should i need a re-tune after headers?
  50. TCS code 1288??? HELP!
  51. ProCarparts Intake & Filter
  52. My First Dyno
  53. what rear gear should use?
  54. check engine light on need help
  55. Static (non-changing) LTFTs
  56. Need a tuner
  57. 1571 code--help
  58. What do I need to change if I switch from stock 26.4# to 30# SVO injectors?
  59. HT Programmer
  60. What tuner will let me change my gear ratio to correct my speedo?
  61. Stock MAF limits?
  62. can ya tell me what this code is 10-pcm p0240?
  63. Edit V1.5, anyone have the patch they could send me?
  64. weird stuff
  65. Scanning Per Service Manual
  66. Not the right forum but this is the only place I post
  67. Bank 2 lean code?
  68. question for tuning guru
  69. Bypassing the Maf and HP Tuners
  70. Anyone Use Gen3Motorsports out of Portland?
  71. Question on Predator
  72. Code help please
  73. Did I lose my dyno tune?
  74. Any tuners near Charlotte, NC?
  75. mechanics in springfield missouri
  76. nashville tuners?
  77. Aftermarket Filters and Intake Kits
  78. to tune or not to tune
  79. New TunerCat OBD2 tuner now available :)
  80. want more horsepower
  81. need some info
  82. central florida tuners?
  83. LTFT's and codes P0171 P0174
  84. AutoTap and USB??
  85. What size hole? TB blade (G5X3/114 cam)
  86. Tuner in Utah?
  87. Tuners in Bowling Green?
  88. Does Anybody Have the Predator PC Interface File ?
  89. Best tuner in Southern California?
  90. [POLL] Your Predator "shift pressure" setting
  91. how do i raise my idle
  92. Predator tune recomendations
  93. Memphis tuners
  94. My Predator settings.....opinions please.
  95. HPtuner Guys In here please...
  96. Too Lean what happens
  97. F55 and Predator
  98. Is it true? HPTuner will allow extended MAP tuning.
  99. Stall Speed Question
  100. Surging and bucking at low rpm's and load
  101. LS1 Edit or HPTuner - Which should I buy?
  102. PCM Swap
  103. Heads/Cam vs Magnusson question
  104. Ls1 Edit
  105. Question for you Tuner Pros
  106. Need Help With Air Flow Problem
  107. reading Predator tune
  108. Problems at WOT
  109. need a tune in a couple months
  110. Mail order tune-what is it?
  111. ? about ignition timing
  112. New Laptop Questions
  113. Predator Tune changes stock setting how much
  114. Handheld Tuner ???? A4 3.42s
  115. TeamZR1 Tuning
  116. ???? gear swap/tuning/warranty
  117. Jet Power Control Module
  118. Gear Swap tune for a 98? 2.73 to 3.42
  119. Will You share your 402/408 Tune?
  120. Makers of Laptop stand Good Price!!
  121. Will Column Lock Recall affect an LS1 Edit tune?
  122. HP Tuners Has A New Deal...
  123. Need to know about tuning
  124. MTI (Georgia) does it again.
  125. Best fuel pump??? 650-700hp
  126. MAFless tuning ....or Large MAF 90+ mm
  127. check engine after 02 sims
  128. Quick LS1 Edit tuning question...
  129. Not makin' the HP I should be......HELP!!! Long, sorry...
  130. C1243 BPMV Pump Motor Stalled
  131. Odd drivability problem with LS1, need help...
  132. DTC code question
  133. I need experienced suggestions
  134. whats the best, low cost way to scan for kr
  135. tune
  136. Hypertech tune??? What changes can I expecT??
  137. 99 A4 Vette KR Problems
  138. OBDII rear O2 question.
  139. tuning info
  140. Vette Inactive for 2 Weeks
  141. LS1 Edit tune in Dallas TX
  142. This Weeks Parts Special 11/13/04
  143. Any good dyno tuners in MA/NA area?
  144. quick predator question
  145. Code Question !!
  146. Dyno tune ?'s
  147. EFILive V7 Scan tool and Flashscan tuning software demo now available!
  148. Can I get some DTC help?
  149. Are you in MD & need LS1 Edit Tuning over X-MAS?
  150. Oxygen Sensor Problem
  151. Turn signals acting up
  152. Crane Powermax Tuner - anyone use it?
  153. Predator wont take
  154. How can a spark map all of a sudden change?
  155. Charge System Fault Message
  156. Hypertech III - (hopefully) the straight facts on gear scaling
  157. Austin TX Tuner needed
  158. Hypertech III and torque management ?
  159. MTI Racing LS1 Edit performance tune.
  160. Changed gears in my c5 from 342 to 373's
  161. Handheld tuners---????
  162. need tire dimensions changed, possible without spending $500 on tuner
  163. Do I need to tune my car again?
  164. transmission tuning
  165. Important - Please Read!
  166. LS1 and LS6 Spec
  167. ? about Tuning when Modding Piece by Piece
  168. DIC codes
  169. Newbie Question: Is a tune needed?
  170. Z06 TI Exhaust vs stock exhaust
  171. Codes after LS6 transplant in 97 M6
  172. ECS is now doing mail order tuning.
  173. Ed Wright Tune
  174. LS1 edit/ traction control
  175. VHP -vs- Predator threads or opinions
  176. PCM for engine swap?
  177. LS1 edit questions
  178. wideband O2 sensor hookup
  179. Should I be worried?
  180. Buying LS1 Edit
  181. How I fixed codes P1111 and P0113
  182. Newbie - Where To Start?
  183. Need LS1 Edit - Anyone in VA to recommend?
  184. New Tuning Experience
  185. Dyno tune worth it?
  186. Dealer Locked with New Flash!!! HP ?????
  187. Tuners in western New York?
  188. Group Purchase: Diablo Sport Predator Corvette Tuners!
  189. 4L60E: please help me to get the big picture
  190. Collecting Wideband O2 data
  191. HP Tuner experts.. Please help..
  192. Help!!!! Installer Tuning Made only 370rwhp Should I use ? or ?!! Thanks
  193. QTP cutouts
  194. HP tuners ver 1.5 is here!!
  195. i maybe wrong
  196. Anyway to tell which plug is not firing?
  197. TIMING- hp/tq relationship help
  198. Line pressure settings with Transgo shift kit?
  199. Question on hand held tuners
  200. change cylinder size?
  201. codes wont come up
  202. Anyone have a stock 2002 A4 bin for HP Tuners?
  203. Hey, Mike Mercury!! (or anybody who's tuned an A4 with LS1 Edit)
  204. Wtf Are These Codes?
  205. Where to buy ls1 edit?
  206. Fuel Trims
  207. Anybody know where I can order a Varaam 2B Velocity Stack!
  208. Code help
  209. Is it worth paying extra for a wideband tune?
  210. 2002 Z06 tuning options?
  211. Check this out!
  212. HP tuner and Yank 3000 converter
  213. Baseline HP/Torque #s?
  214. Opinion Please - LS1Edit or HP Tuner
  215. Newbie help: To tune or not to tune?
  216. Any tuner's with great reputations in WA
  217. Just got a code....please help
  218. Air fuel....?/ help me out
  219. Tuning...Tech 2 or LS1 Edit and Dyno?
  220. OK Predator Guru's (AKA Mike Mercury)
  221. New Code...
  222. Las Vegas Area and LS1 Edit
  223. Shift Point Question
  224. C5 Security light on solid
  225. Code: P0894
  226. Need help with auto tuning...
  227. Predator parameters changes? Any suggestions
  228. Opinion on Fuel Mix
  229. Rear end concerns
  230. WHO here on this forum, REALLY knows transmissions, converters & dyno's?
  231. Highest speed A-4 downshifts into 1st gear with 3.42s?
  232. chevyc5ls1
  233. Anyone know anything about HYPERTECH comp tuning?
  234. Anyone with HP tuners in Metro Detroit Area ('03MY Z06)
  235. Engine Light Came On
  236. Which cam to use?? Please reply..
  237. $5000 budget continued
  238. Opinions on Dyno Run
  239. Need help with Predator tuning
  240. Torque converter lock up on dyno question
  241. Longtubes installed.. can I use my predator to tune?
  242. n00b question - Predator vs. LS1Edit? Help please.
  243. New tranny=10 RWHP loss??
  244. Headlights Will Not Come On
  245. O2 Sensor Question
  246. 75 lb injector tuning ?
  247. "Stuck" in Low Octane Table?
  248. ait procharger tune
  249. Computer Chip?
  250. HpTuner GP People please Read......
