View Full Version : C5 Scan & Tune
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 [21] 22 23 24 25 26 27 28
  1. How do you turn off 02 with edit?
  2. Need a little help with auto tap
  3. preadtor vs. ls1 edit
  4. A4 shift duration times.
  5. Wideband sensor location
  6. PCM Changes for different torque converter
  7. a4 with 4.10 file
  8. DynoJet Commander vs LM-1
  9. Crane Power Tuner
  10. Thank you for the tip on parts
  11. How to disable TM?
  12. LS1Edit V1.4 s l o w. . .
  13. Review of HP Tuners Software
  14. C-5 Rich under 2000RPM
  15. If you want a Predator, Don't call RWTD or James !!!!!!
  16. need a PCM for my 2001 LS1
  17. codes P0300HC , P1571H and check engine light
  18. seek 35k mile tune advice
  19. 02 28.8 injectors in a 99 what to change
  20. Engine code help.....
  21. Computer Relearn - Disconnect Battery or Pull Fuses???
  22. [Misfits] Local Florida Events!!!
  23. Help! Headlight retraction noise
  24. Rear o2 codes - using Sims but still coding
  25. Help with P-1416 code
  26. Dissapointed with LS1 edit.
  27. Change MAF, require a new A/F Ratio adjust????????
  28. Check Engine Light
  29. where did you start with edit?
  30. help w/ turning off check engine light
  31. Help! TCS, ABS, and Traction control not working.
  32. Head and Cam GP - for the after tax set..
  33. Help! TCS, What is TCS error code 1247 and 1283?
  34. Detailed tuning Question on IFR to LTFT and the dreaded P/N Decay table
  35. dynojet update
  36. A stupid question...where do you plug in the cable for LS1 edit??
  37. turnaround on edit??
  38. Help with tuning on 98 w/ 3.73s & pt2400
  39. Need Help Check Engine Light Code reads P0200 HC
  40. Ideas for New Radio Unit for 2000 FRC
  41. MAF-T and Autoatp Tune success
  42. James.... are you out there?
  43. Editing cells cheaply?
  44. help with hosting an MPEG of dyno run
  45. Codes: What are P0136 and P0156??
  46. Looking for tuner in Columbus, Ohio area
  47. LS1 Edit...USB Ports Only...What Are My Options?
  48. Anyone seen RWTD??
  49. Hypertech Power Programmer Plus for 96-99 GM
  50. Anyone ever hear of "Superchips Model 2725 Max Micro Tuner ?
  51. Am I too rich?
  52. Tune\Edit Gains.
  53. Predator and AH/TC
  54. Tuner in Pittsbugh, PA area
  55. Tuner in Washington DC area?
  56. 04 LS1 Edit
  57. What AF typical or optimum for stroker--
  58. Z06 H-pipe and code P0430
  59. DTC 1571 code
  60. Ls1edit and pumpshot?
  61. ls1 edit ? and header
  62. Need Stock 1997 C5 .ls1 file
  63. Is a P0300 misfire code normal after H/C & no tune?
  64. Does it help to reflash PCM ??
  65. Granetteli MAFS
  66. Paging Hool97
  67. big problem?
  68. maxium torque
  69. Code P 1431 H What was it?
  70. LS1Edit Tuning for a Vararam
  71. Bizarre... Service Active Handling / Traction control
  72. 02 Vert Fuel Tank Sending Unit Connection?
  73. Turn Signal Bulb keeps burning out... no moisture present. Any ideas??
  74. Headlight Winking problem
  75. Scaning/logging software?
  76. Tuning for emissions... can it be done with a 222/222 112 LSA?
  77. LS1 Edit and ODB-II emission testing
  78. Tuner question!
  79. Do I need LS1Edit or Predator?
  80. Predator Tune ? Questions
  81. Does CARTEK 'lock' PCM codes when they tune?
  82. any good tuners in southeastern Wisconsin
  83. gear install any edit needed?
  84. Hypertech???
  85. Predator Version 1.04 Still Missing in Action ??
  86. Predetor tune for 3.42 rear on C5
  87. HELP! What does code P1514 mean?
  88. AUTOTAP NOT recording WOT Wideband O2.. Anyone know why?
  89. Latest 2005 C6 News and More!!!
  90. Need to record sensor data without a laptop or palm
  91. just added a blackwing and the Service Engine light is on
  92. Competition for LS1-Edit
  93. LS1 Tuner needed in Louisville, KY area
  94. need help finding local tuner
  95. 97 wiring schematics needed
  96. Code question: What does this code mean? PCM-1416 HC
  97. codes are in...
  98. MAF location
  99. Code help please
  100. Any good tuners in OHIO
  101. Need stock 99 A4 3.15 file
  102. spark plug wires (differance between)?
  103. More LS1Edit questions
  104. PREDATOR VS LS1 EDIT
  105. Fraudulent use of Predator.
  106. EFILive and LS1 Edit
  107. I have some autotap data.. WHO can interpert them for me?
  108. Have 99 LS1edit, can you add a 00 to the cable?
  109. Basic ls1 edit tune
  110. LS1 Edit group purchase in Eastern Canada?
  111. General adjustments on an A4 with the predator?
  112. New Editor
  113. does this make any since (TM GURU hopefully)
  114. Will car run with new cam and old tuning.
  115. 2002 Z06 Head/cam
  116. LS1 Edit tuning questions
  117. I broke my PCM, 10-pcm no comm. error
  118. Innovative Wideband
  119. PCM TACH Signal -- Voltage Range??
  120. Installing 3.73s on a 98 ?
  121. How many degrees spark advance at WOT
  122. Thanks RWTD
  123. FICHTNER CHEVROLET SPRING SPECIAL 03/05/04
  124. ECM replacment ?
  125. LS1/A4 Techie opinions please
  126. New Toy
  127. Disconnect battery resets LTFT? What about my tune?
  128. Need suggestion on idle setting with new setup (LS1-Edit)
  129. LSI Edit in Utah?
  130. SF Bay Area Tuners
  131. predator tnstall
  132. Chicago area members............LS1 Speed open house
  133. (Dallas Area) Best place for LS1 Edit in DFW area?
  134. Need help clearing codes using the DIC
  135. Injector Offsets - Lucas/Delphi 36lb inctrs???
  136. What is burst knock?
  137. 2.5 vs 3inch pipes c5
  138. Pace performance MAF for LS1-LS6 conversion.
  139. superchips
  140. MAF High-Frequency DTC when I go into boost
  141. Who has the best price on EFILive?
  142. 2004 A4 IDLE ?
  143. Help With Code P0442
  144. Code help please
  145. Timing & KR????
  146. Speed Density tuning--anyone have it done-where-
  147. Newbie to tuning, I have some basic questions
  148. LS1 edit?
  149. Hey all you scan gurus, what does this mean?
  150. Anyone Heard from James RWTD Lately?
  151. Denso spark plugs
  152. FICHTNER CHEVROLET PARTS SPECIAL..EXTENDED ONE WEEK 02/27/04
  153. Whats involved tuning wise, going from a 97-00 MAF to a 2001+ MAF?
  154. Anyone willing to autotap my car?
  155. Guidance for a neophyte tuner
  156. Friend trying to sell his Predator
  157. EUROPEAN INSTRUMENT CLUSTER
  158. Given the extent of my Mods will a Hypertech Power tune help or hurt?
  159. Scanner for only pulling and reading codes. Equus or Actron OK?
  160. Anyone know how to reach Mike Morgan?
  161. Steering column locking recall reflash PCM?
  162. Tuning issue? TC RemovED, BUT When power braked, still launches sluggish.....
  163. EASE report with MMS then TeamZR-1 tuning
  164. -------Question about computer relearn after mods-------
  165. C1233 RF Wheel Speed Circuit Open or Shorted
  166. HYPERTECH
  167. placement of wideband sensor
  168. Total Timing ?
  169. LAPD GRAND OPENING/DYNO DAY SATURDAY MARCH 13, 2004!!
  170. Tuner in So Cal quick
  171. Cat codes shutoff help
  172. Diagnostic Scanner Recommendations??
  173. Header Tune?
  174. Disabling TPS...Can the dealer do it??
  175. x pipe
  176. Save 10% at VBP-Vette Brakes & Products, Inc.
  177. Any good source for the LS1 Edit in Northern Colorado
  178. Need help- Have Codes
  179. ecm location
  180. LS1 injector "size" on offsets...
  181. A/F ratio help
  182. ls1 edit
  183. LS1 edit?
  184. Am I screwed?? please help...maybe James has answer?
  185. Those with data acquisition software...
  186. B0026 Code?
  187. Wester's computer programming
  188. A.I.R. psi ?
  189. Anyone in Dallas/Plano area with a scanner I could test to see which one to buy?
  190. mileage
  191. (RE-POST) Please Help! What size rims will fit my C5? 20",19"?
  192. Tuning questions
  193. Usb or serial?
  194. MAF table with 85 mm MAF ends and no screen???
  195. LS1 EDIT??? How $ & Where?
  196. What does code P1416 AIR System Bank 2-B mean?
  197. Can I get a PCM update without going to the dealer?
  198. When do you need a tuner.....
  199. What are the minimum miles before LS Edit ?
  200. Predator Info
  201. Hypertech vs Superchip???
  202. NEEDING A LS1 EDIT
  203. Transmission Fluid mixing.
  204. Southeast Pa Tuner
  205. ltft difference bank 1 and 2
  206. Need to add 50 Horses to my Vette,,,
  207. Techedge WB replacing the stock O2 sensor
  208. GP on Wideband Commancer
  209. Predator Rocks!!
  210. Loyal customer paging James@RWTD
  211. DIC code reading.
  212. Jet power chip
  213. Autotap-How many parameters to monitor for best log?
  214. 2003 vette PCM data field definitions values chart available?
  215. Tech Edge WB
  216. Predator Results on 02 Z06?
  217. Predator LTFT question...
  218. Is the so called black real?
  219. Who has the best deal on LS1 ECM programming
  220. Anyone using a Palm Pilot based scanner on OBD 2 cars?
  221. What's New?
  222. Predator for a 1998 LS1
  223. Tuning Questions
  224. how long before ltft adjust?
  225. Allow TCC lock during shift???
  226. James, Predator for the 04 yet??
  227. New O2 Wideband Product
  228. anyone know how to use ls1 edit to fix start up idle issues
  229. How long does it take to get LS1 Edit shipped to u?
  230. looking for a GM LS1 LS6 flash file.
  231. B&B triflo exhaust
  232. Predator Results
  233. I have a PCM code that's not listed in my documentation?
  234. Can anyone tell me how to reset the check engine light?
  235. tire monitoring system not active, please help
  236. Fine Dyno'ing: All Chassis Dynos Are Not Created Equal.
  237. Autotap for USB and other updates!
  238. Injector percentage 90%, do I need more fuel pressure?
  239. LTFTs changing all the time
  240. Program for my laptop?
  241. LS1 edit for ZO6 in NC?
  242. Take a peek!
  243. Blackwing cold air shroud surging. Could this be tuned out?
  244. LAPD GRAND OPENING OF SHOP FACILITY SPECIALS!!!!
  245. What are people using to tune/program a 2004?
  246. ls-1 edit
  247. Questions about a scan/tune setup
  248. How does the Diablo "Performance Tune" compare to stock?
  249. LS1 edit gurus inside
  250. The truth about tuners!
