- A4 trans problems - help/advice please!
- LS1 edit and Dynatech exhaust system
- Why does my car keep going into theft mode?
- Can I look at someones modified Tuner file?
- AFR at idle and part throttle? Good or bad?
- Any tuners near Memphis, TN?
- Somebody Help quickly / Vinci Tuner/ Car won't start
- Maf table question
- Tuning rip-off??
- Hypertech Program; Need Help!
- where to buy ls1edit
- Pulsating idle when first warming up?
- Stoich Ratio Question
- Predator manual ADDENDUM!!
- Serious all motor route!
- You guys are going to fall over laughing.
- My tune....
- DIY Tuning with HP Tuners
- 390/410 gears
- 1998 corvette engine noise?????
- DESPERATE... C-5 h/c tuning at start up ????
- VCM Suite 1.7.0 Available Now!!
- Looking for a Tuner in Tulsa Area
- Tire pressure monitoring - disable?
- Took out interior for dynamat and ended up with service vehicle soon
- Hp tuner...
- Octane table question
- Looking for a tuner. . .
- Need help with PO113 or P1111
- Knock retard coming in at as much as 10 degrees....
- Water Pump Issues Cant Decide
- From 93 to 91 octane, do I need a new tune?
- smokey tail pipes
- Help! Random Misfire.
- What to do?
- Tuners At Cruise-in This Weekend????
- smokey
- Any tuners in my area?
- Dyno Tuning???
- Whats a BORFA and why does it say NO COMM
- IAC Counts High??
- Need help reading an LS1-Edit File
- Anyone with HP tuner in GA???
- Data Logging with Predator!!
- fuel level sensor codes??
- ls1edit will not connect to pcm
- Doing my first ltft tune and no SES light??
- Help Auto-cross / Road course novice
- Any 02 and up Z06 guys with a Halltech Stinger and programming?
- All Autotap software on sale!
- Planning Tune
- can you save 3 or 4 tunes on hptuner?
- Anyone know a good tuner in SW GA?
- need an HP Tuner file of a performance-tuned A4 C5
- Need an HPT bin file for tuned A4 big cam tranny specs
- 04 o2 sim questions again!!
- EFILive Scan/Tune vs HP VCM Suite Pro
- Rack your brains on these codes guys
- Latest parts for diff seal replacement?
- New PCM, still getting PO 327 code
- What exactly is HP Tuners 3 bar map?
- What is needed to store and install a tune?
- LS1 Edit connection problems
- HP turner or LS1 edit
- Problems with 1998 PCM with boost
- can I claim "Predator Tuned" if I don't make any adjustments to the initial upload?
- Check Engine P1153
- another predator question
- If torque management disabled, Traction control still work?
- Predator question
- Low HP with LG Headers
- California C5 tuning
- 50-60hp with LS1 EDIT?
- My Last Dyno Results
- ls1 edit memphis
- Gas Mileage drop after Vararam install
- Thanks To The Vette Drs.
- TUNER: southern N.H.
- NEED HELP QUICK - Vinci Tuner error!!!!
- Check out my new Numbers...
- A Very Strange throttle position issue.
- Laptop interior mount?
- First Dyno Tune with LS1 Edit! Recommendations Needed!
- tuner upstate new york
- best tuner in ohio for pro charger ??
- Remove MAF and run car in SD ?
- Can tire pressure monitors be programmed out?
- codes after vararam install
- What is LS1 edit? can I beat a GTO?
- Code P0420 need opinions
- Expert opinion needed - is tuning required with my mods?
- LS1Edit
- check engine light on/ Knock sensor
- stupid questions
- HPTuner conversion back to LS1 edit
- LS1Edit Help
- What speed are you shifting at A4's?
- To Tune or Not
- NEED HELP Badly....please
- had a great time at CAM ? on dyno though
- Diablosport Predator questions
- Where did my timing go???
- AFR - Dyno Tune
- Tuning Questions - Multiple
- Dyno Tune at a different Altitute
- Diablo Sport question
- Car won't pass emissions
- How to connect LM1/LC1 to our C5?
- Anyone with a 3.42 tune....please?
- tuning help in the midwest
- What TEMP. should my ENGINE run at ????
- Has anyone used York Dyno ?
- Vette shut down
- How to tune with Nitrous and mods?
- Can it change?
- P H 0327 Knock Sensor Low Frequency?
- HP Tuners...
- If my LTFT's, KR and O2's are perfect........what do I gain with a tune w/Edit?
- Tuners in the southeast
- o2s locked at .450?/= 11 mpg!!!
- looking for stock 2001 Z06 PCM file
- 78mm vs 90mm throttle body & intake systems
- EFIlive Calculated hp
- 3.73's, A4 and Predator???'s
- 97 vette engine knock
- VCM Suite 2.0 and expired support notice.
- Dtc 1217 Bpmv
- need some dyno tune advice
- Thanks Andy @ A&A Corvettes!
- B0134 and B0154 codes after header install
- Tune after headers
- Yet another Diablosport Predator problem!!!
- What Scan Tool Software are you using?
- Slicks & Skinnies..
- anyone want to split HP tuner cost
- Predator install problem
- New 395ci - Throwing code P0336HC
- fast intake 90mm tb tunning
- any other wideband tuner???
- How to connect HP tuner wideband to LS1?
- Stalling - new tune, mods, idle issues????
- Trouble code 1514
- Need Major Help!!!
- MAP sensor problem?
- Surge.....Throttle body elimination.........
- New Manifold?
- Reset computer or let learn after mods?
- Predator and it's support very disappointing
- Help Tuning In Illinois
- 98 C5 A4 Dyno #'s
- Mods and NY emissions
- Relationship of TCC to shift points
- Need St. Louis Dyno shop
- Tuning - Minneapolis
- SLP Lound Mouth Exhaust
- Dynatechs and LS6 intake manifold install question
- A&A Corvette Simply the Best
- interesting edit problem yesterday.....
- Predator Tune:Fans do not come on at set temperature
- Tuning 98A4
- Anyone in CA Bay Area using EFILive?
- Who is running the HP tuner wideband
- should stock tune pull timing under load?
- IM240 ready flags
- Warning! Counterfeit Ac Delco Sparkplugs
- Looking for GM Engineering Documentation
- g5x3 on stock tune
- going in for illinios emissions, what to expect w/ HPT?
- Thermostats and tune - general (dumb?) question.
- First questions on the predator(HELP)
- Help!!! Diablo says "Script Error" and wont download
- SOFTWARE FOR LAPTOP, Dyno tune, or Predator?
- On a MAF car does the AFR change from dyno to street?
- Headers and Tuning????
- Dumping fuel after tune
- some questions and answers from Diablo sport
- Question 4 Forum Members
- Dyno & Tuning Day - April 16th - Augusta, GA
- Tuner in Nashville Area...
- What other forums for tunning?
- Looking for a new tuner in North Dallas
- tuners in quebec or ontario
- Tunning options please help
- Intake/Exhaust opinions
- Tuning: Mike Bruce
- "check engine light" PLEASE HELP!!!
- Header install?
- mail order tuning
- HPTuner question
- what temp does the car go into "closed loop"?
- DTE brace..where to bu and how much?
- Tuning 101?
- Why dyno pull with wideband O2?
- no cats
- warning...don't do this
- Hptuner..what should I expect
- Q's About: Codes
- Good Dyno-Tuners in the Philly Area???
- Anybody use A&A for Dynotuning?
- LTFT's after Hypertech, OK, or return to stock?
- RFA Remote Function Actuation (Where is it?)
- posted in wrong forum...disregard
- Bo-rfa No Comm
- Q's About Pcm/342's
- Q's About The Vararam
- Is the Predator going to be enough?
- {VA} dyno tuning for LS1/LS6 & LT1/LT4 with Jeff Creech from C.A.M. at ABACUS 4/18/05
- Failed Emissions...help
- LAPD is the shiznit
- Mass state inspection with a tune - trouble ?
- Predator programmers at the LOWEST PRICES allowed!
- [AFR -street vs. dyno] My most trusted source just told me..
- give me some idea
- Help: 342 DIFF
- Help: Full Lenght Lg's
- Different dyno numbers from different tuners. What gives???
- Need help on tuning ltft with hptuners
- Tranny codes? (A4)
- Need HPTuner Performance tunes & mail order tuner support
- Need someone more knowledgeable about ac's than I...
- surging
- HPTuner question from newbie
- X-pipe Question
- Z06 rev limiter
- Tuning...can I do it myself???
- Best tuner for me?
- Cam degreeing. HELP????
- Question for Vinci Programmer
- If you were to buy a programer...which one?
- ls1 edit ?
- EFILive7 quick tune
- Dyno Tune or Predator
- PREDATOR or DYNO Tune
- odd thing i noticed, no CAGS w/o air pump??
- codes
- Turn Signal Clicking when off
- P0140 and P0160 codes after Tune
- Hooker Header Q'S
- Which should I buy, Predator or Vinci HP?
- Southeast Florida Tuner???
- need information on Predator and thermostat choice please
- WTB- Innovate LM1
- Ls1 Edit Vs Efi Live
- Newbe here, what should I get??
- Program question
- 2k4 Z06 5th gear question
